The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Ista-d_2.36_ista-p_2.5.40
      10-10-2013, 05:48 AM   #23
alexxx123
Drives: e87
Ok thanks. If you do not complicate, post here.
P.S. (In ISATA P which you distribute, writes "service_mode", therefore i asked about the "expert mode")
      10-12-2013, 03:43 PM   #24
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
Anyone tried setting this up and got the error stating "NO ICOM EMU USB KEY FOUND"? I'm trying with just the K+DCan Cable and ICOM emulater
Car is an 08 328 Could this be the issue where a real ICOM needed because of MOST Connection?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      10-12-2013, 04:42 PM   #25
DRock3d
Kraut Driver
DRock3d's Avatar
Drives: 2014 650i GC/2011 335is DCT
2014 650i Gran Coupe  [0.00]
2011 335is  [1.00]
2007 328i  [2.00]
I've tried searching and I can't seem to find a good answer. Can this be used for coding or is it more/only for diagnostic purposes?
      10-14-2013, 01:07 PM   #26
Sensible_
529
Drives: 2008 E90
This depends if you are using ICOM unit / OPS / DCAN CABLE + ICOM EMULATOR...
If you are using ICOM EMULATOR and DCAN Cable you can only VO Code not FA code.
      10-15-2013, 09:13 AM   #27
DRock3d
Kraut Driver
DRock3d's Avatar
2011 335is  [1.00]
2007 328i  [2.00]
So VO=factory options and FA=windows up with fob, ccc disclaimer etc?
      10-15-2013, 11:38 AM   #28
Sensible_
529
Drives: 2008 E90
Sorry I were that when I was really tired. FA and VO are the same. You can change the VO but need to use the IBAC Generator.
What you cannot do is FDL code. Apologies for confusion.
      10-24-2013, 06:39 PM   #29
nate5ks
Drives: 2006 BMW 330xi
I'm trying to use this with icom clone and I'm having a problem. Ista/d functions fine, it reads normal voltage on kl_30 but when I go to ista/p to program, terminal 30 shows 0.00v and it won't allow me to program. Has anyone seen this before? I've read where clones can have hardware issues but I don't understand why I would get good readings in ista/d but not ista/p.
      10-24-2013, 07:18 PM   #30
nate5ks
I'm using firmware 3.10.42 for ICOM found on one of the other forums.
      10-28-2013, 09:02 AM   #31
BMW..
Guest
n/a
Drives:
Awesome. Where can we get the USB dongle from?
      10-28-2013, 02:20 PM   #32
nate5ks
I have a few or you can use the snapshot method
      11-02-2013, 07:00 PM   #33
hamfei
Drives: 2012 E90
The only word I can say -- You are the Angel!!!
THANK YOU !!!!!
      11-02-2013, 08:37 PM   #34
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
Hey Sensible, how can I get this to work with ICOM Emulator and DCan cable?
      11-03-2013, 06:55 AM   #35
Sensible_
529
Drives: 2008 E90
Icom emu is built in.
      11-03-2013, 06:38 PM   #36
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
Sorry man I meant configuring the VM to work. (Farely noob)
      11-04-2013, 06:26 AM   #37
Sensible_
529
Drives: 2008 E90
Start VM with net adapter 2 (icom emu) NOT Connected.
Once fully loaded, turn on net adapter 2 and turn net adapter 1 off.
The above step is important as it loads the MAC address of the icom, before the emulator will work.
Then just run icom emulator from start menu and ifhsrv32.
      11-04-2013, 03:46 PM   #38
nymike
Drives: bmw e60
Hi,
Iam very new to this and want to start to learn. I downloaded the torrent and my chinese clone icom came today but somehow I can not get it to work. Anybody willing to help set this up ? Can offer few beers if needed
      11-04-2013, 08:21 PM   #39
BicLighter
Drives: '78 2002
I am sitting here with a certified BMW tech, if someone can help us connect our iCOM to this VM, we can answer questions on using the software in this VM.
How do I find the IP of my iCom to connect to this VM?
Let's help each other out.
      11-04-2013, 09:02 PM   #40
nymike
Drives: bmw e60
u using clone or real icom ?
      11-05-2013, 05:44 AM   #41
Sensible_
529
Drives: 2008 E90
For those using ICOM.
Make sure firmware is updated to same as ISID version in this case 3.1
Code:
 Generic ICOM Update Instructions:
1) Setup network adapter to DHCP mode for IP v4
2) Connect ICOM and power on
3) Check network adapter has IP starting like 169.254....
4) Try to ping 169.254.92.38 or use ipconfig in command prompt to find the IP
5) Using web browser go http://169.254.92.38:60080, L/P: root/NZY1150263
6) Select channels menu and make accure lock
7) Go to firmware update and update with ICOM-BootImage-01-11-01.bin, then with ICOM-ApplicationImage-01-15-01.bin, don't reboot between parts.
8) Reboot ICOM, check firmware versions for boot 1.11.01 and application for 1.15.01
Assuming its a clone
You need to register it. You can do it by editing some XML files:
They are in total 4 files you need to create and 1 you need to edit;
Create (XXXXXXX is the serial number) if not created. If already created - edit them with your ICOM serial.
1) p:\apps\wsm\apps\manager\data\DeviceInventory-ICOMXXXXXXX.xml
2) p:\apps\wsm\apps\manager\data\UnitRegistration-ICOMXXXXXXX.xml
3) p:\apps\wsm\apps\agent\data\DeviceInventory-ICOMXXXXXXX.xml
4) p:\apps\wsm\apps\agent\data\UnitRegistration-ICOMXXXXXXX.xml
Edit (just add your icom based on the other one)
1) p:\apps\wsm\apps\manager\data\PXEBootDevices.xml
Or maybe try ITOOLSRADAR attached - change txt to rar.
      11-05-2013, 07:48 AM   #42
nate5ks
Will firmware 3.10.42 work? This is what I am using and I still get 0v at terminal 30 so I can't program. Ista/d works fine.
      11-06-2013, 04:14 AM   #43
Sensible_
529
Drives: 2008 E90
It should work. Have you edited the xmls and what is the status of the icom in connection manager?
      11-06-2013, 07:28 PM   #44
rpoitras
Drives: 2006 330xi
Probably stupid question, but, is it correct that this will not work with K+DCAN cable if your vehicle has MOST or will it work anyway? Thought I read something about this and I have an X5 E70 w/ MOST but have coded and flashed via DCAN successfully using the old tools (winkfp, etc).
