Thrust arm ball joint removal...how do?!
07-31-2015, 07:48 AM | #24 | |
76
Rep 193
After rereading your post I guess I'm not sure how you mean... |
07-31-2015, 07:49 AM | #25 |
1208
Rep 2,835
You have gotten further with your balljoints than I did.... the torx bolts stripped on me and after calling an indy shop they said they could get them out in an hour.
I just went out and looked at the old ones and it looks like they used an air chisel at an angle with a 1/2" to 3/4" flat tip and hit against the top of the balljoint (up near the CV joint) and drove them out. Will take a bit but I can get a pic if needed. |
07-31-2015, 07:51 AM | #26 |
16
Rep 301
Dang. It's tough working in tight areas like that - hope you get it figured out! I feel for your frustration man, we've all been there one time or other doing DIY repairs
07-31-2015, 07:55 AM | #27 | |
76
Rep 193
I'm about to leave the ball joint bolts out and bolt the control arm back on And just run the car down the driveway and over some bumps. LOL |
07-31-2015, 07:55 AM | #28 |
Rep 952
Thanks for the pics. I think most people (including me) didn't understand your problem, and a lot of us don't have the Xi and aren't familiar with that thrust arm.
It looks like the ball joint is still in mount, you've cut off the ears of the diamond bracket to try and get it loose, but it's still stuck. Is that right? One question before I offer a suggestion: Is there a c-clip or wire ring anywhere on the top of that mount? I haven't done an Xi ball joint, but on some other cars, there's a c-clip on top of the joint. If a clip like that is in there, it would explain why you can't get it to release. The diamond bracket makes me think there would not be a c-clip, but just wanted to check. One suggestion: now that you have the ears off the diamond bracket, could you use two nuts (or bolts or ....) and the ball joint stud and arm to press it off? Here's what I mean: put the control arm back on the ball joint stud and taper, but only just enough to get the nut on 1-2 threads. Now put two nuts (one on each side) between the arm and the socket mount. Put these where you cut the ears off. These need to be big enough to span the distance of the grease boot. Now tighten the ball joint nut. If you can get this to work, the arm is pushing on the nuts against the ball joint mount and the tightening of the nut on the ball joint stud will pull the joint out of the socket. Even if it doesn't pull it out, put in under tension using this method and then whack it from above with the screwdriver / hammer.
bone stock
07-31-2015, 07:57 AM | #29 |
76
Rep 193
Thanks. And yeah, I'm definitely used to DIY frustrations. Haha I'm sure when a buddy come over with the torch tonight we'll figure something. I just wish there was a tool I could make/buy that would make this job easier. Seems everyone I've read about has had the same problem with these.
07-31-2015, 08:01 AM | #30 |
Rep 485
Pics make it all clear now. I didn't realize the ball joint was pressed into the steering knuckle on the Xi. On the RWD cars all the ball joints are pressed into the control and thrust arms so they are simply changed out as an entire unit.
Did the hammer trick work to free the ball joint from the thrust arm or did you already have it broken free when I made that post? |
07-31-2015, 08:05 AM | #31 | |
76
Rep 193
There is no C-clip or anything of the sort. That was a good thought but based on RealOEM's part diagram and having the new part in my hand, I don't see how that would be possible. That's actually a brilliant idea...and one that I've tried. The problem I'm having with it, and the reason I stopped, is no matter what I used as a "spacer/wedge" it would twist the arm as I tightened the nut. The mating surface where the ball joint goes is flat, but the arm has curvature to it. No matter how I positioned things it would ultimately twists the arm the tighter and tighter I made the nut. There isn't a flat enough surface on the arm to make 90° contact and have it stay under great pressure. Obviously the twisting was a huge problem as I don't want to tear the bushing on the other end. I ended up abandoning that idea after a couple hours of trying different objects and repositioning them countless times. |
07-31-2015, 08:07 AM | #32 | |
76
Rep 193
I had the thrust arm pulled before even making this thread. That part was easy. Over the years I've pulled many ball joints using the traditional methods. On this one in particular I used a 2-jaw gear puller. |
07-31-2015, 08:14 AM | #33 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
BMW probably reinforced the ballpoints in the front due the the extra stress put on the front end from AWD. If you can't get them out, you probably have 2 options A) put the car back together and pay a specialty front end shop to do it for you B) buy the whole arm(s) Either option is going to be $$ |
07-31-2015, 08:18 AM | #34 | |
Rep 485
07-31-2015, 08:18 AM | #35 | |
76
Rep 193
And option B isn't even an option. Even if they came as one unit (which they don't), I'd still need to pull this ball joint to put another one in...which is what I'm trying to do. |
07-31-2015, 08:21 AM | #36 |
76
Rep 193
Yeah, that's the Kroil that you see that I so liberally used. Haha Next step is acetylene after work tonight...but I still don't have access to an air chisel...so we'll see what I can come up with.
07-31-2015, 08:31 AM | #37 |
Rep 6,968
Ya, I feel your frustration. I had my rear ball joints toe arm bushings and subframe bushings go out this last winter.
I live in Michigan, which uses salt on the roads. This of course corrodes any part and makes it next to impossible for the average DIY guy to take out and replace such parts. I don't have air tools, so a torch wouldn't do me much good. I am afraid if I did use air tools on the parts, I would just end up snapping off the bolt. Then I would be buying several $15.00 Cobalt drill bits in order to drill the snapped bolt out So, I just paid the piper and bought lemforder (which is a BMW supplier) and BMW parts when the prices were close or comparable and took the parts to a front end guy I trust. I ended up paying about $300.00 for labor and a 4-wheel alignment. |
07-31-2015, 09:09 AM | #38 |
Rep 1,268
I'm thinking you will need to pull the trans axle out to get access to the ball joint with a ball joint press. With the axle out of the way you should not have an issue pressing out the ball joint. With that said not sure how hard it is to get the axle out. You can barrow a ball joint press from advance auto or buy one from harbor freight.
07-31-2015, 09:20 AM | #39 | |
76
Rep 193
07-31-2015, 09:29 AM | #40 | ||
Rep 1,268
http://www.amazon.com/gp/aw/d/B00061...PRL&ref=plSrch Advance and harbor freight both have this. |
07-31-2015, 09:33 AM | #41 |
Rep 1,834
Drives: 08 E90 335xi TiAg
I used this:
http://m.harborfreight.com/3-4-quart...not%20provided And a mini sledge, lots of PB blaster, a large flat screw driver wedged into the ball joint plate and the spindle and a few different sized chisels. One side came out right away with the separator tool, a socket stacked on top of the metal cone on top of the ball joint and an impact running the nut on the tool. The other side took me over an hour of working at it, pounding the shit out of it with the sledge, impacting, chiseling etc. The separator got it going but eventually I had to resort to more violent, caveman methods. Lots of four letter words and frustration. When it came loose it was like winning the lottery! Keep at it. It will break eventually. Would be nice if there was some kind of rubber gasket or if the diamond shaped plate had a raised edge on either side allowing more access with a tool etc. I didn't get to page 2 so if you already got it out...congratulations! If not...hopefully this helps. |
07-31-2015, 09:38 AM | #42 |
Rep 482
Post #25. Air tool - an air hammer will pop it out in no time.
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
07-31-2015, 09:38 AM | #43 | |
76
Rep 193
If you have access to a Bentley (which I don't have for an E90 yet as the car is only a few weeks old to me), I would LOVE to hear what it says should be done...!!! |
07-31-2015, 09:41 AM | #44 |
Rep 1,834
I think part of the problem is that when pounding the shit out of the metal cone it expands in the spindle causing it to jam up even more.
I know I couldn't have pounced in that little motherfucker any more and was pretty nervous at the climax of just wanting it out. Kinda like what delivering a baby must feel like accept no physical pain! |
