N54 intermittent metallic ticking sound on idle
01-18-2016, 05:49 PM | #23 |
DOPE
148
Rep 758
Same thing here. I actually brought my car into the dealer today for this, they said it was injectors.
I know it's not injector noise and I would get the same noise as you in the beginning of the vid. Typically after a decent drive and being warmed up. Looks like it's gonna be turbo solenoids. |
01-18-2016, 06:32 PM | #24 |
Rep 32
Thanks for the info guys.
Did the sound permanently stop after you hit it a few times? Or would I still need to replace the parts. Also, how serious is this problem? Something I need to resolve quickly? |
01-18-2016, 06:35 PM | #25 | |
538
Rep 2,084
The tapping didn't come back, but I did not put many miles on it before swapping the solenoids. I would not trust it to be a permanent fix.
2013 135is DCT Carbon Black Metallic |
02-01-2016, 09:22 AM | #26 |
Rep 1,909
I've had it for 2 yrs now, did everything from intake walnut blasting to thicker oil, solenoid swap etc ... the only think that kinda works is if you run the car at higher RPM for 30 mins or so it settle it down for a week or so ... Also I observed it doesn't do it in winters (I haven't heard it all jan here in chicago) so I bet you its heat related, I also run with under shield removed and no engine acoustic cover ... engine oil temp these days is under 200 and didn't hear a single tick
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
02-01-2016, 10:40 AM | #27 |
Rep 15
My car makes the same noise and I only hear it through drive throughs. After some research I'm pretty sure it's the fuel evap line that connects to the throttle body. But the noise really doesn't bother me much so i haven't paid for the $70 to see if it was actually the problem.
03-08-2016, 11:40 PM | #28 |
Rep 749
Drives: 335i xDrive
Recently started getting which I believe is the same noise.
I believe it may be an issue with a pulley. Goes away, and comes back randomly. I cannot reproduce the noise. I think its a pulley by the sound of it and also because I have the oil filter housing seeping oil. Check out the video let me know what you think the sound only happens for the first :03 seconds of the video. |
03-09-2016, 12:19 PM | #29 | |
538
Rep 2,084
=C=68.50 |
03-09-2016, 07:17 PM | #31 | |
94
Rep 233
03-14-2016, 09:17 AM | #32 |
14
Rep 107
Drives: 10' 135i AW fbo mhd2+ - rip
i heard this for the 1st time last night and it scared the shit outta me.. boost solenoid sounds about right. i say this because upon dropping my hood, the sound stopped immediately - which would be the same as tapping the solenoid with a screwdriver.. im convinced this is the issue now after reading this.. (i agree it sounds deadly though)
edit: 111k on the clock btw just for ref. |
03-14-2016, 02:50 PM | #33 |
66
Rep 246
Would boost silinoids effect drive ability? Mine tends to boost then not then kick in hard. I have had this sound for a long time, along with these driving Simpsons.
03-14-2016, 03:19 PM | #34 |
48
Rep 374
Theres a thread about this around here somewhere. It has to do with the lifter assembly having air in there and not being properly lubricated. When the engine is up to temp and the oil is then at its thinnest, it is hard to keep it up on top of the lifter assembly at idle RPMs. This is why with one quick jump in RPMs the noise will go away then after a little delay come back again but only after the car is warm.
http://www.quirkyuncle.com/2013/04/1...w-lifter-tick/ |
03-14-2016, 04:04 PM | #36 | |
14
Rep 107
03-26-2016, 07:48 PM | #37 | ||
Rep 749
Drives: 335i xDrive
n54, tick, ticking |
