Instrument Cluster Swap Question
02-08-2016, 04:50 AM | #23 |
24
Rep 355
Again, sorry, no.
To get to the circuit board, the dial face has to be removed, means removing the needles.. It is easy to calibrate them later.. Just make sure you remove them carefully.. To calibrate, Fire up INPA, go to Kassorie-> Instrument Cluster.. And F6 activate. Enter 0 for set speedo, and set it to 0.. You should be fine.
In Progress: Surround View Retrofit 8TH |
02-17-2016, 01:15 AM | #25 |
Terorist!
29
Rep 315
Hello.....a few month ago I changed my standard cluster on a 320d with HIGH cluster.see picture
ok....I changed the orange led with white (home made), but to change eeprom was necessary to pay someone. I never programmed an eeprom, and I have no ideas about that....I purchased an MiniPro TL866CS. I know I have to modify VIN and mileage in eeprom, but I have no idea what I have to change. Can anyone explain more detailied about that procedure? Thank you
E90/320d/163cp/2007/black/retofit LCI front/rear/Mtech/style 162/M3 mirrors/auto dimming mirrors int-ext/EIBACH PRO KIT/M3spoiler/Performance Kidney Grills/MT/shadow line/M shift knop/M3 steering wheel cover/M footrest/M door sills/M handbrake/Performance aluminium pedal pads/sunroof
___________(Oo) (|||) o (|||) (oO)____________ |
02-17-2016, 04:02 AM | #27 |
24
Rep 355
http://www.bimmerfest.com/forums/sho...d.php?t=666729 I just posted it in the last page..
02-17-2016, 05:14 AM | #28 | |
Terorist!
29
Rep 315
10-24-2016, 08:41 AM | #29 | |
Rep 135
thankyou for your precious information on writing eeprom using a programmer. just want to confirm if a chip can be read or written without desoldering? if i use the clip on the chip with the board the power should be supplied to other chips as well. do you know any impact on writing or reading? it should not be a big deal? i really want to do the programming with what you suggested as the soldering may lead to other risks. thanks//sono Last edited by sono0312; 10-24-2016 at 08:51 AM.. |
10-24-2016, 07:37 PM | #30 | ||
529
Rep 2,503
sono031212.00 |
10-24-2016, 10:33 PM | #31 |
BimECU
193
Rep 759
btw had problem with e60 cluster with my R270
it reads and erases V6 fine but on E60 (M35080 6) freezes on reading 33/1024 :/ |
11-05-2016, 09:31 PM | #32 | |
Rep 135
when it comes to a used instrument cluster, what we need is erase both milage and vin in order to make it virgin. by using r270+, i learned that oddometer can be erased by using tool function (read/write by seletcting proper eeprom). however what does it need to be done for vin? some thread says that datum in dump list, line 0x002e0 have to be changed to FF... i am just wondering if vin can be changed as ussual by usng tool like winkfp? |
11-05-2016, 11:08 PM | #33 | ||
529
Rep 2,503
11-07-2016, 04:14 PM | #34 | |
Rep 135
I hope r270+ will erase both vin (all to "ff") and odo (all to "00") by one-click button. Is it correct? Or i need to change them one-by-one? |
11-07-2016, 04:16 PM | #35 | ||
529
Rep 2,503
Instead you may need to read the complete eeprom. Modify with hex editor then write back eeprom... |
11-07-2016, 07:10 PM | #36 | |
Rep 135
i found where to change from other threads. all i need is change hex data as follows... are these correct? odo: change all "00" from 0x00000 to 0x0001F vin: change all "ff" from 0x002e9 to 0x002ef those may applicable only to e9x 3 series. |
11-09-2016, 11:16 PM | #38 | ||
529
Rep 2,503
Also, of after changing mileage to all 00 bytes mileage is not 0, change byte at 0x2D7 to 00 also. Always test before plugging into car by connecting 12v +/- power to pin 9 and 18. Then press odo button on KOMBI to display mileage. |
DaZuc202.00 |
01-09-2017, 06:47 PM | #39 |
Rep 1,191
01-09-2017, 10:59 PM | #40 | |
529
Rep 2,503
All I know is that if that byte is not 00, odo reading will not be 0. |
01-10-2017, 05:39 AM | #41 | |
Rep 1,191
I think my original EEprom read was corrupted. I replaced it with a new one, fixed my xbox and wrote FF to Vin plus the 00 to 0x2D7. However, I'm getting the coding error and it would not accept a VIN upload or coding uploads. Strange though: Nettodata write and Ediabas c_c_schreiben works. Do you have a good EEprom read by any chance that I can transfer into mine? |
01-10-2017, 04:41 PM | #42 | ||
529
Rep 2,503
https://drive.google.com/open?id=0B0...0RzaHRHbnJRa2c |
Mik325tds806.50 |
01-10-2017, 05:36 PM | #43 |
Rep 775
01-10-2017, 10:08 PM | #44 |
BimECU
193
Rep 759
it should be same, and it would save lots of hassle with this needles,
I'm always afraid to break them plus my programmer(VVDI PROG) does not like working with clip, need to desolder/solder all the time but dont you have to remove needles to get to processor anyways? |
