12-22-2019, 10:04 AM | #23 | ||
79
Rep 182
12-23-2019, 11:04 PM | #24 | |
Rep 7
01-22-2020, 04:21 PM | #25 |
Rep 457
Just received my strut brace. It is good quality. Appears to be made for a German company, there is a sticker on underside of bar with name and address of a German Tuner. I'm sending the bar out to get polished. Have the new strut bolts, and will install the mounts todays. Will take a pic when complete.
01-23-2020, 09:46 AM | #26 | |
Rep 965
01-24-2020, 06:46 AM | #27 | |
Rep 14,521
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
01-24-2020, 09:45 AM | #28 |
Rep 457
prowrapper is the seller. Here is the linky...
https://www.ebay.com/itm/BMW-F10-F11...72.m2749.l2649 |
01-24-2020, 10:02 AM | #29 |
1312
Rep 2,595
Just a heads up to those doing the bar, because it just happened to me.
Be careful when bolting down the bar. The bolts go into little wells on the brace, so you can't use your fingers to hand tighten the bolt and you need to use an extension to tighten them initially. This makes it hard to feel if the bolt is cross threaded or not. I just stripped two (one on each side) strut tower holes and now need to retap them to a size larger. If you ever need to remove the bar to remove, for instance, the airbox, just undo one of the bolts holding the actual silver bar, loosen the other side, and then just swivel it up. It's way faster and more convenient.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
John H.230.00 lsturbointeg9169.50 |
01-24-2020, 08:51 PM | #31 | |
Rep 457
The torque specs on the strut mount bolts are approx. 20 ft lbs. It can be easily over-tightened by hand. Also, these bolts are set-tapping. For those who plan to do this....Test fit the strut brace mounts, and see how the holes line up with the strut mount. I had a few that would have made the mount bolt go in crooked. Used a Dremel to to open it up a bit. I'm debating whether to replace the strut mount or installing Helicoils. If am not mistaken, the bolts are M8x30x1.25, 10.9 grade. Are you going with a M10 or near equivalent SAE bolt? Did not have time to pick up brace from polishing shop. I'll get it on Monday. . Last edited by John H.; 01-24-2020 at 09:18 PM.. Reason: Added info. |
01-25-2020, 11:07 PM | #32 | |
1312
Rep 2,595
2015 BMW 535xi
01-29-2020, 03:49 PM | #33 |
79
Rep 182
As previously mention some of holes from does not line up perfectly. I used a step drilled and made them larger. I believe I only did this with two holes. You want to make sure you don't drilled it larger than the diameter of the nuts that's goes on them. It's fairly easy to do and yes hand tighten this before you use a ratchet. That's just common sense stuff with any bolting items.
01-30-2020, 04:37 PM | #34 |
Rep 457
I decided to go with M8 Helicoils on the strut mounts. I can get a 21/64 bit through the body sheet metal w/o cutting into it. Also, I can still utilize the stock OEM strut bolts. On eBay, found a few NOS USA-made Helicoil kits out East. I'm expecting them today.
Did pick up the strut bar from the polishing shop. Will install when I square away the mounts. It will match the other polished items in my engine bay. . Last edited by John H.; 01-30-2020 at 04:47 PM.. Reason: Added info. |
01-30-2020, 04:40 PM | #35 |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
Pics! What kind of shop did you take this to?
01-30-2020, 04:55 PM | #37 |
Rep 1,445
Nice! was the ham and cheese extra or did they throw that in?
And nice California car wash brush deal, I have the same thing lol. |
02-01-2020, 07:31 AM | #38 |
Rep 1,445
Ordered.
02-01-2020, 08:02 PM | #39 |
Rep 457
So, I managed to Helicoil driver's side strut mount. It is SOLID. Tomorrow, will do pass side, and install the bar.
Had a bit of scare, tap fell out of t-handle into the BMW engine bay abyss. Dropped the splash shield, nada. Dropped the aluminum support, nada. Found it behind a brake line on the inner engine sidewall. Man, I was really worried. |
02-01-2020, 08:06 PM | #40 |
Rep 457
02-01-2020, 08:19 PM | #41 | |
Rep 1,445
02-02-2020, 01:53 PM | #42 | |
1312
Rep 2,595
2015 BMW 535xi
02-02-2020, 05:46 PM | #43 |
Rep 457
@Unspec, Yes. Use a quality bit that cuts well. Also, be easy with the tap, I had broke one in the process. Some tools and parts used...
1.). M8x1.25 Helicoil kit, stainless inserts,#5546-8, NOS(New Old Stock) USA Made, $18 - eBay, stitapandtoolsupply 2.). Dewalt drill bit, , 21/64, item #93021, $5 - Lowe's 3.). T-handle tap wrenches, 3 pieces, item #38560, $9 - Harbor Freight 4.). Aerosal air duster spray, remove shavings from drilled holes, $2 - Micro Center 5.). Loctite Blue - for strut mount bolts. 6.) Brake cleaner -clean up area of oils. 7.) WD40 - For tap use and inserts installation. Just finished the install. No hood adjustment needed. Came out tits. Last edited by John H.; 02-02-2020 at 08:39 PM.. Reason: Added info. |
WinstonE92xi64.50 |
