03-18-2019, 09:03 AM | #23 |
Rep 495
Drives: BMW 330e F30 M-sport
Happy to answer questions. I may have been a bit unclear, but I currently don't have a remap. I'm going to do a remap with bootmod3, but it hasn't been released for my engine (B48) yet. It's due out by the end of this month. I will report the results in this thread when I get it.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
03-18-2019, 09:10 AM | #24 | |
Rep 572
The link to the magnaflow unit shows a single outlet back box. Was it not a dual outlet box? |
03-18-2019, 09:35 AM | #25 | |
Rep 572
03-18-2019, 09:50 AM | #26 |
Rep 495
No, the exhaust pipe is a Y-design. The exhaust system is a single pipe system anyway. The original backbox was single inlet, dual outlet, I switched to a single inlet, single outlet.
Thorbjorn
04-02-2019, 11:14 AM | #27 |
Rep 495
Downpipe arrived. Next step to get it installed..
Thorbjorn
04-02-2019, 11:20 AM | #28 |
Rep 495
I did some sound deadening (doors, back seat, against rear fenders, and now recently started on the trunk) for those who are interested. And I also recently treated the undercarriage with sound dampening material. This last thing actually changed the road noise characteristic to the better, making it less unpleasant and easier to hear people talk in the car at highway speeds.
Thorbjorn
04-08-2019, 04:17 AM | #29 |
Rep 495
I did some logged runs with dashcommand today to prepare for BM3, wanted to be able to compare what's happening.
I'm currently on JB+, and it's actually loosing quite a lot of boost at the top end, from around 4750 it's actually below stock. Perhaps the ECU trying to correct for it, I don't know. This means I have more power than stock at the mid end, but max hp at the higher RPMs are probably below stock. It will be interesting to see the difference in boost curves, AFRs etc when I get the BM3. Stock boost stays at 12-12.5 from 3500-4500, then down to around 10psi at 5000rpm. 5500rpm = 8psi. With JB+ I'm at around 14psi from 3500-4250, then down all the way to 8.5psi at 5000rpm. 5500rp = 6psi.
Thorbjorn
04-08-2019, 07:46 AM | #30 |
Rep 495
First photo of 2019 with summer wheels. Car's eagerly anticipating new downpipe + Bootmod3 (if they can just release it already!)
Thorbjorn
mlev371.00 |
04-08-2019, 01:24 PM | #31 |
Rep 552
I'm a bit surprised the noise is that bad inside your cabin that you felt the need to insulate more. Are you running runflat tires? Those are usually noisy, my summer tires improved this a lot
04-08-2019, 02:03 PM | #32 | |
Rep 495
Also, it doesn't bother me that much when I'm driving alone, so it's mainly the combination of road noise and two noisy kids. Anyway, I've now both insulated the cabin and done the undercarriage, so it's tolerable now.
Thorbjorn
04-10-2019, 07:51 PM | #34 | |
Rep 572
2017 330e M Performance, MG Flasher Stage 2, RM Motors DP, xHP Stage 3, Armaspeed CIA
hybris204.50 |
04-11-2019, 11:18 AM | #35 |
Rep 495
Installed RM Motors downpipe yesterday. Posted first impressions here: https://f30.bimmerpost.com/forums/sh...9&postcount=42
Thorbjorn
05-10-2019, 04:29 AM | #37 |
29
Rep 73
What shall I do to the exhausts ??? https://f30.bimmerpost.com/forums/sh....php?t=1611150
05-10-2019, 09:13 AM | #39 | |
Rep 495
The wheels are 8.5" ET35 front, og 9,5" ET40 rear. Tyres are 235/40R19 front and 265/35R19 rear.
Thorbjorn
05-27-2019, 11:28 AM | #41 |
Rep 495
Bootmod3 b48 beta testing.
Flash successful, engine at least started afterwards and no error codes. Will go for a drive + log when the kids have gone to bed.
Thorbjorn
05-27-2019, 08:03 PM | #42 |
Rep 572
So how is the new map behaving? Much difference in power from the tuning box?
05-28-2019, 12:06 AM | #43 |
Rep 495
Yes, the engine is running much richer (seems to be targeting around 12.3 on WOT), and also the turbo pressure stays stable all the way to the redline, which it didn't do at all with a piggyback. It just pulls hard all the way.
On the timing I'm no expert but it looks fairly stable too. Sent logs to PTF yesterday evening, and they've already sent me V2, so will be doing another run tonight.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs Last edited by hybris; 05-28-2019 at 12:47 PM.. |
05-29-2019, 12:28 AM | #44 | |
Rep 572
330e, 330e tuning, b48, bm3, bms, f30, mineral gray f30 |
