BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30/F20 TPMS Retrofit
Studio RSR
      07-30-2021, 06:24 AM   #397
hawk_lv
Drives: F31 316d
Hi,
I do have F31 05/2014 With DSC MK100
When I bought car, I did receive RDC failure message. Thought that reason was missing sensors in wheels, so I decided to buy wheel sensors. (6855539)
After installing them I still get RDC message. So that means that I did buy wrong sensors?
Or I do need some coding to make them work ?
As sensors arn't cheap to change is there any other options? like adding RDC module (near diff with wiring)? And will it not conflict with DSC MK100? And isn't that some kind a downgrade?
- Thanks in advance.
      01-17-2022, 08:08 AM   #398
antox90
Drives: BMW F20 116D ED
Hi, first of all compliments to all of you for this topic and this forum on which I always find brilliant ideas!
Then, I have a F20 12/2012 without TPS and I would like to retrofit it.
As far as I've understood from realoem, on the F20 there should not be present this module but, reading the thread, it seems that many of you were able to achieve this retrofit.
It is almost everything clear except how to wire the new module: I've read that many of you were able to create your own harness but nobody has explained how.
I mean, the pinout has been already reported in one of the first messages but where did you get the connector?
Many thanks for your great support
      01-31-2022, 11:51 AM   #399
Mitraks
Mitraks's Avatar
Drives: BMW 320d Sport line
Hi everyone
I got F30 08/2013 and my question is
Control unit 6876227 / Sensors 6856227 will be work ?
Any better sets ?
      06-12-2022, 05:46 AM   #400
kyo7877
kyo7877's Avatar
37
Drives: BMW F22
The key thing is Radio Remote Control Receiver
If your car was produced before 2014/03, you need to change the Remote Control Receiver, and because it's replaced, the frequency of your fob keys is also changed, this means your fob keys won't work, so you need to make a new fob key. here's the steps,
Get 1). 4 TPMS sensors
Replace 2). the Remote Control Receiver upto latest
VO code 2VB.
      06-27-2022, 10:03 AM   #401
Rockyz
Rockyz's Avatar
Egypt
Drives: E90 LCI
Hi,
I had my F30 340i prod. 03-2018 retrofitted with TPMS sensors through local workshop by simply adding tire sensors and doing some coding back in 2019. They work since then without any problem. Now, i am expecting full car update at dealership due to factory recall and i would also expect TPMS coding to be cleared afterwards.
I am preparing myself to recode necessary parameters using ESYS and ENET cable, I loaded current FA from car and was expecting to see 2VB already present in vehicle order, however it is not!
Any explanation for that?
Thanks!
      07-11-2023, 10:26 PM   #402
arsenal6
Drives: bmw 428xi
2015 bmw 428xi  [0.00]
I have a 2015 428xi (shitty Canadian edition). How complicated would it be to retrofit from FTM to TPMS?
      10-19-2023, 09:10 AM   #403
AlvaPinSo
Peru
Drives: BMW 435i Coupe F32
Originally Posted by larry_bml View Post
NBT doesn't recognize by itself the rdc sensors, DSC has this function on newer cars. On your 2013 , I'm 90% sure that you still need rdc ecu and wheels sensors.
Hi, i have a 435i F32, I have upgraded to an NBT Evo, my car's production date is 07/2013 and it has Euro Spec, what part numbers do I need to get the TPMS?
What setup do I need? 6876227 and 6856227? 6855180 and 6798872?
      02-01-2024, 02:31 PM   #404
dansobolanu
Drives: Suzy N57
THANK'S TO THIS THREAD I'VE MANAGED TO fully retrofit the 227 RDC module paird with 873 wheel sensors, on a 330Xd from 2013 !
the 227 module was SH from an F07 2015, coded and programed with Esys.
Everything tested before and after, no errors....
Posting this just to say THANKS !!!
https://youtu.be/rE6kPiOHYOw
Smile More
