01-06-2020, 04:11 AM | #23 |
No 55mph
1623
Rep 8,479
Forgive me for asking what may be a totally stupid question (I am just now moving to BM3 over my AA Flash tune & have not received all I need yet):
When a new version tune is released, is/are all the old versions of the tune still available to revert back to in case something with the new tune does not play well with my car?
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
n55david1306.00 |
01-06-2020, 06:20 AM | #24 |
Rep 6
Any tune you've 'purchased' in the past is still available under your account. You get one credit to choose a tune with a brand new license. Updates to tunes you already own are free.
01-06-2020, 06:30 AM | #25 | |
No 55mph
1623
Rep 8,479
So from this I gather this also apply to the tunes located under the optional 'Bundle' pkg?
01-06-2020, 07:52 AM | #27 | |
Rep 1,499
The old version will not be available in the OTS maps section but any version you have downloaded to your My Maps section will be available as long as you don't delete them.
Review of v7.0: So I haven't had the opportunity to log yet (hoping to do that over my lunch break) and all of my driving since I flashed has been during my commute so with a lot of traffic but initial impressions are very good. I did get to hammer it a couple of times and acceleration seems to be extremely smooth and you can really feel the added torque in the lower RPMs. I haven't noticed the "flat" spot between 2800-2900 RPM as some others had reported. I really like this map over v6.4. Quote:
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids Last edited by JaredG_F30; 01-06-2020 at 08:05 AM.. |
01-06-2020, 07:56 AM | #28 |
Gettin It Figured Out
1823
Rep 2,669
01-06-2020, 01:10 PM | #30 |
Rep 1,499
So I got a chance to log Stage 2 v7.0 93octane with and without spraying meth. The logs are below. I've also provided a link of an older v6.3 Stage 2 93 octane log for comparison. Unfortunately, all of my v6.4 logs are on the E30 map so I didn't include that.
Comments: - v7.0 boost increase is significant over v6.3 (from 15.8 on v6.3 to 17.2 on v7.0) - With that said I'm not sure why I'm seeing boost quickly ramp up to 19.2PSI (not a boost spike) and ramp down to 15.8PSI. I believe the boost target is changing through the RPM band but for whatever reason, it's not being reflected in the boost target value in the log. - Timing on cylinder 1 looks good on v7.0 when compared to v6.3 but I need to re-log with all cylinder timing parameters being logged. I forgot to change the logging parameters from a time when I was trying to diagnose some hesitation which I thought could be misfiring related (turned out I just need to reset the throttle adaptations). - The logged RPM value tops out at 5700 RPM even though I know I logged up to 6800 RPM. You can see my speed increased even after the RPM stops at 5700 RPM. I'll probably reach out to PTF of this as I've never had this problem when logging before. - For the v7.0 log with WMI I had to avoid an obstacle so I didn't floor the throttle right away but I was still able to capture a pretty good log. Stage 2 v7.0 93 octane http://www.bootmod3.net/log?id=5e136b17c090c66aa3637238 Stage 2 v7.0 93 octane with WMI http://www.bootmod3.net/log?id=5e136b48c090c66aa363723a Stage 2 v6.3 93 octane http://www.bootmod3.net/log?id=5d0cca0eae729b66bd2152d0 Overall the tune is very smooth and increased torque in the lower RPM band is noticeable. I'm looking forward to throwing in some E85 and flashing the E30 Stage 2 tune to see how that logs. Previously I've seen my timing advance got from the 6-8 range to 10-12 degrees which adds a nice punch.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
designatedposter175.00 |
01-07-2020, 10:01 AM | #31 |
181
Rep 252
Drives: 2017 Model S P100D
My butt-dyno says torque has seen a pretty substantial improvement which is great!
Has anyone been noticing small pops on downshift? (I'm 6MT) I've noticed that even in comfort that when I'm cycling gears it sounds like I get some loud burbles every here and there but I'm well below my RPM limit I set up for burbles (2500RPM). I've also noticed that burbles are inconsistent until the car has been fully heated but this issue was present with V6.4 as well as far as I can tell. When it is heating up and I go over my RPM settings for burbles, I might get one or 2 extremely loud pops that are spaced like 0.75s apart, but when the car has heated up fully that's when it gets the higher frequency crackles which is what I'm assuming it is supposed to be.... Other than that this update has been a definitely noticeable bump in power! |
01-07-2020, 08:47 PM | #32 |
Rep 928
Are there any plans to offer a stage 2 93 for the new fx-150 pump from Spool performance? There's gonna be a lot of them hitting the streets? Or is the factory pump sufficient for the factory turbo?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
01-07-2020, 09:11 PM | #33 | |
Rep 7,634
You can squeeze more power out of the factory turbo (compated to OTS maps) with a upgraded HPFP and custom ethanol blend tune. Several examples of that. |
01-08-2020, 07:02 AM | #34 |
Rep 1,499
I've been able to run an E29 mix (4gals of E85 and 11.9 of 93 octane) pretty consistently without my HPFP crashing. Stock HPFP and stock turbo. I'm actually about to switch of the to the v7.0 Stage 2 E30 map today and give that a shot. The added torque of v7.0 just on Stage 2 93 octane has been a blast to drive so looking forward to the added punch from the E30 map.
01-08-2020, 07:27 AM | #35 | |
Rep 288
01-08-2020, 10:33 AM | #36 |
Rep 928
I'm gonna go bm3 s2 and have a question about ethanol. There is e85 30 miles away so would like to take advantage. Where are the mix ratios for mixing with 91? If I did say a mix to like e40 and got a custom tune would I always have to run that same mix or if I fill with 91 would the car adjust? Or do you need to switch tunes just to go back to 91? Can you store different tunes and switch between them with the wifi agent very easily? If I bought bm3 s2 v7 91 octane then bought a custom tune tune for the e40 blend would I have both tunes stored in the cloud and be-able to go back and forth with the wifi agent? Thanks
01-08-2020, 11:02 AM | #37 | |
Rep 7,634
I am yet to try ethanol mix maps, planning to do that soon after i get my new tires installed. I have E85 right around the corner from me. It's pearson fuels, so its supposed to be consistently 83.3%, but i will probably do my own test before i start mixing. |
01-08-2020, 11:07 AM | #38 | |
Rep 7,634
2. Closed loop fueling will do some adjustments as needed but you would not really want to run a tune designed for say E30 and put in pump 91... there would probably be way too much timing and fuel and that is not an idea situation, even if the DME can work to compensate. You would want to flash back to a 91 tune. 3. Yes you can store tunes and yes you can easily flash between them. That should hold true for flashing between a custom Exx map and a OTS tune, so long as you keep both on your device (or cloud or whatever for BM3). E40 is probably going to be too much for stock fueling, but everyones car responds a little different. Note that in general lower IATs mean you can run less ethanol (more air demanding more fuel) - mostly noticeable in sub 50 F temperatures. |
01-08-2020, 11:47 AM | #39 | ||
Rep 928
01-08-2020, 12:51 PM | #40 | |
Rep 7,634
One other thing to keep in mind is the limit of the LPFP if you want to do to high ethanol content. Personally not exactly sure how far people have pushed it with an upgraded HPFP. |
01-08-2020, 01:03 PM | #41 |
Rep 1,499
So as much fun as v7.0 is to drive with the added torque, the boost spikes, HPFP crashes and throttle closures when logging concerns me on stage 2 E30 map. Maybe I just have too much ethanol for my HPFP to handle. I'm going to run this tank down to 3/4 then fill up with 3.5gals of 93 octane to bring me down to a E25 mix and see how that goes. I've reported this to PTF and asked for review of the logs. I'm curious to what they say.
http://www.bootmod3.net/log?id=5e161aa5ae729b0471ba6d9e
01-08-2020, 01:10 PM | #42 | |||
Rep 4,218
With that said, I get around 28-30mpg all highway - low 20s city - AND I'm tuned. If you're getting 20mpg mixed, the E85 tradeoff just doesn't seem worth it for a daily.
Mods: Yes.
01-08-2020, 01:54 PM | #43 |
15
Rep 100
Hey, I was looking at getting a stage 1 93 octane bootmod3 for my 16' 435i xDrive. Do you know what numbers I could possibly make? I couldn't find any dynos online.
01-08-2020, 02:46 PM | #44 | |
Rep 525
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
