08-18-2011, 07:46 AM | #23 | |
117
Rep 1,998
BMW High Performance Brake fluid Dot 4 P/N 81220142156 Conforms to FMVSS No: 116 and SAE J1703 Minimum Wet Boiling 311*f (155*c) Minimum Dry Boiling 446*f (230*c) Made in USA Dist. by BMW NA ... no other indications of manufacturer of fluid..
X1, R58 JCW, M2 in my future if planets align
08-18-2011, 11:29 AM | #24 | |
European Editor
10637
Rep 22,992
Thanks DriveHard! Looks like my stuff has better specs. And its pretty cheap too over here (five euros for 1L bottle). Dackel Last edited by Dackelone; 08-18-2011 at 12:02 PM.. |
08-18-2011, 11:33 AM | #25 | |
Rep 475
08-18-2011, 12:00 PM | #26 | |
117
Rep 1,998
and your welcome !! yeah your stuff looks good.. USA stuff retails for $7.48 for .35 Liters ( 12 oz) I use ATE.. I like the pretty blue color and i only do a quick bleed after every event...no flush till end of season
08-18-2011, 12:01 PM | #27 | |
European Editor
10637
Rep 22,992
You got me curious about this Castrol SRF (racing)brake fluid, so I googled the specs... DOT4 dry boiling point: 320' C wet boiling point: 270' C 50 euros for a 1L bottle. http://www.oelwelt24.de/catalog/1+L....ng+Brake+Fluid Still... it IS marketed as a racing product so that really means you must test it or replace it often. Not pour it in and forget like a street product. I think yearly brake fluid flushes make sense for street cars. As for race cars or street cars that see a lot of HPDE... if you can afford to pay... don't play. Replacing brake fluid, engine oil, trand and diff fluid, tires, brake pads and rotors... is just the price "we" pay to play out on the race track. |
08-18-2011, 12:09 PM | #28 | |
European Editor
10637
Rep 22,992
ok, I fixed that typeo of mine! You made me chuckle! lol Yea... well... even a quick bleed is better than nothing. Its just some people think since they have the GOOD STUFF in there... they can forget about it. That is all I was trying to say. You know its like Mark Donohue and Roger Penske have written about... when your race car is clean... and detailed... it makes it easier to find/discover when something is broken or about to break/crack. When you are doing HPDE and pushing yourself AND your car... you should take time to check all those little things that can lead to a big accident. Even something simple as bleeding your brakes. Dackel |
08-18-2011, 01:24 PM | #29 |
140
Rep 2,234
I think Dackel is referring to me above from an earlier post. guess I should clarify a few things before I am painted with a broad brush and categorized as a reckless speed crazed nut
as a part of my post track day inspections, I take apart the brakes after each event and thoroughly inspect everything for signs of wear and stress. I haven't bleed my brakes partly because I haven't noticed any sponginess or decrease in brake performance. my service guys run the insight racing team in the continental tire series and last year before the track season I had them throughly inspect the car and told them to flush all the fluids including the radiator but they told me it's too early to worry about it and I should do it the following year. they told me that if oil temps don't go over 280 I wouldn't need to change the motul 300v oil and it should be good for 6-8 track days. obviously their knowledge and experience is invaluable to me. so yes I wish I could afford to change everything after every track event but as you said, it gets expensive when you start adding everything up. meanwhile I have to take extra caution and keep a sharp ear and sense for how the car behaves and to make sure you don't drive the car recklessly but still have a ton of fun within the limits
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
08-18-2011, 02:21 PM | #30 |
European Editor
10637
Rep 22,992
08-18-2011, 02:46 PM | #31 | |
Rep 566
I started with fresh oil, then did a UOA after two track days. Results were waaay within spec. So I went four track days before the next UOA - results still very much in the clear. So next I will try one after 6 track days, which I am guessing will still be in the clear, but might give a comfortable buffer (peace of mind). It gets expensive to replace oil all the time, so I use data to determine when it is actually needed. I'll use the money saved to attend more track days, and a virtuous cycle ensues. I'd like to do the same with the brake fluid, to at least give me a general guideline for how long before the dry boiling point is reduced to wet for the fluid I use, but haven't got around to figuring out how I can get it tested myself. So far, I started the season with a flush and had no issues 6 track days in. I just did a flush as a precautionary measure, but I doubt I was anywhere close to the current boiling point anyway. As for the aforementioned pre/post track inspections, definitely mandatory. You'll wanna include checking the ceramic piston caps to make sure they haven't powderized.
08-18-2011, 03:55 PM | #32 |
117
Rep 1,998
We could all buy this !!!! ( im joking...ill just bleed them damn things LOL )
http://www.amazon.com/Brake-Fluid-Sa...=pd_sbs_auto_3
08-18-2011, 05:02 PM | #33 |
140
Rep 2,234
ok nevermind
08-18-2011, 05:14 PM | #34 |
Rep 941
do our cars require the wheel off to reach the bleeder valve on the front and rear brakes?
which fluid is clear and has a better / higher boil point than the OEM stuff? Also, whats the process to bleed the brake pump cylinder when using the motiv bleeder?
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ berk resonated mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth, drilled slotted rotors
08-18-2011, 08:34 PM | #35 |
140
Rep 2,234
yeah you need to take the wheels off. I use motul RBF 600 which is considered one of the better ones. of course castrol SRF is considered the best but it costs $75 for a small bottle. as far as the bleeder, it's quite simple. you attach the pressure cap to the reservoir and you pump enough pressure into it and the rest is normal method to bleed. some people actually place the brake fluid directly inside the motiv container but I don't because cleaning that sh*t later is not fun.
08-19-2011, 02:45 AM | #36 | |
European Editor
10637
Rep 22,992
Also... when using any pressure bleeder do not pump it up more than say 10 psi. I once saw a mechanic pump it up to 15 psi and the prssure bleeder blew off the res from the master cylinder! What a mess! So this is the reason why you don't want to go over 10 psi. Always start your bleeding from the longest brake line first: right rear, left rear, right front, left front. For UK drivers IF the master cylinder in on the "other side" (ie in front of the driver, then you have a different bleeding order). Just remember longest brake lines first! Sometimes it doesn't hurt to use a small rubber hammer to tap the brake caliper as you have the bleed nipple/valve open. This will "move" any trapped air bubbles. I always use a CLEAR (6mm ?) hose on the bleeder valves. This will show you when there are air bubbles in that caliper. I always like to bleed each corner a few times. Brake fluid is cheap. AFTER you are done... depressurize the Motive bleeder. You do this by SLOWLY opening the T-handle pump (CC). Do it slowly so you don't spray any brake fluid all over your car! Then, once depressurize - you can remove the brake res adpator cap. The brake res will be over filled at this point. I use a clean Turkey baster to remove some brake fluid from the res. Make sure you are at the MAX mark on the res. There is an arrow on the side of the res. Some other tips... spray some penatraiting oil on the bleed valves BEFORE you try tp open them. USE a 12 point wrench or better yet, buy some flare tool wrenches. This will grab and hold the bleed vales better and not be prone to stripping or rounding the valve. Nothing worse than breaking one while trying to bleed your brakes. Don't go nut retightening them either. ALWAYS have some "Brake Kleen" on hand, just incase you spill some brake fluid on a painted surface. I like to use the CRC products bc they are non flamable. Dacxkel |
08-19-2011, 08:07 AM | #37 |
140
Rep 2,234
^ spot on directions! Flare wrench is a must. I believe it's a 11mm?
08-22-2011, 11:30 PM | #39 |
53
Rep 230
Well, I flushed my brake fluid for my first time... and the brakes stop the car with little to no fade so far.
I don't think it went as well as it should have though. For one thing it took hours, but the main problem was that the fluid never came out the color I expected. I was going to go with Motul RBF600, but I had already ordered Castrol SRF and it was too late to cancel it, so I just used it. I also decided against the ATE Super Blue as an indicator. The Castrol fluid looks completely clear. The fluid in my brake reservoir was brown and had junk floating in it! I just had my rear brake pads replaced at the dealer! So here's what I did: I wanted to make sure I didn't waste the Castrol fluid, so I suctioned out most of the fluid in the reservoir with a surgical irrigation syringe. I stopped when the old fluid was up to about the "Min" (minimum) mark. I put all the suctioned fluid in a plastic water bottle and marked a line at the fluid level to record this volume of fluid. I dumped out the plastic bottle into a glass jar for disposal somewhere (don't know where). I then poured in the Castrol fluid up to the "Max" arrow and hooked up and pressurized the empty motive pressure bleeder. I started with the passenger rear. At first the fluid came out dirty brown, then changed to a pale yellow, but it didn't come out clear. At this point I had reached the mark on the plastic bottle, so I decided to move on and avoid running out of new fluid. All four wheels and the clutch did the same thing. I used up all the fluid and the reservoir is now filled to about 75%. It's well above the "Min" so I assume it's okay. I assume that the old fluid and the Castrol mixed in the reservoir and some of the old fluid is mixed in with the new fluid. If this is what happened, then my question is... will the fluid boil at the old fluid's boiling point or somewhere in between the old and new fluids' boiling points? Thanks! |
08-23-2011, 04:57 PM | #40 | |
Rep 475
08-23-2011, 05:05 PM | #42 | |
European Editor
10637
Rep 22,992
Your new brake fluid (SRF) is dilluted with some of the old brown fluid. The only way to know at what point it will boil is to take a sample and you guessed it(!) boil (test)it! I don't think anyone in the US has the brake fluid testers that they have over here in Germany. You are probably fine with your fluid. But IF it really bothers you you should bleed your brakes again - until the fluid come out clear. |
08-24-2011, 07:25 AM | #43 |
Rep 475
08-24-2011, 11:01 AM | #44 | |
European Editor
10637
Rep 22,992
These guys sell the 1L bottle. http://www.oelwelt24.de/catalog/1+L....ng+Brake+Fluid 50 euros for a 1L bottle. |
