06-16-2010, 01:10 PM | #23 |
Rep 4,167
More information on everyone please
Audi R8 v10 Ford Raptor m3e46freak@yahoo.comfor all euro parts!! ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum |
02-10-2011, 04:54 PM | #28 |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
Great overview,
some questions: - what is the use/relevance of the wheel rate as opposed to the spring rate? - I'm used to spring rates in SI (Systeme Internationale) and they are defined as force / distance: [Newton / meter, N/m]. With Lb being mass and not force, how do the mentioned rates mentioned here translate to SI-units? SI spring rate value = Imperial Spring Rate value *2.2046 (for Lbs-> Kg) *9.8 (for mass->force) * 0.0254 (for 1/inch -> 1/meter) any thoughts? - Is there any comparative info on the (minimum e/o maximum) damper rates of these systems available? Both SI or imperial values are welcomed? SI -unit is force * time / distance: [Newton * second / meter, Ns/m] |
03-10-2011, 12:46 AM | #29 |
Moderator
675
Rep 4,737
Late reply but here it is anyway.
Wheel rate is what the car actually experiences due to leverage. Just like a car jack, it is much easier (less force) to jack up the car when you have a longer handle. Same principle applies. lb here is pound-force. Just google xx inch per pound to newton per mm. |
08-04-2011, 07:08 PM | #30 |
Rep 439
So many to choose from. I am gathering if I want to retain my EDC functionality, springs are the way to go.... Or just say screw it, and get a nice set of COs......
08-14-2012, 10:49 AM | #31 |
45
Rep 345
Drives: Many BMW's & Porsche's
TC Kline Racing offers a Single Adjustable and a Double Adjustable suspension...
http://www.tcklineracing.com/webdocs...Details159.cfm |
09-20-2012, 09:08 AM | #32 |
47
Rep 283
Drives: M3
Garage List 2016 Mercedes c63s amg [0.00]
2013 Kawasaki Ninja ... [0.00] 2007 Yamaha R6 [0.00] 2014 Mercedes S500 [0.00] 2011 BMW X3 35i [0.00] 2012 Mercedes E63 AMG [0.00] 2006 Mercedes S500 [0.00] 2007 BMW 335i (E92) [0.00] 2011 BMW M3 [0.00] |
which one of these can be the same height as stock?
i would like the car to be able to be stock height when i leave my house then when i show up on track or at a meet i can lower it then. is there one that suits my needs?
now: 2008 335i (E92), 2011 M3 (E92), X3 35i (F25),2012 E63 AMG (W212), 2013 Kawasaki Ninja 250, 2007 Yamaha R6
gone:2009 GTR, 2007 335i (E93) 2004 M3 (HPF stg 3), 2008 Civic Lx, 2007 Z4M Roadster, 2001 Gembala GT550, 2007 CLS 55, 2007 STI, 2004 M3 |
11-01-2012, 03:59 PM | #33 | |
45
Rep 345
TC KLINE RACING E9X M3 S/A TRUE MATCH COILOVER SUSPENSION - With this kit, you can adjust rebound externally front and rear plus have the added benefits of ride height adjustability (up to two inches). The True Match System includes proprietary valved KONI single rebound adjustable shocks and our super trick VVS alloy springs. Unlike other coilover systems, our rebound adjusters and wide range of spring rates enable a true match to your driving needs and preferences. Encompassing both street comfort and track performance, this kit is unsurpassed in its class. This suspension kit includes the following components: (1) 8741-1484LSPTC - TC Kline/Koni Left Front Coilover Strut (1) 8741-1484RSPTC - TC Kline/Koni Right Front Coilover Strut (2) TCKFSXXX - TC Kline VVS Alloy Front Springs (2) 8241-1200Sport - TC Kline/Koni Rear externally adjustable shocks (2) TCKRSXXX.250.10 - TC Kline VVS Alloy Rear Springs (1) TCKRSA - TC Kline Rear Ride Height Adjusters (pair) (2) TCKE90RCR - Delrin Centering Ring for rear ride height adjuster (2) 12mm shock sleeves for upper mounts (1) E9X M3/1M Shock kit (2) Koni Spanner Wrenches (2) Koni Rebound Adjuster Knobs *Camber plates are not included with the kit but are highly encouraged to achieve less understeer. **We recommend 350#-400# front springs and 600# rear springs for daily driven cars. Please feel free to call us with questions at 614.771.7744 TCKR Smart Design D/A Coilover System Proven on the street and track, this system is unmatched by any other system on the market. TC Kline’s unique Smart Shock technology mated with our VVS alloy springs (see springs) make this ride height adjustable kit the most versatile available. Incorporating separate external compression and rebound adjusters, the shocks can be dialed from street comfort to a full race setup in minutes. These features combined with our complete selection of VVS alloy spring rates make this kit the uncompromising choice for both street comfort and track performance. The Smart Design System is perfect for driving school enthusiasts, autocrossers, club racers, and serious pro racers alike. This kit includes the following: (1) 8711-1125LSPTC - TC Kline Racing / Koni Left front strut (1) 8711-1125RSPTC - TC Kline Racing / Koni Right front strut (2) TCKFSXXX - Pair of front springs in your choice of spring rate (1) TCKE9XShockkit - Spacer sleeves for the Struts and Shocks (1) 8242-1009LSPTC - TC Kline Racing / Koni Left rear shock (1) 8242-1009RSPTC - TC Kline Racing / Koni Right rear shock (2) TCKRSXXX.250.10 - Pair of rear springs in your choice of spring rate (2) TCKE9XDCR - Delrin centering ring for rear height adjusters (1) TCKRSA - Rear ride height adjusters (2) Koni Spanner Wrenchs (2) Koni rebound adjuster knobs *Camber plates are not supplied with the kit. Camber plates are needed in order to use this suspension kit. *TC Kline Racing camber/caster plates are available for $495.00. Please feel free to call us with any questions at 614.771.7744 |
12-12-2012, 06:20 PM | #35 |
DHS
229
Rep 4,043
Drives: 2023 M4, 2020 Land Rover
This is actually incorrect. Its actually the exact opposite. Most can lower much more in the rear.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
05-13-2013, 01:00 PM | #38 |
octane chick
81
Rep 1,187
Drives: ex-M
Dinan Racing Coil-Over Suspension System (EDC & Non-EDC versions)
EDC: http://www.dinancars.com/shop/R190-9...-EDC-Only.aspx Non-EDC: http://www.dinancars.com/shop/R190-9...-EDC-Only.aspx $2,499.00
04-23-2014, 10:44 AM | #40 |
Rep 980
RZM3, I noticed you are missing the Nitron coilovers in this list. I picked up their 3-way adjustable a few months back and although its not yet installed on the car I can either send you the pics to upload or I can upload them in here myself? LMK!
04-28-2014, 04:45 AM | #41 |
Rep 5,950
Also, there are the following options:
JRZ RS1, RS, and RS Pro Ohlins R&T Motion Control Suspensions 1WNR, 2WNR, 2WRR Moton "Motorsport" 2-way remote reservoir Except for the Ohlins R&T, all other dampers use springs for your specific application (e.g., street-only, strret-track or track-only) |
05-28-2014, 02:49 PM | #42 |
Rep 149
Drives: M3 E92 with AA Stage 3 SC
I did't see the info about some of it that work with EDC without emulation or delete. That keep edc original.
05-28-2014, 04:47 PM | #43 |
99
Rep 2,991
Drives: 13E92 MCB M3 18 F80M3 Atlantis
I am still waiting on this.
| 2013 M3 Coupe | Individual Monte Carlo Blue || ESS VT2-625 Kit| KW Clubsports | OSS Headlights | HRE590RS | Brembo | BMW Performance Seats
| Dinan Strut Tower | Dinan Midpipe | Akra Slip-on | Valentine 1 Built-in Radar Detector |
07-02-2014, 11:25 AM | #44 |
N54 Tuner
Rep 160
Great post thanks! What options are there for good coils under the $2k mark?
