03-08-2022, 12:04 AM | #331 | |
24
Rep 48
03-08-2022, 12:51 AM | #332 | |
Rep 1,048
Normally we get them either with a link from here or sharing the link at discord. Preferred method is to do a re-upload via wetransfer.com as the chinese then dont see many downloads of the file from their server. Kri |
03-08-2022, 01:59 AM | #333 | |
24
Rep 48
Here it is https://we.tl/t-w4z7KwcHx2 |
03-14-2022, 11:09 AM | #334 |
Rep 3
I have Android 11 head unit in my e61 ccc with software Ksw-R-M600_OS_v1.8.9 and i just want to check that the latest version Ksw-R-M600_OS_v1.9.9-ota is ok to install ?.
03-14-2022, 11:10 AM | #335 | |
Rep 1,048
We don`t have changelogs for newer files, i`ll upload 1.9.7 1.9.9 and 2.0.0 soon but at everyone's own risk. Kri |
03-14-2022, 11:28 AM | #336 |
Rep 3
03-14-2022, 12:47 PM | #337 |
Rep 1,048
03-17-2022, 02:58 PM | #338 |
18
Rep 116
Is it better to buy from Avin or aliexpress such as below? https://www.aliexpress.com/item/1005...rch-mainSearch
03-18-2022, 02:32 AM | #339 | |
1050
Rep 2,370
Drives: E63 645Ci
03-18-2022, 04:17 AM | #340 | |
Rep 1
Not been here long at all since picking up my F30 a couple weeks ago. Thank you for all the information here…! 👌🏻 My Droid 11 HU arrived with 1.8.6 installed and found it was rather buggy, so took the plunge with 2.0.0 as I didn't think it could get any worse. So far so good!! It's cleared up the Bluetooth connectivity which was the worst thing for me and a few other minor glitches. Including the default music app selection. It just wouldn't let me select Spotify… 🤦🏻 Hope this is of some help to someone! I can report back again after a week or so to see if I notice any bugs in the OS. Even managed an animated boot logo yesterday courtesy of the Discord forum you guys posted! |
03-18-2022, 09:37 AM | #341 |
Rep 5
Boot logos in page 2 are disappeared
Dear Erik, Boot logos in page 2 are disappeared after importing mylogo.zip and cannot restore them.. Always thank you for your kindness. Last edited by bdh0108; 03-18-2022 at 09:45 AM.. |
03-18-2022, 10:35 AM | #342 | |
Rep 1,048
The mylogo.zip has to contain all images, you replaced the original file with yours, you would need to recreate a new one that has the old and the new logos. Kri |
03-18-2022, 09:55 PM | #343 | |
Rep 5
But I mean the import function doesn't work at all. And the USB stick method, which is putting splash.img file in the OEM folder and connecting, also doesn't work while bootanimation.zip can be changed by this method.. Last edited by bdh0108; 03-18-2022 at 10:40 PM.. |
03-19-2022, 01:48 AM | #344 | |
Rep 1,048
The Bootlogo (splash) file format has been changed with A11, A10 splash files do not work here. No one has reverse engineered the new file format yet, so for the moment its not possible to change splash files for A11 for us. Kri |
03-19-2022, 02:57 AM | #345 |
Rep 5
Changing "Car" icon in Carplay
I found a small tip for changing "Car" icon in zlink carplay.
1. Root the device (Thanks to Kri https://f30.bimmerpost.com/forums/sh...&postcount=659) 2. Connect with adb command window 3. Replace the logo file /system/etc/exit.png 4. Change mod 5. Reboot Code:
C:\BMW\KswRooting-master\compiler>adb connect 192.168.0.47:5555 already connected to 192.168.0.47:5555 C:\BMW\KswRooting-master\compiler>adb root restarting adbd as root C:\BMW\KswRooting-master\compiler>adb remount remount succeeded C:\BMW\KswRooting-master\compiler>adb shell bengal:/ # cp /storage/emulated/0/exit.png /system/etc bengal:/ # chmod 644 /system/etc/exit.png bengal:/ # reboot I attached an example of new icon I created. Hope it's helpful, Thanks. Last edited by bdh0108; 03-19-2022 at 03:21 AM.. |
03-20-2022, 04:34 AM | #346 | |
Rep 5
Is someone working for it? I hope we can find the way soon.. How can I support? |
03-20-2022, 05:05 AM | #347 | |
Rep 1,048
I don`t have an A11 unit so i can't do it either Do you have a working file from your seller to reverse engineer ? I heard some sellers do offer a custom file. Kri |
03-20-2022, 05:35 AM | #348 | |
1050
Rep 2,370
Drives: E63 645Ci
I know every encryption can be broken with enough of time and resources. But we are car enthusiasts here with various backgrounds and levels of IT skills. This task lands 11 on a 1-10 difficulty scale according to one Android developer. No one is willing to spend months trying to "reverse engineer" the mechanism of compiling some meaningless pictures - that's the reality of that. |
03-20-2022, 02:17 PM | #350 |
18
Rep 116
I ended up ordering an Avin unit due to 1-day shipping (can’t beat that)
Installation is confusing as hell and not really clear. Are the USB wires and AUX thing even mandatory to install? I only installed basically the wiring harness and the 4G thing, didn’t install GPS because my car has nav already or the USB ports that connect to the screen. Everything is working pretty good- except CarPlay and audio when in android mode. I just can’t get it to work. Audio works fine on iDrice but the moment I switch to android , it doesn’t work. How can I fix this? |
03-20-2022, 02:35 PM | #351 | |
18
Rep 116
ID7 file?👀 Do I just have to ask them for this? |
03-20-2022, 02:39 PM | #352 | |
1050
Rep 2,370
Drives: E63 645Ci
Installation is pretty easy: you connect the quadlock cable, APIX video cable, all the antennae you're plannig to use, AUX cable (pretty important if you want to have any audio) and USB cables for any data transfers and updates. |
