      07-02-2014, 07:36 AM   #287
Oregon
NRA Life Member, BMW CCA 30 year member
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Thanks again, Andy.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason
      07-10-2014, 07:41 PM   #288
E46NAQ7
E46NAQ7's Avatar
16
Drives: None
Thanks man, very useful DIY!
      08-08-2014, 06:24 PM   #289
doritos123
Drives: BMW 116i Performance Edition
Is it possible to remove the chrome surround from the bars?
      08-11-2014, 03:45 PM   #290
GnarlyMarley
Drives: 2013 128i
Yessir, its a two piece setup. Once the assembly is out, just undo the couple tabs and they separate.
      12-01-2014, 06:09 PM   #291
BigRussia
BigRussia's Avatar
152
Drives: 04 M3
Bumping this up to say thanks and pay it forward with a couple tips now that I did this install.
First, here is the link to the pick set I bought at Home Depot for less than $5, actually found it by accident while I was shopping for a set of Torx drivers.
http://www.homedepot.com/p/Husky-Pre...004H/204314893
(The 45 degree pick came in handy for picking tiny rocks out of my radiator and mending bent fins while I had the grills out, because I'm OCD like that )
Lastly, regarding the rubber weather strip that goes along the top; you actually don't have to remove it completely. You only need to lift off the two ends that go over the headlights, you can leave the middle section on the bumper trim. This is handy since you wont have to worry about lining it up perfectly again when placing it back on the bumper trim if you removed it completely.
Hope this helps
      01-02-2015, 05:19 AM   #292
Masaharu
Drives: 135i 2010 dct n55
Thanks for useful diy!
      08-05-2015, 03:42 PM   #293
XAMI
XAMI's Avatar
Drives: 135i
Great writup, had them removed in 10 minutes.
I used one of those hook-dental picks from Walgreens to get the lower clips out..
      08-31-2015, 08:58 AM   #294
PDACPA
Drives: F33 M Sport 435i
Just an update to those thinking of changing out the Kidney Grills. Swapped out both the OEM grills on a 2012 135i by pulling on the slats close to the headlights first and then the middle and the side close to the center Roundel and the grills came right out. Was very easy. New ones snapped back in with ease.
2014 F33 Blk/Blk MSport 435i (sold)
2012 135i Blk/Blk
      12-17-2015, 12:29 PM   #295
fknlewis
fknlewis's Avatar
Drives: E82 M Sport 120d
Just fitted mine no problem thanks to this guide! Oh and I couldn't find a right angle tool anywhere, and didn't want to wait to get it delivered so what worked for me was putting the flat head in the same bit and rotating it which made it lift up, definitely not the best way but it worked and honesty I didn't think it would snap or anything, felt safe to do it.
Thanks again for the guide!
      01-16-2016, 02:52 PM   #296
squidge
91
Drives: 1997 Porsche 911
Thanks for the guide! Used a set of Tekton hooks, $8 at Amazon.
http://www.amazon.com/TEKTON-6943-Pr.../dp/B000NPPBQK
      01-16-2016, 04:45 PM   #297
Orpo
Orpo's Avatar
26
Drives: 2020 M2 Competition 6MT HS
I did the same!
Thanks guys
      07-14-2016, 02:07 PM   #298
sandlion
18
Drives: 2011 135i
So I ran over a curb, and my kidney grills popped out. One shattered, so ordered some new ones. SO, passenger grill pops right in, starting the drivers side grill, and there is a plug / connector dangling in front of the radiator. No codes or anything, but does anyone know what this connector is for? The dealer wasn't helpful. Looks like stock wiring, but weird it's just dangling there.
I'm wondering if I ripped off a sensor or something?
Thanks, - Eric
2011 135i DCT
Space Gray Metallic | TR Motorsports 17x8 ET40 Wheels | Koni Yellows | FMIC | Charge Pipe | MHD Stage 1 | Riken Raptor 245/40ZR Tires
      07-14-2016, 04:19 PM   #299
sandlion
18
Drives: 2011 135i
OK, looked at it again, and the connector clips / slides on the the center post between the kidneys, if that helps.
2011 135i DCT
      09-09-2017, 12:34 PM   #300
Gangplank
Gangplank's Avatar
Drives: 2011 e82 135i n55 Sport w/ DCT
2011 135i  [0.00]
Thanks for the write up. Made for a 5 min. Project. One more step toward "is"
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
      08-03-2023, 04:43 PM   #301
schernov
80
Drives: 2018 340zhp, 2009 135i
Just installed these. For me easiest way was to undo 4 bumper cover retaining bolts on top and using a long flat screw driver to push three top tabs and one side tab. And they came out easy.
I failed using a pick tool trying to release bottom ones as the first go around.
      03-02-2024, 10:49 AM   #302
MOTO
Turbo fever
MOTO's Avatar
Drives: 2024 M340i
Necro Thanks!
