12-09-2021, 05:07 PM | #397 |
469
Rep 280
Drives: M2 F87, M3 E92 & E46, C63, 911
Garage List 2018 BMW M2 F87 [0.00]
2008 BMW M3 E92 [0.00] 2003 BMW M3 E46 [0.00] 2012 BMW M3 E92 [0.00] 2011 Merc C63 AMG [9.00] |
yes, i should have a kit laying around in my stock. but why would you want to swap? the e92 m3 pinion ball bearings are quite solid. if set properly they last very long, even when used on track. and you can improve their life even further with the GT4 solid sleeve (instead of crush sleeve).
i got these taper roller bearing conversion kits many years ago when i was not sure if the ball bearings will be capable of motorsports and hard abuse. but i had no issues with all e92 m diffs i built with the ball bearings. there are other bmw diffs that would need this conversion kit a lot more. even f and g m-diffs do have weaker bearings compared to e92 m! |
DrFerry6734.50 |
12-26-2021, 10:48 PM | #398 | |
Rep 22
I found this: https://osgikenusa.com/collections/l...ducts/bm237-ha it says fit both E46 M3 and E9x M3. Is it a mistake or this same unit can fit to both E46 M3 and E9x M3? While with this link, seems same unit: https://www.ecstuning.com/b-os-giken...unit/bm237-ha/ it says only fit E46 M3 And how your limitedslip.de LSD compares to OS Giken? Have a good day |
DrFerry6734.50 |
12-29-2021, 04:48 AM | #399 |
469
Rep 280
i tried this os giken unit in 2 different setups ("spec-s" and "spec-x") in my e92 m3 and i was very disappointed on both setups. really not what i expected. plus the quality problems you often hear with os giken units i stopped putting time and effort in making this unit work. plus it is pretty overpriced for a basic "steel on steel" friction material unit. of all units i tested it was the one with the weakest performance (spec-s) and the most NVH (spec-x).
if you are interested in my findings on the osg in detail check the first pages of this thread. i did a detailled writedown with pictures on both setups. so imho the drexlers are by far better units (really no comparison at all). and even the "low budget" zf based 4cp units are easily outperforming the osg. fitment of this core mostly depends on ringgear used. if one wants to buy a certain lsd core i ask for the required information and then can choose the right core and according parts to make it fit for that application. |
DrFerry6734.50 |
12-31-2021, 05:12 PM | #400 |
Driver
2692
Rep 2,714
Odd, my spec-x OSG is amazing, and mostly silent on the street. Dry or wet track conditions, I couldn’t ask for better.
E90M 6MT Slicktop Single Humper in need of a diet
12-31-2021, 07:08 PM | #401 |
Rep 4,183
I think OSG had some quality issues with a batch of LSDs many years back. That has been resolved but they still carry the stigma of that incident.
01-05-2022, 02:05 PM | #402 | |
469
Rep 280
why didn't they replace the affected parts on the units sold? or at least why did they not inform their customers about this? so far, no one informed me... and i guess it is unlikely to happen at all, 9 years later. mistakes happen... the question is how you deal with it! so yes, this is a big stigma to me then! luckily drexler is certified to IATF 16949 and ISO 14001. this is the big advantage of companies that also (or mostly) supply big OEMs. they really (have to) care about quality control. |
07-26-2022, 10:47 AM | #403 |
469
Rep 280
due to the many inquiries on drexler lsd cores for bmw m3 e92 and e46:
good news! they are back in stock now. i just got x65 drexler lsd cores for BMW 210 type diffs. each can be built individually to any spec required. i received ~200 drexler units in total recently, also for bmw 188K/L diffs (non-M E46, E90, Fxx), M2/M4 F82 and also M4 G82. additionally various Porsche, Merc C63, Toyota GT86, Nissan 370Z, ... if you require any drexler core that fits your needs and your gearbox, just contact me! worldwide shipping! |
08-29-2022, 09:43 PM | #404 |
Rep 893
Awesome thread, Florian. Just read the whole thing. I'll be in touch in the near future for my E92 track car.
Instagram: slcook54
reidetailing642.00 driftflo468.50 |
09-01-2022, 11:28 AM | #405 |
29
Rep 14
What's the best bang for your buck when it comes to LSD's? I'm sure I'm no where near the skill level of seeing a difference when I'm at a track day but I like spending money on car parts.
09-02-2022, 01:10 PM | #406 | |
469
Rep 280
and all lsd cores and setups i offer are a big upgrade compared to the OEM lsd. in the end it is "you get what you pay for"! the zf45 is a good low budget lsd core, but a drexler "gt race" (best for track, good for street) or "gt performance" (best for street, good for track) are delivering even more traction and rear end predictability while being noticably smoother in reaction and more durable... but you have some bucks more to spend initially. in between is the drexler "performance"... all the drexler parts, more clutches then zf45 but less then the "gt" setups. so depending on budget get one of these and you will be happy... and feel the difference!!! |
06-14-2023, 09:43 PM | #407 |
Rep 568
Drives: BMW M4 DCT (F82)
Does this statement also apply to the newer M cars, for example a F82 M4 with active M differential that locks up on demand?
Current: F82 Mineral White M4 7DCT
Gone but never forgotten: E92 Sparking Graphite 335i (N54) 6MT build thread. |
06-15-2023, 02:50 AM | #408 | |
469
Rep 280
the newer e-diff (like used in f and g series m cars) is a little improvement over the old m-variable (used in e46 and e92) but still leaves a lot of room for improvement via fitting a clutch type solution. even bmw motorsport knows this and installed the clutch type hardware that i offer into their entry level racers m2 racing and m4 gt4 f82&g82 (for high end racecars like the m6 gt3 and m4 gt3 such a clutch type unit is standard as well). although these two entry-level racecars (m2 racing, m4 gt4) are designed with a low cost approach they opted to change the diff as it will have a big impact and benefit for performance, predictability and also durability. the e-diff is not very intuitive to drive and tends to fail prematurely when driven hard (i.e. on track). setup of the e-diff is optimized for unexperienced drivers and safety (of course)... not performance foremost. so, long story short: expect a big and noticably improvement when upgrading to one of the units/setups i offer based on the oem gt4 hardware and set to the individual requirements of my customers. i have already ~40 m2/m4 units running (for both, track and street cars), all customers very happy, no complains at all... |
DrFerry6734.50 |
06-15-2023, 02:54 AM | #409 |
469
Rep 280
