Feeler GB: E92 LCI Tailights
09-28-2012, 09:44 PM | #23 |
Jedi samurai ninja turtle
621
Rep 3,021
Drives: X3 M40i 2018
anywho, i will be trying this very soon as i have a set on their way..
I will test if it works without harness, however all kits are saying that harness is required. |
09-28-2012, 10:24 PM | #24 | |
Rep 968
09-29-2012, 03:39 AM | #25 |
Rep 941
There's definitely an oem retrofit harness. You may not have noticed it if it's already attached to the lights. Simply converts the new connector to the old one. It's only a few bucks from what I recall. The $200 one I suspect has some extra resistors to avoid coding. Sounds like a rip to be honest. Getting them coded or doing the coding yourself is a better solution.
09-29-2012, 05:44 AM | #26 |
Rep 89
Why not just spend a lil extra - Buy them from Stu and less headache?
I think if you show him some love i.e mula - He will install too? (Could be wrong about that though) |
09-30-2012, 01:46 AM | #27 |
621
Rep 3,021
All rumours and hear say will be tested soon folks!
like i said, i have a set coming from BMR and Stu and myself will test the harness situation. From everything i've seen, the harness is needed for all LCI upgrades as the clips/sockets are different. But all will be confirmed in 2 weeks or so. |
09-30-2012, 03:37 AM | #28 |
Rep 6,285
09-30-2012, 05:16 AM | #29 |
621
Rep 3,021
So it looks like you just need to switch the yellow and green wire over?
09-30-2012, 09:44 PM | #30 |
Rep 308
Do you know the part number for the harness? I am sure that there is someone out there either overseas or within Oz that sells the harness for less than $200.
EDIT! There you go guys. http://www.ecstuning.com/BMW-E92-335...ght/ES2138675/ UNDER $100 SHIPPED TO ALL YOUR DOORS!! ^^ OR FOR $89.00+shipping here- http://www.europeanautosource.com/pr...23-3-series-m3 (I'm not too sure whether this harness kit is OEM) Last edited by Rob32R; 09-30-2012 at 10:12 PM.. |
10-01-2012, 05:35 AM | #31 |
127
Rep 2,224
Yeah you need the harness, unless you're an epic tight ass and want to do some wiring. It's just an adapter to convert the pre lci plug from the car to fit in the new lights. They're cheap and the 1 part number has both the left and right harnesses.
Then you need to 'code' disable the bulb checks. The new foot well module isn't really needed unless you have the real old module 2 and want to recode the software rather than remove bulb checks afaik. |
10-02-2012, 01:45 AM | #34 |
Rep 640
Good to hear..
08' E92 335I
Black Sapphire Metallic | M-Sport | GT-CS 19" Matte Anthracite | BMW Perf. Exhaust | JB4 | AR Design Catless DP | R1 Concepts Cross-drilled & Slotted Rotors | aFe DCI | ER Chargepipe with Forge DV | ER FMIC |
10-02-2012, 07:20 AM | #35 |
Rep 6,285
I should be able to do this GB guys
Let me know if you're serious! Last edited by DR-JEKL; 10-03-2012 at 03:00 AM.. Reason: Stu is now purchasing the taillights |
10-02-2012, 09:10 AM | #36 |
20
Rep 302
10-02-2012, 09:12 AM | #37 |
19
Rep 250
Shane, Have you spoken to Stuart as well?
I would be down for a set (for e93), but I'd rather support Stuart because he supports the community so much and is a great guy to deal with. |
10-02-2012, 11:27 AM | #38 | |
20
Rep 302
By the way, Ali...picture of your 335I exhaust please!! |
10-02-2012, 06:55 PM | #39 | |
Rep 6,285
Wont hurt to ask him though!! Last edited by DR-JEKL; 10-03-2012 at 03:01 AM.. Reason: GB through Stu @ BMR |
10-02-2012, 07:13 PM | #40 |
Rep 6,285
Stu from BMR has indicated that he can supply for this GB, please see original post @ the start of this thread
10-02-2012, 07:40 PM | #41 |
Rep 5,530
thanks for organising Shane
did all the hardwork for me Lights: - will be OEM - 4 pieces total (inner & outer, left & right) - amber blinkers - inclusive of GST |
10-02-2012, 08:52 PM | #44 |
Rep 2,934
The forum should always be about members helping other members first. I am sure Stu is big enough to understand this.
