BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Help! E90 LCI Halogen to Xenon
      08-31-2011, 08:00 AM   #23
uweric5985
uweric5985's Avatar
32
Drives: BMW E90 LCI 323i
2009 BMW 323i  [9.50]
I uploaded in zip format
Performance: K&N High Flow Air Filter | AA Tune Stage 2 | SuperSprint Quad Exhaust
Handling: KW V2 | AP Racing 5200 4 Pots Front Calipers with 330mm J-Hook Drilled Disc | Matt Black 19" Advan RZ-DF
Cosmetic: Gloss Black Roof | Gloss Black Front Grilles | M3 Style Trunk Spoiler | Performance Front | M-Tech Rear Bumper | M-Tech Steering Wheel
      08-31-2011, 08:21 AM   #24
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
Yea I know that. I unzipped it and still got nothing..here is what your files shows me:
"K
g?A" Š  FSW_PSW (NFRM).TRC=]“۸‘ϷUSbQ#(‹ * 8gW6ծ/_ H|5*›@/| *P#y?=$o~~zIxH*‚4nW&: ŒJQM.\H.c[*=qŸW-; _~‡…ˆs _>髲`A++^5p–+–=-C@‰k”@
*û1E;E*xY
Ui^Z•s$$~PPexf*"4e \U8$•!6|Ecpz ó}3l8`=”P4D*p„=•W,Q! E$EDZ’R#\F;]€f޷• 8m' UR•H–•U$bE]žaŒ5˜#k#P2T^‘~}1Vžp•\u` : ˜ZJJŽQ
T{gVJ#Iƒ›/’ kDœ œO9€?œ€lTP0 —?_?zS• 8:O.*|
٥@ˆ2*MLR‚V_MœvJ\i
*SƒB N%l4B}Xƒ€!9)[œ>j˸VOh^૲…uX${P‡’Q{& Q_~„1k<  *vݾ2$‹;‚œC%}ˆš]vŒhC0cas ! rV‰"
Copy the contents and save it as a text file and send it over again.
Thanks
      08-31-2011, 08:42 AM   #25
uweric5985
uweric5985's Avatar
32
Please see the attached file.
      08-31-2011, 09:56 PM   #26
DESI4life10
201
I will get back to you tomorrow.
      09-01-2011, 03:41 AM   #27
uweric5985
uweric5985's Avatar
32
Yea, please, looking forward for your help.
      09-01-2011, 08:03 AM   #28
DESI4life10
201
Try changing the following below to nicht_aktiv. This should be for your turn signal.
WARMUEBERWACHUNG_BLK_V
KALTUEBERWACHUNG_BLK_V
      09-01-2011, 08:12 AM   #29
DESI4life10
201
You should also disable the follwoing lines as you are getting the 9c series errors (self levelling for the xenon lights, which you don't have installed)
DYNAM_LWR_ENABLE
LWR_ANSTEUERN
AUTO_LWR_ENABLE
      09-01-2011, 10:16 AM   #30
uweric5985
uweric5985's Avatar
32
ok, I have done the coding but same errors still exist, am I missing something?
      09-01-2011, 01:05 PM   #31
DESI4life10
201
According to this site:
http://www.endtuning.com/ccidcodes.html
CC-ID 378 is Sidelight/Daytime Lights Defective- Left
Check to make sure all your lights are in working order? (left side)
-Angel eyes (no loose connection)
-Turn signal
-etc
      09-01-2011, 01:48 PM   #32
uweric5985
uweric5985's Avatar
32
AE works fine and will turn on when I lock/unlock the car.
Turn signal works normal, no hyperflash, etc.
The three little led works normally.
Low beam is fine.
However, high beam is not able to turn on. I remember before adding $522, high beam is able to flash and turn on.
After adding $522, high beam get sort of "linked" to low beam.
Which means that when I flash high beam (with low beam off), the low beam HID flash. If I flash high beam (with low beam on), nothing will happen.
Please see the video
      09-02-2011, 08:19 AM   #33
DESI4life10
201
Your NFRM file seems to be different from my file.
For the high beams, try this as it is similar to how I did it (I am not sure since it isn't the same)
PWM_FL_BEI_BIXENON
wert_02
wert_03
change to
PWM_FL_BEI_BIXENON
wert_01
wert_01
This will be a test. Did you tap the shutter to the high beam (halogen)?
      09-02-2011, 11:54 PM   #34
uweric5985
uweric5985's Avatar
32
PWM_FL_BEI_BIXENON
wert_02
wert_03
change to
PWM_FL_BEI_BIXENON
wert_01
wert_01
Wowow~!
This is working! High beam is now working perfectly!
Come on DESI4life10, shoot me some idea to cancel the error, I can do trial and error.
      09-03-2011, 06:58 AM   #35
DESI4life10
201
LOL...seems like it's just us two in the thread.
I will look into it some more and get back to you with suggestions :-)
      09-03-2011, 02:51 PM   #36
rayguy24
the mod bug is crawling in my brain
rayguy24's Avatar
Drives: e90 tiag aka "luna"
I'm in here too. Just reading your progress and waiting patiently for all my parts to arrive. Keep it up!
      09-03-2011, 11:54 PM   #37
DESI4life10
201
Thanks guys.
Didn't have time to look into this today. Hopefully I can get to it tomorrow.
      09-05-2011, 12:45 AM   #38
DESI4life10
201
In order to remove the error, we need to disable the cold/warm check for the bulb causing the problem (even though it's working fine).
Do you have any aftermarket lightning on the car?exterior and interior? Have you checked all the brake lights/parking lights in the back as well?
Looking in your text file, these are the following that are currently active for cold/warm checks. Up to you to disable them all to see if that fixes the error, or do it group by group. The first one is the easiest to correct, however you won't know for sure which one controls it (till you do it the 2nd way, which is longer but better)
Rear Fogs
WARMUEBERWACHUNG_NSL_L
aktiv
WARMUEBERWACHUNG_NSL_R
aktiv
KALTUEBERWACHUNG_NSL_L
aktiv
KALTUEBERWACHUNG_NSL_R
aktiv
Low Beam
WARMUEBERWACHUNG_AL
aktiv
Brakes Force Display
WARMUEBERWACHUNG_BFD
aktiv
KALTUEBERWACHUNG_BFD
aktiv
Brake light
WARMUEBERWACHUNG_BL
aktiv
KALTUEBERWACHUNG_BL
aktiv
WARMUEBERWACHUNG_RFS
aktiv
KALTUEBERWACHUNG_RFS
aktiv
      09-05-2011, 02:05 PM   #39
uweric5985
uweric5985's Avatar
32
Rear Fogs
aktiv
aktiv
aktiv
aktiv
Low Beam
WARMUEBERWACHUNG_AL
aktiv
aktiv
aktiv
Brake light
WARMUEBERWACHUNG_BL
aktiv
KALTUEBERWACHUNG_BL
aktiv
aktiv
aktiv
I have the Ultimate LED kit from bimmian which works fine before and after I swap my headlights.
I disable them group by group, and finally disable all of them but no luck, none of the groups can clear the error.
Should we focus on the corner signal LEDs since they are one of the main changes from Halogen to Xenon.
      09-10-2011, 11:16 PM   #40
DESI4life10
201
Yes we need to focus on the corner led, more specifically the left side.
CC-ID 378 is a defective side light and daytime driving light defective on the left side.
I haven't been able to work on this, been busy. Have you gotten anywhere with this?
      10-26-2011, 08:59 AM   #41
sqexpress
Drives: 2015 i3
Rear Fogs
aktiv
aktiv
aktiv
aktiv
Low Beam
WARMUEBERWACHUNG_AL
aktiv
aktiv
aktiv
Brake light
WARMUEBERWACHUNG_BL
aktiv
KALTUEBERWACHUNG_BL
aktiv
aktiv
aktiv
Is this problem solved?
      10-30-2011, 01:11 AM   #42
aaabbbyyy
20
Drives: E90-318
hi @uweric5985, have any progress?
      11-04-2011, 11:05 PM   #43
charles.soori
23
Drives: 2016 F85 x5m
hey how did you get you high beam to flash without turning the light? i just upgraded to lci Xenon and i could only flash/high beam if my low beams are on. Did you do any internal wiring? I just connected my pin 5 which is high beam to pin 6 that's the shutter on lci xenon. But i want to be able to flash my high beams without turning my low beams on.
Low beam is fine.
      02-11-2012, 07:55 PM   #44
pinopatty
Drives: BMW e90 2005
Hello, you solved your problem flash with hight beam? I made the change I have the same problem can you help me and tell me how you solved it.
thanks
