BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > **N55 Full Bolt On Dyno** "Proceed"
      06-16-2011, 04:12 PM   #23
Shellacked135i
Drives: 2010 135i, 09 335xi
How accurate is that sniffer?
      07-30-2011, 11:51 PM   #24
Brian@bavarianx
Drives: E36 M3
Hmm, maybe all the SoCal N55 guys should do a dyno day!
      07-31-2011, 06:13 PM   #25
CPWINCH
CPWINCH's Avatar
Drives: Toyota Prius
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
      05-10-2012, 09:39 AM   #26
335 oClock
MOE
335 oClock's Avatar
Drives: 2011 e92 335i 6MT
jus tryin to learn here...what is the reason that the car is running "lean"? and what exactly does that mean?
Originally Posted by Booztd 3 View Post
That drop you're seeing is the car going lean as hell....and likely detonating like crazy.
Take a quick look at your A/F ratio and its around 16 which is even lean for cruising, let alone peak tq.
That thing needs fuel, in a big way. I would seriously not even drive your car at WOT until you get it back on the dyno with some added fuel (or pulled timing)
You'll want to see that AF around 11.5 on pump gas (not sure what octane you're on) but anything from the pump needs to be around 11.5
It even appears you're lean through damn near all of your powerband
Originally Posted by shockin330i View Post
Welcome to DI. These cars all run ugly lean. The drop has to do with boost overshooting the max and the car compensating for it.
