04-29-2013, 07:11 AM | #3434 |
Rep 1,063
I've enabled this function in the car --- it works, i.e., starts in Eco Pro, but it also throws a CEL. Is there a combination of options required?
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
04-29-2013, 10:35 AM | #3435 | |
Rep 1,063
ICM/IcmKod_B_ECONOMIC ICM/IcmKod_B_ECO Both of these are showing verbaut in my FDL, but I'm wondering if that's something I changed that might be causing a CEL.
04-29-2013, 11:48 AM | #3436 | |
Rep 1,892
ICM/IcmKod_B_ECONOMIC is verbaut (installed), werte=01 ICM/IcmKod_B_ECO is nicht_verbaut (not installed), werte=00 |
04-29-2013, 11:50 AM | #3437 |
Rep 1,063
Thank you! I'll try these when I get home and see if this resolves the CEL.
04-29-2013, 11:15 PM | #3438 |
Rep 3
Drives: 2013 BMW 328i Sport Sedan
Jus got all the files together, can't wait to code mine.
04-30-2013, 09:07 AM | #3440 |
Rep 490
04-30-2013, 10:20 AM | #3441 |
Rep 84
04-30-2013, 10:46 AM | #3442 |
Rep 490
Maybe my fault for misunderstanding but I did recall there is 2 files that we can download the installer. One is zip up with ediabas, the other a standalone .exe installer (without ediabas). For user upgrading from 3.18.4, the stand alone installer is good enough (same file actually minus ediabas)
04-30-2013, 01:13 PM | #3443 |
General
10541
Rep 41,202
PM sent.
05-01-2013, 08:14 AM | #3444 |
Rep 1
Hi all !
I try to code a Serie 1 delivered on march 2013 but it seems that I need the last pszdata can someone please send me a link ? my mail : 1kc76l0nc9afum3@jetable.org thanks ! |
05-01-2013, 10:18 AM | #3445 | |
General
10541
Rep 41,202
05-02-2013, 07:53 AM | #3446 | |
Rep 67
05-02-2013, 12:59 PM | #3447 |
35
Rep 239
@shawnsheridan, it works again!! Now i can code again
The last thing i'm looking for is this http://www.7-forum.com/news/2011/1er_f20/eco_pro-p90078278-b.jpg It should be in the eco menu. I can only see the car on the screen, not this graph |
05-02-2013, 06:40 PM | #3448 |
15
Rep 144
05-02-2013, 07:28 PM | #3449 |
Rep 1,892
When we VO coded your car from 6NH to 6NK, we did not write the new FA to the car. This seems to work just fine. There is a separate E-sys operation to actually write the new FA to the car that we did not do.
What we did is change the FA in E-sys from 6NH to 6NK, save it to disk, and then tell E-sys to use that FA and not the car's FA for future coding for that session. Then we VO coded HU_CIC and CMB-MEDIA. So, we really haven't changed the the vehicle Order as we didn't write the FA to the car. All we have done is to set all of the things that needed to be set to enable A2DP, office, etc. So, when you take it in for updating, the VO will match their server and all you will lose is the coded FDL's that you set. Maybe someone can ring in here as to the above technique. If it works, I think it's better not to write a modified FA to the car if it's avoidable. That way, you shouldn't have to revert anything when you take it in for software upgrades. If the above isn't kosher, then we'll have to write the FA to the car. |
05-02-2013, 07:57 PM | #3450 |
15
Rep 144
Thanks for the clarification.
If we didnt write a new FA to the car but tell E-sys to use FA files on the disk instead, doesn't this mean that the car now is running on 2 FA files? 1 original from the deal and 1 from our coding session, if so How does the car know which FA files to run from? or Am i going way off topic here Let says if i was to VO code and a new FA to the car (add 614, 615 , 6AL), and when i take it in for an update, the VO won't match their server so what would happen in this case? |
05-02-2013, 08:36 PM | #3451 | |
Rep 490
So VO is really only used when reprogramming/coding. When your car run, it uses whatever FDL code that is already set. Think of it as Windows installation disk, every single option/feature is in the installer, but what runs your computer is what's saved in the registry. So using VO code without writing new FA to the car doesn't cost any conflict, it just facilitate the dealer to reset everything to default. As for option code, the dealer computer do know what originally should be in the car, so any obvious/conflicting changes their system will prompt & reprogramming stop. My dealer never say anything when I permanently added 6UH, 6AL SPBR, OMSA to the VO |
05-02-2013, 08:37 PM | #3452 | |
Rep 490
For some funny reason I still couldn't VO code without changing the car FA. I did intentionally skip the step to 'write FA', but somehow the FA still get change/updated on it's own when I code the individual ECU |
05-02-2013, 08:39 PM | #3453 |
Rep 490
Never try never know, but I suspect 6NK won't "pass". You could easily leave everything as it is, and see if the dealer screams
05-02-2013, 09:59 PM | #3454 |
Rep 1,130
Drives: '16 340i AW MSport
Getting my coding list down, confused about the differences between these Key FOB options:
Code:
Close SideMirror FOB Fembody 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN nicht aktiv aktiv Closing side mirror with Fob Open SideMirror FOB Fembody 3110 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN nicht aktiv aktiv Opening side mirror with Fob Code:
FOB long hold mirror fold CAS 3020 ASP_BEIKLAPPEN_B_KOMFORTSCHL nicht_aktiv aktiv Folds mirrors with long hold of lock button on key fob. Folds mirrors with long hold of door ridges on comfort access equipped vehicles. And lastly, what does this do? Code:
Configure sport mode HU CIC 3000 Macro_fds popup_only popup_and_config you can configure the sport mode in idrive Code:
Sports + Mode ICMQL 3000 LCMKOD_B_SPORTLENKUNG VERBAUT VERBAUT Last edited by kromix; 05-02-2013 at 10:14 PM.. |
