E Series NBT Evo Retrofit Development Thread
08-26-2020, 09:52 AM | #331 |
Rep 21
08-26-2020, 10:54 AM | #332 |
Rep 763
Drives: BMW E90 Dinan stage 3 335I
i have a set for sale now working and tested from Nick.
2007 E90 335i N54 Montego blue with grey Dakota leather interior
08-28-2020, 10:22 AM | #333 | |
Rep 11
2. They were mostly phased out and the few that are still produced are hard to find and usually very expensive. |
08-28-2020, 02:09 PM | #334 | |
16
Rep 93
2. Very rare to find them in US spec units. You can get these all day from ECE units though. |
09-02-2020, 05:59 PM | #335 |
Rep 15
Cannot get network connection to EVO HU
Sorry to hijack the thread, but i cannot start a new one. I am performing a CIC to NBT EVO retrofit into a 2009 e92 m3. Bought a full system from a wrecked 2018 F36. I have everything cabled up but I cannot establish a network connection to the HU and I get no signal to the screen. It is getting power as I can feel it vibrate and get warm, and the retrofit adapter also gets power and powers the CIC faceplate. I have created a cable direct from OABR to ethernet (RJ-45) and have tried created 3 separate cables using 3 different CAT5e cables, 3 different OABR connectors, and always splicing in pre-crimped OABR cable leads with the MicroMQS pins. And have verified pinouts of each many times before and after making each one. I have also tested resistance of each lead through the cable on all 3 which are all good. So I literally have 3 totally separate cables that all produce the same exact result - when i plug it into my windows 7 laptop, the network adapter continues to loop from "identifying" to "unknown network" to "cable disconnected" every 1-2 seconds. I have also tried a second laptop with the same result. The cables from the EVO HU were cut off, so I don't think there is damage to the port/connector on the HU from them pulling it. I really hope my evo HU is not bad, but at this point I do not know what to try next. Any help is appreciated. Thanks!!
09-04-2020, 07:12 AM | #336 |
Rep 11
did you connect the activation line and supplied it with 12v 1k ohm?
09-07-2020, 12:52 PM | #337 |
Rep 15
Thank you for the reply! Yes, I did. For others that may come across this, I just found out the issue. It appears the retrofit adapter I was using was coded for an NBT unit and not an NBT EVO unit. The adapter provider just completed a remote session with me to update the firmware of the adapter for NBT EVO and I can now establish a network connection and ping the EVO HU at 169.254.199.99. I have no video signal and E-Sys still shows no targets that I now need to go troubleshoot, but I think the EVO HU is operational as now my climate control shows and temp values all show in celcius
09-08-2020, 06:07 AM | #338 |
Rep 14
Trying to wake up NBT HU. The head unit seems to react on CAN messages. If no messages go to sleep with no power consumption, when resume sending can - wakes up and consume up to 2.7A. However, the monitor does not work at all.
Is there any way to check it? Trying to validate video cable-piount, works like on this pic. Checked the voltage when screen is disconnected - got 8.4V but not constant.. Last edited by vitalic; 09-11-2020 at 02:05 AM.. |
09-11-2020, 02:07 AM | #339 |
Rep 14
tried to feed 8.4V to monitor, and woila it gets a message. HU reacts on can messages...
But when assembling together, screen gots black... Sending three commands on 500Kbps //0x12F, 8, 37 7C 8A DD D4 05 33 06 - nbt wake //0x130, 5, 45 42 69 8F FE - ignition on //0x21A, 3, 85 12 FF - lights on Please suggest how to troubleshoot it? Last edited by vitalic; 09-11-2020 at 02:39 AM.. |
10-20-2020, 08:34 AM | #340 |
Rep 3
I had the same issue with "NO SIGNAL" displaying on the screen. Apparently it got locked up and needs to be reflashed. Mine occurred after trying to update maps from an ebay seller, who provided me with a 4GB map file I formatted onto a USB drive correctly, it was recognized by the EVO but the map update failed. About a month later the screen would only display NO SIGNAL. I contacted Bimmerretrofit where I bought it, they reflashed it.
12-28-2020, 11:20 AM | #341 |
Rep 38
Drives: BMW 330ci M Sport Coupé
Mounting NBT Evo
Hi everyone.
Apologies for jumping on a thread, but this seems quite active and it might be useful for others to keep all info in one place. I'm retrofitting an NBT Evo ID6 along with the touchscreen of a MINI and an ATM module of an F31. Using a CarSystems emulator to get it to talk to my E90 330d. Previously had a similar setup in my E46, so have some experience of retrofitting an NBT Evo, including the wiring, coding and FSCs. Have one question and it's quite a simple one. How are people mounting the NBT Evo and CIC front plate? It fits into the locator pins, but this prevents the CIC front plate from pressing into the locator pins. There are also no aligned screw holes, and so I am using zip ties to hold it in. Are there any alternatives? I've attached a photo to demonstrate. |
12-31-2020, 08:35 PM | #342 | |
Rep 1,917
ATM with the mini touch screen is a damn nice setup. It is nice to see some other people are dropping huge money and doing to full setup in the E9X. Are you also retrofitting the ICAM or TRSVC as well? |
01-01-2021, 05:41 AM | #343 |
Rep 38
I have added wiring for iCAM in case I want to do that a little later down the line, and have excess CAN wiring tucked away in within the boot liner. They use the same micro mqs crimps as the OABR. My crimping tool isnt particularly good, but it can just about do them. Always have to shave off some of the insulation to get the pins to fit in.
Well, I had the same setup on my E46. Managed to get an Evo and emulator for a decent price on eBay. I have only just bought this car and intend to keep it for around 3-5 years. Its nice having the updated gadgets. Thanks for the heads up on the faceplate, Ill add a ground wire in. |
01-01-2021, 02:32 PM | #344 | |
Rep 1,917
01-04-2021, 02:22 PM | #345 |
Rep 14
Hi guys! I was able to start my NBT on bench using cheap Arduino and MCP2515.
Need to pair front panel with volume knob, am/fm and other buttons. It works with I-bus or Lin bus. Can Anyone point me to the right direction how to find appropriate CAN ID's to execute these commands at NBT? I would sniff them from a front panel via Lin bus. |
01-10-2021, 08:47 AM | #346 | |
Rep 4
yardım
lakin ana üniteyi bir türlü uyandıramadım.ana üniteyi uyandırma konusunda yardım etmenizi rica ederim. uyandırmak için gereken mesajları paylaşmanız mümkün olabilirmi? saygılar. |
01-12-2021, 12:33 PM | #347 | |
Rep 14
I had an issue with MC2515, had to explicitly select 8Mhz. |
01-17-2021, 02:05 AM | #349 |
Rep 14
PHP Code:
01-22-2021, 04:15 AM | #350 | |
Tinkerer
83
Rep 532
0x12F: 00 50 8A DD D1 01 36 C1 (100ms) 0X130: 05 F0 FC FF FF (100ms) 0X510: 40 10 80 00 00 00 00 00 (500ms)
2014 F25 X3 335d M-Sport:
01-27-2021, 07:20 AM | #351 | |
Rep 4
teşekkürler
paylaşmış olduğunuz kodları mevcut kodlarım arasına dahil edip uyandırdım teşekkür ederim. mcp2515 şu 15 lira lik can bus ile uyandıramadım. can bus sheld ile 500 16mhz ile mümkün oldu. Last edited by ahmettemha; 01-27-2021 at 07:26 AM.. |
