Spacers on OEM E92 only
03-02-2015, 11:56 AM | #23 |
130i Performonster
152
Rep 80
Drives: 2009 E82 130i Performance
That Is Stock.
Look at My First pictures on Top. There you Can See it a Little Bit. |
03-02-2015, 11:58 AM | #24 | ||
Rep 1,347
03-02-2015, 12:29 PM | #25 | |
26
Rep 198
also another useful thread: http://www.e90post.com/forums/showth...413211&page=71 but then again, camber, tyres etc are uncertain for these LCI's Guess its trial and error, I've the ordered spacers anyway, lets see how this goes. any further input and suggestions welcome |
03-02-2015, 01:21 PM | #26 |
130i Performonster
152
Rep 80
Allright. Give us some visual input.
Try and error is the best way at spacers. |
03-01-2016, 08:32 AM | #28 |
Rep 2,962
I'm running 19x8.5 front with 235 tires and 12mm spacers, and 19x9.5 rear with 265 tires and 15mm spacers. LCI e92 msport with stock suspension and I only rub in the rear (slightly) if I go over a huge bump while traveling fast.
03-01-2016, 06:50 PM | #29 |
Rep 3,131
Drives: 2011 335i e92 DCT
I have the same car and wheels.
I have 12mm front and 18 mm rear, wish I went larger. The only run I get is if I go over a speed bump too quickly, or hit a pothole at speed. |
03-01-2016, 06:56 PM | #30 |
23
Rep 139
03-02-2016, 02:15 PM | #31 |
Rep 4,502
04-02-2016, 10:48 AM | #32 |
Rep 664
04-02-2016, 02:45 PM | #33 |
34
Rep 142
I know this doesn't really address or help with the spacer question/issue, though from a guy who's had a lot of different spacer setup I'd say your time and money would be better put towards buying wheels with the correct offsets for your application.
By the time you start hitting a 20mm spacer ideally you'd want to start looking at adapter style like H&R DRA spacers rather than bolt-through style (in my opinion), and if you're in for two pairs of those it's starting to become a significant chunk of a set of new wheels. If the cost of new wheels isn't viable financially then figure out what offsets you want in the long run and keep an eye on the classifieds, tons of great deals on people's used wheels. Hope that helps in some way...good luck. |
04-04-2016, 08:28 AM | #34 |
Rep 3,131
Not lowered at all, stock m sport suspension.
Rubs in the rear when the road suddenly dips, rear fenders are rolled as mush as possible Rubs in the front when turning the wheels and reversing
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
04-04-2016, 10:08 AM | #35 | |
Rep 664
I think i've made my decision. I'm gonna go with 12 mm front and back. |
04-04-2016, 07:24 PM | #36 |
Rep 3,131
No not anymore I dont, I want to cut the rear fenders on the inside to make some more space, when i inspect the rub area, its only just touching the rim of the tyre, and the part thats touching is on the inside of the fender
04-04-2016, 07:26 PM | #37 | |
Rep 3,131
Its not an MSport thing is it? I had a body shop try and roll them even further, they got another 1-2mm out of it, which decreased my rubbing by about 60% I think the next step is to get someone to do some cutting, theres a lot of fatness in there
04-14-2016, 06:59 PM | #38 |
Rep 664
Installed my 12mm spacers all around today and i'm happy with them. No rubbing at all in the rear and it rubbed a bit when turning the wheel and reversing but if I go slow, no rubbing. Haven't had anyone in the backseat yet so we will see.
04-14-2016, 10:02 PM | #39 |
Rep 801
I run 15fr with no issues could probably run a 18
in the back i run 18 and it rubs slightly...for no rub 15 would be ideal i drive a 335is with the 19" 313's and stock rfts 225 and 255 that should be identical to your setup and this was ran on the sport suspension with H&R sport springs imo an 18 and 20mm spacer would be perfect with a rear fender roll also camber comes into play alot, but the above was ran after being aligned at bmw |
04-14-2016, 10:17 PM | #40 | |
Rep 664
04-15-2016, 08:32 AM | #41 | |
Rep 801
04-17-2016, 08:25 AM | #42 |
Rep 3,131
I had 3 people in my car the other day. The rubbing in the rear was extreme.
19 inch 313 wheels with 265 tyres and 18mm spacers, fenders rolled as must as possible. |
04-18-2016, 07:57 AM | #43 |
Rep 11,908
Did someone say spacers??
5mm both front and rears on H&R sport springs and Koni yellow shockies |
thormessiah165.50 |
04-18-2016, 08:30 AM | #44 |
Rep 1,707
I have 313s with 10s in the rear but I can def fit a 12mm with no issue, contemplating looking for one...
Same spec wheel and tires, I am low but not slammed and no fender work done. |
