08-21-2016, 07:05 AM | #23 |
Rep 1,296
Also why is this thread about rear view camera referencing the same PINs on the same connector? Confusing me.
A173*8B PIN 51 & 52 are mentionned for the rear view camera, what happens if I need them for the TPMS? http://f30.bimmerpost.com/forums/sho...=873744&page=9
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
08-21-2016, 09:22 AM | #24 |
590
Rep 2,302
Yes that's normal.
Because these 2 wires are for the CAN-Bus. And this can branch off multiple. As i remember these 2 PINs are also for the trailer hitch. So if you have a trailer hitch you also can branch off these two wires in the trunk if you find them there. |
08-21-2016, 09:41 AM | #25 |
Rep 1,296
Ah OK so I can just take the existing orange/green orange cables and do a Y with each?
Sorry for the beginner questions, first time i'm tapping into what i understand is the CAN bus. Thanks for your help
09-05-2016, 12:50 PM | #27 | |
Rep 1,296
I made it finally thanks to the extremely valuable info from you here.
I got my ECU 6855180 (from gribouille1210 thanks !) + 4 sensors 6798872 from Ebay Germany, then wired per the instructions here + more explanations from gribouille. + holder 36206852245 to the bottom tank (I think it would have worked fine in the trunk too to be honest). The wiring goes under the car through a hole underneath the combox in the trunk, power from fuse 132 (used an "add a fuse" device like this one ) and the ground from the lighter ground wire in the trunk Then FDL coding with almost exact instructions here, one slight change: Quote:
09-05-2016, 01:30 PM | #28 |
Rep 1,296
I just change d RDC_SAFETY to aktiv and RDC_FORTSCHRITTSANZEIGE to aktiv just to see the difference.
And for good measure, a photo
09-06-2016, 07:43 AM | #29 |
15
Rep 106
Hi all,
I'm thinking about retrofitting TPMS in my F30 LCI. As per the above instructions and part numbers, I find that the TPMS module is not available for F30 LCI. Any one has any idea about a new part number, or if it was integrated in another module? Thanks a lot |
09-06-2016, 07:52 AM | #30 | |
590
Rep 2,302
It is standard since end 2014. You can see it at the tyre valve. If ou have TPMS you have a metal valve. If you don't have TPMS you have a black rubber valve. I think you only have to activate the display of the pressure and temperature. |
09-06-2016, 07:54 AM | #31 | |
590
Rep 2,302
But I must also admit that I do not know what that value means. The codings from above are exactly the same like VO coding. Last edited by atzebmw; 09-06-2016 at 08:22 AM.. |
Lancelot572.50 |
09-06-2016, 08:04 AM | #32 | |
15
Rep 106
But does that mean, if I get sensors, then I'm good to go? :O |
09-06-2016, 08:13 AM | #33 | |
590
Rep 2,302
But maybe only in germany the TPMS is standard since end 2014. If you want to retrofit the TPMS you need the sensors in the tyres, the control unit, 4 cables and someone to code it. |
09-06-2016, 08:25 AM | #34 | |
15
Rep 106
When I check on bmwfans.info there's nothing for F30 LCI to do with any TPMS modules. So, may be the module is integrated in FEM, REM (more logical) or ICM? |
09-06-2016, 08:43 AM | #35 | |
590
Rep 2,302
Before 03/2014 there was an own control unit. In my car (and some other users here) i have a control unit from a BMW F10, which works too. |
09-06-2016, 08:54 AM | #36 |
15
Rep 106
That's a screenshot from E-Sys of my DSC Module! This means, it has built-in RDCi, correct? If so, I guess, if I get the sensors (metal valves) and do the coding, it should work.
09-06-2016, 09:37 AM | #37 |
590
Rep 2,302
11-03-2016, 12:29 PM | #38 | |
15
Rep 106
atzebmw I have a question about the DSC coding, shouldn't C_Funktion_RDCi_l be aktive? |
11-03-2016, 01:22 PM | #39 | |
590
Rep 2,302
I just checked this and am confused. At my old F30 with retrofitted RDC this value was "nicht_aktiv". At my new F30 with RDC as standard has this value "aktiv". But it also worked at both cars. |
11-03-2016, 01:57 PM | #40 |
15
Rep 106
11-03-2016, 05:45 PM | #43 |
590
Rep 2,302
11-04-2016, 02:31 AM | #44 |
15
Rep 106
