10-13-2017, 11:53 AM | #331 |
851
Rep 2,281
I want to do trans & diff soon. This DIY is a fabulous help. One issue is access to trans filler plug. I think OP said low profile tool needed. My 8mm hex socket is 1/2 inch drive and 2 1/8 inch long. Its got vice grip marks on the body so obviously I've used it before in a tight situation. With my 1/2 inch breaker bar on the socket, I'm now at 3 inches. Will report after I do the work on exactly how things work out, ie: how much clearance we have to access the fill plug.
Dackelone10632.50 |
10-13-2017, 07:45 PM | #332 | |
Thread killer
646
Rep 1,896
Dackelone10632.50 |
10-19-2017, 04:28 PM | #333 | |
European Editor
10633
Rep 22,992
Here is the Hazet tool I use... I got mine locally here in DE years ago for ~30 euros. I can't believe what they are charging for it now... Here it is on Amazon.com https://www.amazon.com/HAZET-Chrom-V...+tool+17mm+hex Here it is on Amazon.de https://www.amazon.de/HAZET-2760-Haz...rds=hazet+2760 And here on KC Tools... https://www.kctoolco.com/search.php?...ection=product Maybe get yourself a "stubby" 17 mm hex socket in 3/8th from Harbor Frieght. Or from SnapOn. Dackel
12-30-2017, 04:36 PM | #334 |
708
Rep 3,268
Drives: 2010 128i
Anyone have any trouble removing the trans filler plug? Mine is on there on tight! Is it reverse thread or something? I'm a little afraid to try too hard to break torque in either direction...and there's not enough clearance for my go-to cheater bar. Any tips?
____________________________ |
12-30-2017, 05:20 PM | #335 | |
European Editor
10633
Rep 22,992
IF its the first time removing the fill plug... yeah... it is TIGHT! Best thing is to use a new 8mm allen socket(or L-key) with a small cheater bar. It should break loose. No its not left hand threads. Remember righty, tighty... sometime you can get disoriented when you are laying under the car. Besure to remove the "fill" plug before draining your trans oil!! I think the fill and drain plugs are a 8mm allen/socket/hex. Looking on Amazon here is a nice set. But I am sure you could also pick up something at your local Harbor Freight or Sears or AutoZone. https://www.amazon.com/Titan-Tools-1...bby+socket+set Dackel
12-30-2017, 05:58 PM | #336 | |
708
Rep 3,268
Drives: 2010 128i
Thanks, Dack! I finally got both plugs off - it was just a matter of finding just the right angle that I could barely slip on my cheater bar (one-half of a floor jack handle). Not much space between the transmission and the ground on jack stands, and (like you mentioned) I was afraid that I might have been turned around and disoriented, and wanted to make extra sure it wasn't a left-handed bolt or something (although that would be a really odd place for one, admittedly).
Dackelone10632.50 |
04-14-2018, 09:54 AM | #337 |
Rep 22
Hey guys! I've read through this thread and cannot make a clear decision.... I have a 2008 328Xi 6spd So which transmission fluid is best for ease of shifting for summer and winter and safe for both bearings and synchro's ??
04-14-2018, 10:57 AM | #338 | |
Rep 1,001
I ran Pentoson FFL-3, IIRC, because it crossed to he ZF spec that crossed to the BMW MTL spec for my 135. Ive been happy. Lower viscosity lubricants will perform better in the cold but compromise high temperature performance to a point. Higher viscosity will be more difficult to shift in some conditions. Some fluids may have friction modifiers that affect synchronization. |
04-14-2018, 11:09 AM | #339 | |
Rep 22
I have the GM 6spd transmission |
04-14-2018, 04:41 PM | #340 | ||
European Editor
10633
Rep 22,992
For the diff you can use either a 75w140 or a 75w90 gear oil from Redline. You will need some way to suck out the old diff fluid - with a fluid extractor. You will need a little over 1.1 liters of diff oil. Dackel
07-05-2018, 09:07 PM | #341 |
51
Rep 144
MTF LT-5
Hi folks,
Great discussion. I struggled to find a replacement to my F82 6MT trans oil and this thread helped a lot. 1. I called redline. Interestingly enough: BMW MTF LT-5 = Redline DCTF #31004 https://www.redlineoil.com/dctf-dual...smission-fluid He said this is the recommendation on the newer transmissions. Check the pics & website. 2. I did an extensive search as well BMW MTF LT-5 = Pentosin FFL3 #1052107 http://pentosin.net/catalogs/Pentosi...dGuide2016.pdf These are 2 respectful companies offering DCT oil for manual transmission. I may go with redline and update you. Hope this helps. M Vier
///M4 /// 6MT /// Alpine White /// Sakhir Orange
Dackelone10632.50 |
07-05-2018, 09:56 PM | #342 | |
Rep 1,001
To be honest, Ive never been that impressed with the longevity/sustained shift feel from Redline fluids. Ive noted this in E30 and VW manual transmissions. For both of those, Amsoil far outshined the redline fluids after "the honeymoon". Redline was also noisy in my E30 LSD, when other fluids werent, and it behaved the same way, it just degraded (got louder) over time. People put too high a value on redline. Now, if its much easier and cheaper to get than the Pentosin or OE fluid, Im willing to give anything a try, but I dont put a ton of faith. Redline has also sold out to big oil, FWIW. Their Si-1 fuel additive, their grease, etc. are great. Im not anti-redline, and have and use a LOT of their products. Im just not as convinced about their gear oils personally... |
07-15-2018, 03:49 PM | #343 |
Rep 3,547
I like redline gear oils. I used them in my SUV and recently changed my manual transmission. I put in MTL when I had about 7,000 miles and put in D4 when I had 70,000. It seemed wrong to put in automatic fluid in my manual but I am happy to report it works well. The effort level with the MTL was not high but it is lower with the D4. I did not expect that. Especially on downshifts, the gears seem to engage easier. We'll see what it's like in 50K-70K miles but I suspect it will still be working well.
I used a cheap harbor freight allen socket on both fluid changes. It is 1/2 drive. I shortened it this time with an angle grinder. I could use it without shortening but it is easier now that it is shorter. I just cut off what wouldn't go into the transmission plugs anyway. Took longer to walk to the shop and get out the grinder than to make the cut.
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
Dackelone10632.50 |
08-13-2019, 07:38 AM | #344 |
Rep 1,416
Drives: M-Sport 128i, 328xi, 3.0CS
Just changed the oil in the differential and 6-MT transmission in my 128i. I used Red Line MTL in the transmission and Red Line 75W-90 in the differential, per Mike Miller's recommendation. The diff oil was still clear-yellow. The transmission oil was dark and really stinky. I didn't notice any difference in shifting after the oil change.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
11-15-2019, 08:58 PM | #345 |
Rep 12
Drives: BMW M235i, Honda S2000
I use Amsoil DCT in m235i manual trans. It meets the LT5 and pentosin specs. It's been great so far. Same with the 75w90 severe gear in the diff.
Btw great right up! The underbody on that car is mint lol. It's the same steps for the m235i if anyone was wondering. |
02-24-2020, 11:01 AM | #346 |
Rep 3,240
After another 4k miles I will be doing the transmission and differential fluid changes again. I previously did it at 30k, so now I am hoping the fluids will still be clear.
2012 BMW 128i 6MT Deep Sea Blue Metallic
04-30-2020, 11:10 AM | #347 |
22
Rep 28
Preparing for my first (on this car) tranny and diff fluid swap, I came across this fluid pump on Amazon which has some rave reviews. I'm going to give it a try and will report back (probably in late May at the rate I am s-l-o-w-l-y approaching the 60k mile mark during the Corona-era).
https://www.amazon.com/Mityvac-MVA68...ustomerReviews |
05-29-2020, 04:40 PM | #348 |
2183
Rep 2,807
What Differential Fluid Type
A while back I did a differential fluid change using BMW branded SAF-XO 75W90. Now thinking I might have used the wrong fluid.
In RealOem a different part number is shown for differential oil from 07/2011 onward. I know part numbers can change with no change in the part itself, but, it seems the pre 07/2011 oil is a 75W90 GL-5 spec while the 07/2011 forward is 75W85 GL-4. The viscosity isn't my concern, it's GL-4 vs GL-5, specifically the additive package and the way it attaches itself to surfaces. (initially dug into this when looking into gearbox oil for my old British motorcycles) Anybody know anything about this? Those with newer cars, what differential fluid did you use? I'm not hugely concerned since I don't put on a lot of miles and some gear oils carry both GL-4 and GL-5, but, since BMW decided to change spec in 2011, might be worth investigating.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
11-21-2020, 03:49 PM | #350 |
131
Rep 100
Did this today on my 118k 128i with Redline 75W-90 for the diff (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and Redline MTL 75W-80 for the trans (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1). Shifts feel much smoother, car is new to me and I doubt it had been flushed before. 10/10 recommend.
05-26-2022, 06:29 PM | #351 | |
Rep 575
2011 135i 6MT | Alpine White | Terracotta Boston Leather | M-Sport | BMW Performance Exhaust Resonator Delete | Active Autowerke Signature Exhaust | BMW Performance Suspension | Blackline LCI Taillights | BMW Performance CF Spoiler | CF Rear Diffuser | PPK | E92 M3 FSB | Matte Black Kidney Grilles | VMR V710 Jet Anthracite | Michelin PSS | BMW SS Pedals
05-27-2022, 10:34 AM | #352 |
Rep 1,017
Sadly Dackleone left us for the big race track in the sky. Ideally you would replace any fill or drain plug, but as long as yours are in good shape, I would just clean and reuse them. The gearbox isn't under a lot of pressure anyway.
Official BMWP Whore - BMWP suspension kit w/ M3 arms, BMWP big brake kit, BMWP intake w/Mishimoto tube, BMWP exhaust, BMWP carbon strut brace, BMWP short shifter, and BMWP carbon spoiler. OZ Leggera HLT w/ 245 square setup.
