04-23-2015, 01:24 PM | #24 |
Rep 1,178
I thought the rebate is on V1 and up
2002 E46 M3 Coupe.. SOLD
2011 BMW 1M Coupe SOLD 2013 BMW M3 Coupe SOLD 2014 BMW 335i MPPK SOLD 2015 M3 SOLD |
04-23-2015, 01:51 PM | #25 |
Rep 517
Justin at supreme told me they were on the has. I haven't checked yet to verify.
04-23-2015, 02:19 PM | #26 |
19
Rep 74
05-02-2015, 07:38 AM | #27 |
13
Rep 23
Gentleman, just some honest feedback.
I put the stock springs on again and the floating at high speed has remained. So we can logically deduce that something went wrong during the initial Eibach Spring installation. I have rechecked my alignment, the guys made some moderate changes to toe settings, which admittedly has helped but it's nowhere near 100%. I am welcome to any suggestions. |
05-02-2015, 11:16 AM | #28 | |
General
21133
Rep 20,742
Drives: 2021 911 turbo
Maybe the Eibach aren't that bad after all .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
05-02-2015, 11:21 AM | #29 |
13
Rep 23
05-02-2015, 03:37 PM | #31 |
Rep 1,178
I will install my KWs on Friday and will post here
05-02-2015, 04:29 PM | #32 |
19
Rep 74
Had KW HAS installed last week. Been driving a lot since then. I really like the ride. Better turn in then before but that could be just the way the alignment was set-up. Does not get flighty over bumps. Really happy with them.
05-08-2015, 03:17 PM | #34 | |
67
Rep 102
05-08-2015, 04:44 PM | #35 | |
Rep 3,834
Those coilovers listed will outlast your car. You can set the ride how you like it vs paying someone to keep swapping springs out.
Daily: G12 750 MSPORT Weekend Car: E90 M3
05-08-2015, 05:28 PM | #36 | |
67
Rep 102
I also disagree with any coilover outlasting the car. Shocks are a wear item just likes tires and brakes.
05-08-2015, 11:52 PM | #37 | |
Rep 3,834
K&W / Bilstein / TC are known to last 80k-100k miles with lifetime warranty and rebuild-able shocks. Feel free to cross check my claims, you'll find forum members getting more than 100k miles from those brands (track and street). Not sure how long you plan on keeping your cars, but 80k+ with lifetime warranty is acceptable in my book. If you slap on random springs to the stock shocks, the shocks aren't valved to deal with the stiffer spring rate = bouncy = faster wear on the stock shocks. The whole suspension is compromised by a $300 spring vs thousands of hours on R&D to make the M suspension near perfect. My thought is if you're going to upgrade, you'll have to spend a good chunk of change to "improve" the M suspension setup.
05-09-2015, 12:05 AM | #38 |
69
Rep 127
This is why I will wait until they do a competition package like the current M5 before trying to buy an M3. Hopefully it will be lowered another 10mm and have a little more power. Then I won't have to spend a ton of money on aftermarket parts and get a better car too.
05-09-2015, 07:50 PM | #39 | |
314
Rep 2,448
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 Last edited by swifty; 05-09-2015 at 08:00 PM.. |
05-11-2015, 12:56 PM | #41 | |
Rep 3,251
They all use the same double adjustable twin tube design and fail to see any difference in construction quality... Bilstein uses monotube shocks, which in theory should have faster and more consistent damping response than twin tube design. But you might as well go with remote reservoir JRZ or Motion Control if you want step up from KW and TCK level. Anyway, lowering springs on stock shocks are just bad idea in general. You are sacrificing decent amount of suspension travel due to the lowering. Go with a properly paired spring/shortened shock combo or just get a set of coilovers if you want to do it right... These lowering springs and coilover conversion kit for stock shocks will do very little to improve the suspension, if not making it worse...
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
05-12-2015, 10:05 AM | #42 | |
314
Rep 2,448
Regardless, I think everyone agrees that lowering springs are not the best solution hence why I never bothered with them on the 335. However, I read a lot about swifts on the GTR forums and the M3 forums after trying them out, I was surprised. It's been almost 2 years and though the drop isn't significant like H&R, the ride is not much different than OEM. Furthermore, the up and down motion improved a lot over bumps as the linear springs settled down quickly. The issue with coils is that you need patience initially to dial it in which eats up a lot of time. And if you are not familiar, it means more frequent trips to the shop that installed it. Then there is the increase in NVH. Also if you do blow a shock or something, there is down time. Out of 10 ppl I know with coils, atleast 9 of them faced some kind of issue initially. Even with JRZ, an issue crept up with one of the shocks that JRZ took care of right away but it meant more money to take off, ship and install while also losing couple days of use of the car.
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
05-12-2015, 10:34 AM | #43 | |
Rep 3,251
It would be nice to know these kind of information when I switch to the F80 platform down the line.
05-12-2015, 11:09 AM | #44 | |
314
Rep 2,448
