08-27-2020, 12:23 PM | #23 |
181
Rep 252
Drives: 2017 Model S P100D
I have their catless, I picked up from them in person andthey said they had one in the works but they didn't have a timeline for it when I bought. Would have chosen this one for sure.
Subb'd for a sound clip, will probably buy and remove the vibrant resonator I put in to tame the full straight pipe |
09-06-2020, 01:49 AM | #25 | |
84
Rep 124
compare that to active autowerke, they state exactly what kind of cat they use and the specifications. anyways i bit the bullet and ordered the cts turbo one. hopefully it arrives soon. |
alohasurftoad3132.00 |
09-06-2020, 12:31 PM | #26 | |
Rep 4,210
Do we have any data in longevity, flow or emissions reductions? |
09-06-2020, 06:04 PM | #27 | |
84
Rep 124
just the assumption that you get what you pay for. when i install mine ill do a write up and give some feedback on fitment, sound, smell and butt dyno. |
09-07-2020, 01:31 PM | #28 | |
Rep 7,630
For flow, it stands to reason that the lower cell cats will allow more flow, although that's certainly not the only factor. Another major consideration is the actual diameter of the DP where the cap is located - some but not all significantly increase the DP diameter where the cat is located so there's more cross sectional area for flow (since the cat itself is taking up some of that by obstructing the flow). After all, the cat density is where most of the flow/power gains over stock are, right? For emissions, not aware of any F3x that are undergoing the sniffer emissions test but in terms of the car's own cat monitors some throw and CEL and show emissions ready and others do not... so there is certainly some difference there. |
09-07-2020, 08:23 PM | #29 |
Rep 1,125
Drives: 2015 BMW 435i Xdrive MSport
Fabspeed and AA use HJS racing cats. I met the owner of Fabspeed at a car show back in July and he explained to me that cat technology has come very far. He also said anything sub 1000 dollars for cats are most likely garbage. HJS is the leading performance cat provider in the world. I plan on doing the Fabspeed cat once my warranty runs out.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
09-07-2020, 09:18 PM | #30 |
Rep 445
In short, you shouldn't be buying this if you are trying to avoid a CEL. This is mainly for people who want the least possible restriction without having to go full catless so they can avoid some level of smell. This one also has the support bracket which the VRSF option does not have, which I personally would much prefer.
-Fitment -Smell That's really all that's needed to know at this point.... |
09-07-2020, 11:31 PM | #31 | |
Rep 4,210
09-08-2020, 05:57 AM | #32 | ||
Rep 1,125
09-08-2020, 09:23 AM | #33 | |||
Rep 1,934
In any case, removing any of those hydrocarbons is better than catless.
09-08-2020, 10:32 AM | #34 | |
Rep 7,630
Anyways, this discussion always ends up going in circles because theres no back to back quantitative testing of aftermarket catted DPs. There is obviously a difference between the cats and overall design in say VRSF vs fabspeed, but what that means for longevity/performance/emissions is not quantified. So, you generally just make your purchase decision based on whether or not you want the no CEL guarantee and/or emissions compliance. Back on topic, still interested for the CTS impressions after install and test drive/logs. |
09-08-2020, 02:43 PM | #35 | ||||
Rep 1,125
09-08-2020, 03:10 PM | #36 |
Rep 27
I thought I'd decloak and mention my AA downpipe is tripping my CEL, but it's doing it intermittently ("180001 - Catalytic converter: Efficiency below limit value"). It's been installed for about a month. It's very intermittent -- the first time I hoped it was a one-off, but about every week and a half or so, it pops up again. This is with Shell, and Sunoco, 93 oct. Given the no-CEL guarantee I'm paying for with the AA dp, I think if it comes on again, I'll spend a few hundred more and get the Fabspeed.
09-09-2020, 04:33 PM | #37 |
10
Rep 35
If the quality is the same for all CTS turbo product I would stay away from their DP, I have their charge pipe and I was really disapointed by the quality(it was leaking badly from the 4 possible place it could leak) and the constumer service isnt better.
I hope for you that the DP will fit in place without major issu. |
09-10-2020, 10:13 AM | #38 |
Rep 21
Im using the CTS charge pipe on my 16 435i with no issues thus far that I'm aware of. Was a tight fit on my X-Drive. I cant say anything about customer service since I have not dealt with them.
Mostly, I went with CTS as they are somewhat local to me if I needed any help. I'm not saying your wrong. I just wanted to throw my experience out there as well. I do hope to put their DP in my car next year possibly. So I do hope there are no quality issues. Last edited by TurboCanadian; 09-12-2020 at 10:26 AM.. |
alohasurftoad3132.00 beeyar16.00 |
09-13-2020, 08:14 PM | #39 |
Rep 445
I'll probably grab this one and install it after I'm allowed to get my car inspected(stock DP) in advance of my yearly registration, I think it's in a few weeks. Even if it's not needed, I really do like the mounting bracket this one has.
kitchener2.00 |
09-15-2020, 05:18 PM | #41 |
84
Rep 124
ive never done any logs on my car before. im on bm3 stage 1 at the moment with all stock hardware.
would doing some before and after logs provide any useful info? |
09-15-2020, 07:15 PM | #42 | |
Rep 7,630
https://f30.bimmerpost.com/forums/sh....php?t=1732327 https://f30.bimmerpost.com/forums/sh....php?t=1710794 |
09-15-2020, 10:29 PM | #43 | |
84
Rep 124
redline in 4th is crazy fast, would a 3rd gear + half of 4th provide a decent log? |
