02-17-2016, 08:33 PM | #23 | |
1099
Rep 2,286
Like others in this thread - I've had cross-drilled rotors on other cars and never had this problem - and I also bedded the pads exactly as the owner's manual said for the first 300+ miles - but still get that vibration through the steering wheel... Any further suggestions, theories or advice are welcome! |
02-17-2016, 09:02 PM | #24 | |
Rep 626
02-18-2016, 06:24 PM | #25 | ||
1099
Rep 2,286
02-18-2016, 06:26 PM | #26 |
1099
Rep 2,286
I should also add that I previously had a 4,150 lb. E93 - which supposedly had less capable brakes and 500 lbs. more weight to bring to a stop vs.my F8x - yet not once in 80,000 miles did I have this issue with my E93...
02-19-2016, 08:32 PM | #27 |
Rep 626
02-21-2016, 09:08 AM | #29 |
17
Rep 33
Took my car in for groaning brakes. Dealer said everything is OK. It is not. I think the only soloution is to go aftermarket pads with higher heat capacity. Tech confirmed a new car on the lot did it too.
02-21-2016, 04:56 PM | #30 | |
1099
Rep 2,286
02-22-2016, 01:27 AM | #31 | |
Rep 626
What pads do you recommend? |
02-22-2016, 07:45 AM | #32 |
1099
Rep 2,286
[QUOTE=hdubf80;19435371]Please let me know what they say... If you figure out the solution ill have to send you a gift basket or something. Shit is driving me insane...
So - I took my car out for a drive late last night (no traffic out). I did some fairly aggressive stops, first from 40mph down to about 15-20 mph (never coming to complete stop), then some from about 60-65 mph down to about 35-40 mph. The amount of force I used was not quite enough to trigger the ABS - so imagine almost maximum decelerative force short of ABS. I would do maybe 2-3 such stops in fairly short succession, then let the brakes cool for a few minutes (while driving at about 40-60 mph in 35 F weather). I noticed that the brakes got smoother as the drive went on. Now granted, there is still some "groan" sound, and still just a little bit of vibration above 40 mph, but in some instances, it was much lighter than before, and in a few instances, barely even noticeable (whereas on Saturday, it was vibrating so much in the steering wheel and brake pedal I thought I was driving a jackhammer)!! So - I elected not to go through the time-consuming venture of going to the dealership (about 25-30 minutes from home, and not on the way to work), taking the time to go back and exchange the loaner for my car, etc. etc. What I am going to do is see how the car does in the next few weeks - I starting to think that what may have happened in my case (and possibly others' cases as well, including yours) is one or both of the following: 1) somehow I got pad deposit unevenly distributed on the rotors; and/or 2) I needed to "burn off" the pad deposit by being more aggressive and applying more brake pedal force when decelerating. It is still too early to know if either 1) or 2) were in play, but last night's results were somewhat encouraging. Will keep you posted on this thread. You may want to try something similar to what I did last night and see if you notice an improvement. |
02-22-2016, 08:52 AM | #33 | |
278
Rep 221
Drives: 2016 F80 SS/BK DCT
[QUOTE=Powerslide;19436211]
02-22-2016, 11:51 AM | #35 | ||
1099
Rep 2,286
[QUOTE=bradleym]
Also never had this problem on my E93 - 80,000 miles on that one!! |
02-22-2016, 12:00 PM | #36 |
Rep 859
Drives: 2017 Alfa Giulia Quadrifoglio
02-27-2016, 04:10 PM | #37 | |
1099
Rep 2,286
Tried to do same thing as in my quoted post above again this afternoon - and brake judder still bad...especially while decelerating below 50-60 mph and above 40 mph... I think I'm going to have to take the car in again - this is so massively frustrating. I've never had a car that brake judders like this one - despite breaking in the brakes per the owner's manual and being careful not to leave the brake pedal pushed down at a stop when the brakes are at higher temps. |
02-27-2016, 04:51 PM | #38 | |
Rep 626
[QUOTE=Powerslide;19471732]
02-27-2016, 05:33 PM | #39 | |
1099
Rep 2,286
[QUOTE=hdubf80;19471896]
02-28-2016, 07:22 AM | #40 |
Rep 842
Argh...sorry you guys are going through this hassle!
Normally under daily driving situations, you would not be getting the pads hot enough to make a major deposit on the disc (unless the OE pads has a seriously low max operating temp...which I doubt). If you went out on country roads/canyons and were blasting around, it would be very easy to get the pads hot enough to stick to the disc. There's no reason to believe a car wash would have any impact on brake performance. When they get wet your discs will form a little surface rust, but that is swept off as soon as you apply your brakes the first time. The fact that Powerslide's issues abated after getting hard on the brakes a bit leads me to believe that it is indeed an issue with the interface of the pad and disc. Chasing uneven pad deposits can be a royal pain for sure. Have you guys ever seen my video on swapping between street and track pads? Scroll down on that page to see it. The easiest way to scrub discs is with aggressive racing pads. They have a higher mu, and when cold, they can clean up a disc face rather quickly. Has anyone with this groaning noise down a proper full pad/disc bed-in? By proper I don't mean a few hard stops scrubbing a span of 15-20mph. I'm talking about blasting them hard enough to get the pads actually smoking. To do that you need to go from 60mph+ down to 5mph. If you don't you won't get enough heat into the pads to make them stick to the discs. Please see my video in the link above on that topic...braking repeatedly hard enough to really get the pads seated on the discs, and get a solid amount of material transferred onto the disc face. If the pads and discs aren't bed-in, you're going to have more noise, chatter, etc. of the pad on the drill holes or slots, and also more potential groaning of the pad on the iron disc face. Think of it this way...the pad and disc are two different hunks of differing metal. You're rubbing them together. When you do that, you're going to get some noise. The surfaces of those two items are going to be imperfectly mated, since each has its own irregularities. The bedding process is used to mate those surfaces together and eliminate those irregularities, and that is done through force and heat. Again, as long as the caliper bolts holding it to the spindle are tight, and the disc is running centered in the caliper, there's not a lot other potential culprits other than the pad and disc interface. As for disc noise with drill holes and slots...that is a valid possibility. It doesn't happen on all cars, but we do see it on some. In the hierarchy of noise, from quietest to noisiest would be plain face, straight slot, J Hook Slot, Drill holes. The noise you get from holes or slots is typically not a groaning...it is more of a scraping or whirring noise. You would hear it when you drive next to a wall and the sound bounces off the wall and back to you. The fact that the issues are speed-dependent are really odd. Normally with a pad deposit you will feel it most of the time, and it tends to be more severe/violent the harder you're stopping. The only way you guys are going to isolate the issue is to change one thing at a time on the car. 1. Change the brake pads out to something non-oem and leave everything else alone...check for noise. 2. If still present, put on fresh discs and check again. 3. If you change out the pads and discs and the noise is still present, you have something else going on. Anybody with this problem live around Charlotte, NC? If so, we'd be happy to look at the car and see if we can isolate the issue and its cause. My gut tells me that a proper bed-in will take care of this issue. A proper bed-in is typically more aggressive than what people do. Most people back off too early, aren't braking hard enough, aren't scrubbing enough speed, etc. Watch my videos...they show exactly what I'm talking about better than I can write it. Thanks. |
02-28-2016, 12:13 PM | #41 | |
1099
Rep 2,286
03-01-2016, 02:17 AM | #42 | |
Rep 626
03-02-2016, 02:17 PM | #43 |
Rep 842
No worries. I hate that we can't get our hands on the car with the issue and see it firsthand! My engineering director would probably have a fix in three minutes!
03-05-2016, 08:20 AM | #44 |
1099
Rep 2,286
So - back from the dealership with new pads/rotors front and rear - I just started a new thread/poll for break-in procedures used by people, and whether each person has had the judder come back - regardless of which break-in procedure was used before/after rotor/pad replacement.
Nobody is sure why the judder developed in the first place. Although I'd love to know the exact answer why - I'd still be more than happy if the problem never came back again (even without knowing). Guess we should all periodically check back in on this thread with any new developments/information as we go - the more collective knowledge we assemble here - hopefully the more likely a "root cause" will be identified and a more long-term solution also identified... |
