Poll: Do you like meaty tires?
View Poll Results: Do you accept the looks of meaty tires? | |||
Yes | 126 | 90.65% | |
No | 13 | 9.35% | |
Voters: 139. You may not vote on this poll |
04-20-2017, 07:11 AM | #23 |
Rep 1,192
Drives: 2009 BMW 328i Wagon
04-20-2017, 07:20 AM | #24 |
Rep 5,443
Drives: Beige G31 40ix m sport
The word is tyres, that's TYRES not tires.
04-20-2017, 07:33 AM | #25 |
Rep 1,192
04-20-2017, 11:18 AM | #27 |
1208
Rep 2,835
04-20-2017, 02:11 PM | #28 |
Rep 1,192
Here's a pic of the 161s and 245-45-17s. Please excuse the bad picture...
04-21-2017, 07:41 AM | #29 | |
1208
Rep 2,835
But I'll probably switch to the Continental Pure Contacts. I have those on my 16" rims now and they are a great long distance road tire. |
04-22-2017, 04:25 AM | #31 |
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
It's hard to get it right.
I like the look of rear tyres on the new Dodge Demon. And I like the meaty tyres on the Volk racing rims. But as for all the others, not that much Here's a video of a Mini that looks OK: |
10-15-2017, 11:01 AM | #33 |
9
Rep 63
Personal opinion, I like it.
I do think the whole stretched tire on rim with excessive camber just to fit under the fender so my car looks cool trend is rather dumb. As in a, "let's totally f up the suspension geometry, ride, and handling charecterics, so my car looks like a cartoon" kinda dumb. |
10-15-2017, 03:56 PM | #35 |
2218
Rep 2,382
AG 359M's with Pilot super sports 235/35f, 275/30r
It was mentioned in a post above that it is important to have your tire and wheel width similar. Square sidewalls look more "meaty" than stretched. View post on imgur.com View post on imgur.com
BSM ///M2cs, 6spd
10-16-2017, 09:14 AM | #36 |
Guest
Rep n/a
Drives:
Agreed. Pics of the car you posted appear much too stretched...not a good look.
10-16-2017, 09:25 AM | #37 | |
30
Rep 130
1) both those cars are wider running wider wheels. 2) both have clearance for meaty tires m3 is obviously running 18x10 +25 fitment the black WTCC widebody is running the same if not wider with an even lower offset. the hardsport widebody is similar other than its not molded and they are running 18x11 +0 and claims to still have room to play with. |
10-16-2017, 10:01 AM | #38 |
Rep 3,339
Meaty tires... who needs those??
We're running 295 rears with the Hard Motorsports Leichtbau WB (below) z3Ro with proper offset and some pretty extensive tweaking to the Hard kit, you can likely fit a 315/325 rear. The limitation for anyone wanting to fit some real meat on the e90 comes from the front. Beyond the fender rub issue which can be corrected with a widebody, there is a firewall limitation if you're wanting to run any real width upfront (265 or wider). Here's a breakdown on max tire widths for the FRONT for an e90 (assuming correct offset): 245 or under: No modifications needed 255: Possible fender roll (depending on suspension setup/drop) 265 - 285: Widebody/cut fenders + cut out firewall seam weld 295+: Widebody + extensive modification to firewall ^^^ When running a 265 or higher tire, you may will either need to add a spacer or run a lower offset wheel, thus pushing the wheel outward and increasing the radius of the outer part of the wheel. This increased radius pushes the outer part of the wheel beyond OE spec and into parts of the firewall when wheel is turned. Last edited by sirdaft1; 10-16-2017 at 11:26 AM.. |
10-16-2017, 11:55 AM | #40 | |
Guest
Rep n/a
Drives:
Further, there's a guy running 275/40/17 r-comps on an E92 w/ the only modification being -3* of camber up front. |
10-16-2017, 11:56 AM | #41 |
30
Rep 130
03-24-2020, 01:53 AM | #42 |
Rep 780
Drives: 2009 BMW 328i, Honda Civic Hat
03-24-2020, 09:31 AM | #43 |
eBay Special
3122
Rep 3,042
Drives: E90 330xi
I don't think he's going to respond.. He hasn't been on here in 3 years
Common sense is a flower that does not bloom in everyone's garden
03-24-2020, 09:35 AM | #44 |
Rep 780
