02-24-2010, 01:08 PM | #23 |
BMW n00b
50
Rep 1,143
How much did this set you back?
09 SpaceGray M3 DCT
Power: Dinan 3.62, Gintani Race Mufflers, Dinan Intake, Gintani Xpipe, RPi Scoops Cosmetic: Vrs Poly-Lip, CSL Trunk, LED Interior Lights, LUX H8, Smoked Tails, Challenge Diffuser |
02-24-2010, 07:44 PM | #24 |
Rep 1,198
Approx. $900. Includes camber/caster plates, springs, sway bar links, mounting hardware for height adjusters, height adjusters and rear shock mounts. Call Jay at GC for specifics.
Thx! BC
'15 M3, '16 911 Turbo S Cab
02-24-2010, 07:51 PM | #25 |
191
Rep 2,867
02-25-2010, 10:49 AM | #26 |
Rep 7,887
Barry.What front wheel & tire setup are you running?I spoke to Jay yesterday @ GC and the only thing that concerns about this kit is that you loose 2mm of wheel/tire inner clearance to the strut.I am running 275/35 18 on a TR 18x10 25p for my track setup.
02-25-2010, 11:00 AM | #27 | |
Rep 1,198
Thanks, BC
02-25-2010, 11:27 AM | #29 | |
Rep 7,887
02-25-2010, 11:37 AM | #30 | |
Rep 1,198
I know Stoptech provides a wheel fitment guide and I would assume others would too so that should help you with your decision. BC
02-25-2010, 12:04 PM | #31 | |
Rep 7,887
02-25-2010, 01:45 PM | #32 |
Rep 1,198
Gotcha. I dunno doesn't bother me to be honest. I'm probably in the minority here....
02-25-2010, 02:35 PM | #33 | |
Rep 9,034
02-25-2010, 05:00 PM | #34 |
191
Rep 2,867
So I got my custom alignment done. I finally found a shop here in nyc that is superb with custom alignments. The owner of the shop I went to, which is also the guy who did my alignment was very knowledgeble, and it was very comforting to know I finally found someone who knew what they were doing. He gave me an aggressive setup, but is still easy on the streets. I did feel the grooves on the road a bit more, but wasnt really able to test it out since we r getting hit with snow. He also said there is no way to go any lower.
However, what is even better is the fact that gc called me, and offered to send me a shoorter spring via air since I wanted to go lower. So apparently there is a solution to that issue. The spring is slightly stiffer but 1" lower, and gc said there is still enough travel that u wont hit the bump stop. I dont really mind how the car looks now, since its still lower then the eibachs but just a bit higher then the H&R's, but i do love how it drives. And now that I just finished getting this alignment, I dont know wether I want to change it up. However if i do, all that needs to be done is the front, which shouldnt b a long process at all. I told gc I would wait for my new wheels to come in, and if I dont like how it looks then, Ill go for the lower spring. They said that was absolutely not an issue and if I decide to switch they will overnight the new spring for me. Thumbs up to Ground Control. My first time daling with them and they have been absolutely superb. |
02-25-2010, 05:19 PM | #35 |
Rep 9,034
Nice write-up.
So they recommended a shorter spring, but don't the front springs come loose as it is?
02-25-2010, 05:28 PM | #36 |
Rep 7,887
02-25-2010, 05:36 PM | #37 |
191
Rep 2,867
02-25-2010, 05:38 PM | #38 |
Rep 7,887
Yeah that is the range where the stock geometry still works like it was supposed to.I know that that on a lot of other cars strange things happen to handling when you go too low.
02-25-2010, 05:39 PM | #39 | |
191
Rep 2,867
One thing I dont get tho is all the adjustability in the rear. U can literally slam the rear more then coilovers. |
02-25-2010, 05:40 PM | #40 |
191
Rep 2,867
Yup, exactly. I would assume the lower u go the more bouncy it may be and not as good for performance altho having a lower cebter of gravity. Weird how it works. But I dont doubt that for the track, what I have now is the best setup.
02-25-2010, 06:00 PM | #41 |
Rep 1,198
only if you go airborne....
