04-06-2013, 04:25 PM | #3169 |
Rep 67
Hey -
Heading over from the m5 board - I did buy my enet cable from a member listed on this board - but I do not have the required software needed to make this work. Is there someone here who would be willing to email me exactly what I need? Thanks so much Regards |
04-06-2013, 06:55 PM | #3170 | |
Rep 4
in couple hours I coded: - Video in Motion - Turned the Seatbelt Gong off - Remove disclaimer - Tire pressure + temperature in TPMS - Mirrors close by pressing doorknob (comfort access only) - Mirrors open automatically when closed with comfort access - Add HP/LB_FT/KGM/etc to sports display - Closes windows/roof with keyfob - Turned left and right front sidemarkers off etc... Thanks for all your posts, you doing a really great job. |
04-06-2013, 07:22 PM | #3171 | |
General
10543
Rep 41,219
04-07-2013, 02:04 PM | #3172 |
Rep 67
GREAT!
Thanks so much - I will be bringing my netbook from work - total apple geek here at home! - I will use the windows machine to start this, this week. It does seem daunting at first...... |
04-08-2013, 01:09 AM | #3173 |
351
Rep 2,937
Drives: 2013 Estoril 328i M Sport
Can US spec mirrors be programmed to fold on lock and unfold on unlock with the FOB, in cars that don't have Comfort Access?
04-08-2013, 06:13 AM | #3175 |
General
10543
Rep 41,219
Yes, if you have Power Fold Mirrors now, you can code them to work from the Fob.
04-08-2013, 06:51 AM | #3176 |
351
Rep 2,937
04-08-2013, 08:24 AM | #3177 | |
General
10543
Rep 41,219
FEM_BODY => KOMFORTSCHLIESSUNG_PA = aktiv is Comfort Access Both require FEM_BODY => ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv FEM_BODY => ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = aktiv
04-08-2013, 08:43 AM | #3178 |
Rep 1,130
Drives: '16 340i AW MSport
Placeholder of things I want to code when my '13 F30 328i arrives in May 2013.
Coders, please let me know if anything on my ToDo Coding list is not possible, on a standard f30 no options other than Lighting Package: - Disable AutoStopStart - Key FOB roll up all mirrors - Key FOB fold/unfold side mirrors - Lighting: Corner Delete (sidemarkers) - Turn Seatbelt Gong OFF - Display Tire Pressure+Temperature in iDrive - Window rollup safety disabled (while door is opening) - Default Sport Mode - Sport Display in HU_CIC Not sure about this one: - Code 6NH to 6NK. I have the standard 6NH bluetooth only(no nav), I read you can code it to 6NK to be able to play music/enable cover art, is this correct? Or does this require a specific hardware other then the standard bluetooth? Last edited by kromix; 04-12-2013 at 09:09 PM.. |
04-08-2013, 03:15 PM | #3180 |
9
Rep 56
Question re: Recoding of 6NH for Bluetooth streaming and Apple Cable
Hi,
I recently ordered a 2013 F30 (335i) with 6NH, 688 (HK Upgrade) and No Nav. It appears that 6NH will not let me use the white iphone 5 cable or do streaming BT without a Y-cable and/or BT adapter. I've read some posts here from folks who were able to recode 6NH to enable BT streaming audio and use of the white apple cable. Just wanted to check if I will be able to do the same with my config (6NH, No Nav, Unknown Combox) or should i just add 6NL to the order while I still have time and be done with it. |
04-08-2013, 07:20 PM | #3181 |
General
10543
Rep 41,219
Well, I'd tell you, but with only 1 Post, you can not receive PM's yet, so either increase your post count, or put up an email address.
04-08-2013, 07:21 PM | #3182 | |
General
10543
Rep 41,219
04-08-2013, 07:39 PM | #3183 |
9
Rep 56
04-08-2013, 07:46 PM | #3184 |
Rep 1,130
04-08-2013, 08:03 PM | #3185 | ||
Rep 1,892
I'd verify this with your CA ASAP. |
04-08-2013, 08:18 PM | #3186 | |
Rep 1,130
"Or you could save the money and have it coded if you have the 6NH option on your Vehicle Order. It was coded for free for me by a kind fellow BB'er and it saved me ~1100 dollars (here in Canada Enhanced Bluetooth and USB has to be bundled with BMW assist for a total cost of 1100 I believe). Check your VO and skip out on the option if you can, it's a nice way to save some money." Posted by hrosenberg33. http://www.f30post.com/forums/showthread.php?t=805746 Original thread. |
04-08-2013, 08:27 PM | #3187 | |
General
10543
Rep 41,219
6NH + No 609 = No Combox = No Codeable A2DP 6NH + 609 = Combox = Codeable A2DP 6NK + No 609 = Combox = A2DP from Factory 6NL + No 609 = Combox = A2DP from Factory And a car with with 6NH and 609 would be able to be coded for 6NK which supports A2DP, whereas the same car with only 6NH and No 609 can not be.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 04-08-2013 at 08:34 PM.. |
04-08-2013, 08:31 PM | #3188 | |
Rep 1,130
04-08-2013, 08:37 PM | #3189 | |
General
10543
Rep 41,219
04-08-2013, 11:36 PM | #3190 | |
9
Rep 56
So much for not letting BMW nickel and dime me for something that should have been standard in the first place :-) |
