DIY: How to setup BMW Standard Tools 2.12 w/Windows 10 x64 (64-bit)
02-04-2016, 01:57 PM | #23 | |
Ballin' out of control.
521
Rep 1,289
Thank you !! You're welcome.
In order to preserve English language localization to the greatest extent possible, this DIY utilizes the last English INPA scripts that the BMW Group released with INPA 5.0.2. INPA 5.0.2 did not include a script for the MEVD17.2 DME. That aside, all other functionality works as expected. There are later German language INPA scripts available for that DME. I will PM you details.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
02-13-2016, 09:30 PM | #24 |
19
Rep 61
This guide is great, I am giving it a try now after I get the slow chinese download done. I havent had luck with other tutorials although I am very familiar with the windows environment... I hope this works.
Current: 2017 BMW 340i F30 B58 BSM Black Dakota Leather, MPPSK, Active Autowerke Catted Downpipe, MHD STAGE 2
SOLD 3/6/21: 2009 BMW 335i MANUAL E92 N54 MHD STAGE 2+ |
02-14-2016, 01:25 PM | #25 |
19
Rep 61
When I go to identifcation in INPA I get IFH-0009: No response from controlunit
When trying to code injectors I get Error #100 SYS-0010: INITIALIZATION ERROR API job error or no such result These are the same errors I got with the other installations I tried... I'm starting to think my cable is not working but the clamps work???
02-14-2016, 02:05 PM | #26 | |
521
Rep 1,289
02-14-2016, 02:56 PM | #27 |
19
Rep 61
I ordered it from an ebay seller: autogadgets2015 it has a green circuit board and says K+DCAN. I have placed an order for the one stop electronics cable which is known to work. Hopefully its just a bad cable and my installation is fine?
02-14-2016, 03:18 PM | #28 |
521
Rep 1,289
Most likely. The one-stop-electronics.com cable will definately work properly. Once you receive your new cable, please report back.
02-15-2016, 07:35 PM | #29 |
¯\_(ツ)_/¯
170
Rep 425
This source is also pre-tested and worked for me with MHD/Carly/NCS
https://www.bimmerstuff.com/collecti...le-with-switch
30FF
02-20-2016, 10:06 PM | #30 |
Rep 1,602
02-21-2016, 02:52 PM | #31 |
521
Rep 1,289
DIY updated
A few updates...
Post #2 is now a BMW Standard Tools 2.12 FAQ: http://www.e90post.com/forums/showpo...48&postcount=2 I will continuously update the FAQ over time. Errata:
Code:
cd C:\EC-APPS\NFS\DATA\GDATEN copy INFO.GER INFO.ENG /v
02-24-2016, 07:51 AM | #32 |
Guest
Rep n/a
Drives:
hello, i am confused about inpa, bmw standard tools, ediabas and the whole thing. i just need to diagnose my car 335d e92 and possibly with the least hassle. and i want to know if i have to download all the software here or if i can only install standalone inpa for diagnostics, as i dont want to do any coding. can somebody point me the right direction please ? my car has many many issues and i am trying to spend the least.
last failures included: 1.broken flywheel (mechanical problem, and very noisy one and also very expensive one (800 euro) 2.drive belt pulley failure (couldnt turn steering wheel, and smell of rubber, 500 eur) 3.before i had numerous other problems, basically every month something... |
02-24-2016, 09:20 AM | #33 | |
521
Rep 1,289
02-25-2016, 03:58 PM | #34 |
19
Rep 61
I got my onestopelectronics cable and everything works now. I was able to code my injectors no problem. Thanks for the guide!
03-02-2016, 10:45 PM | #35 | |
521
Rep 1,289
03-08-2016, 08:36 AM | #37 |
707
Rep 2,450
Thanks for the info. In your post about identifying which daten you have, how do would I know it's v51? I do not see 51 anywhere in the data posted.
03-08-2016, 05:00 PM | #38 | ||
521
Rep 1,289
You can get a rough idea by reviewing an ISTA/P version and I-level overview chart to determine which ISTA/P version(s) align with the integration level of your SP Daten. The chart for ISTA/P P3.57.4 is attached. For example, if your SP Daten supports integration level "E89X-14-11-501" then you know it's SP Daten 54.3. However, if it supports integration level "E89X-15-03-500", it could be SP Daten 55.0, 55.1, or 55.2. In that case, there really isn't any way that I know of to easily narrow it down further. Beginning with the F-Series, BMW replaced the former KMM database with the CIS database. From the best that I can ascertain, unlike the KMM data, the CIS data is not contained within the SP Daten. Otherwise in the example above, we could have at least been able to distinguish between 55.0 and 55.1 by determining the F01 supported integration level.
03-08-2016, 05:06 PM | #39 | |
707
Rep 2,450
03-08-2016, 05:44 PM | #40 |
521
Rep 1,289
You're welcome! I'm glad to know that it helped you.
03-18-2016, 02:03 PM | #41 |
Rep 1
Hey guys!
I am a new member, I am from Bosnia so my English isn't very good. 808AWD325xi I have come to the point where you suggest to reinstall Windows. When I choose to reset windows in recovery tab it offers me two options: 1. Keep my files - Removes apps and settings, but keeps your personal files 2. Remove everything - Removes all of your personal files, apps, and settings. What should I choose? Thank you! |
03-18-2016, 02:34 PM | #42 | |
521
Rep 1,289
03-18-2016, 09:42 PM | #43 |
Rep 25
This has got to be the best DIY I have ever come across in my life. Not only was the DIY very comprehensive, but the OP was extremely helpful through PM. I was able to download and install despite being a total noob + hitting every obstacle along the way!
Thank you so much. Someone in OR get this man a beer! |
03-21-2016, 04:40 PM | #44 |
Bob Saget
356
Rep 2,229
OP, what is your opinion of the self installing program? http://www.e90post.com/forums/showthread.php?t=1233568
In memory of Robert E. Flynn (AR)
bmw standard tools, coding, diy, inpa, winkfp |
