      06-19-2017, 09:52 AM   #23
Eau_Rouge111
Eau_Rouge111's Avatar
356
Drives: 2009 128i and 2007 Z4M Coupe
Originally Posted by asbrr
Originally Posted by Eau_Rouge111 View Post
Ha no worries. I've read both bolt right up...my only question is with the F22/F30 calipers...if they fit the regular 18" wheels without spacers given they are wider than the e90 335i calipers because of the 4 pistons
All help is appreciated!
Argh...guess I was wrong...looks like a 5mm spacer:
http://babybmw.net/forum/viewtopic.p...a0770b665b9ebd
I really appreciate this...confirmed my suspicions. Thanks again!
      07-28-2017, 12:45 PM   #24
AlpinaB3
31
Drives: 2012 Individual 328i
Sorry to bump an old thread - OP did the parking brake still work after the rear swap?? I got a killer deal on a set of BMW performance calipers from a 135i (even with the cracking they'll be miles better than the stock 328i calipers...) I will for sure retrofit the fronts, but I'm curious if the rear e-brake will still work.
IMO the performance brakes look more aesthetically pleasing than the newer M-Sport brakes.
      03-12-2018, 05:47 PM   #25
NinjaDog
NinjaDog's Avatar
Australia
20
Drives: BMW 135i
Any update on how these perform at the track?
      05-22-2018, 10:49 AM   #26
chris_flies
Sideways and Smiling
chris_flies's Avatar
3029
Drives: In Exuberance
I did two track days on mine (with OEM pads, BTW) with stock 128i rear brakes (with Hawk pads). Absolutely no fluid boiling going on, the calipers were perfect, but the OEM pads let them down in terms of fade. I don't really have any issues with brake bias, either...
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread
      06-14-2018, 10:08 AM   #27
gixracer
gixracer's Avatar
Drives: 1M3/SlickN55/SlickN54/128
Similar results as above. I ran with the ecs tuning rotors and hawk 5.0 pads(they had a deal going on). I am running 135 rear brakes/hubs/axle swap with a 135 master cylinder.
No issues at Mid Ohio yesterday. Plenty of bite and no real fade in a 20 minute session. I do notice that they are softer going home after 6 sessions. that would just need a quick bleed.
I find that these are much better than 135 fronts. they are more consistent in feel and less perceived fade. I think with cooling/track spec pads/r compounds these would be a great setup.
my 2 cents
128i Msport, 1M3=1M clone +S65= N55 swapped former 128 slicktop, former 128 slicktop with N54T swap
      06-16-2018, 08:52 PM   #28
chris_flies
3029
Ran last weekend at Summit Point, this time with EBC YellowStuff pads. More consistent than the OEM F30 pads, much better modulation, but they got soft towards the end of the first session, and never recovered. I'll bleed the brakes to be sure that the fluid isn't an issue (never has been with Motul RBF600) and inspect the pads to see if they're glazed. Do glazed rotors have a purplish tint to them? That could also be the issue (mine are totally purple, but get less purple with street driving)...
I did get one particularly strange thing from the brakes this time around, smoke. We had a red flag (E92 M3 rolled inside of T9) and as I slowed to a crawl and got over to the right of the track, smoke was clearly pluming from the front corners, and I could see major heat distortions at every corner; it all subsided after about 30 seconds. Yikes.
      08-18-2018, 10:01 PM   #29
Booey1979
Drives: 2010 128i m-sport BBK 2piece
Wait so F30 brakes fit e82 128i?
      08-19-2018, 10:01 PM   #30
chris_flies
3029
Yesss, and with good pads, they are well worth it for track junkies...
      09-10-2018, 03:45 AM   #31
mika type r
mika type r's Avatar
France
Drives: 125i e82 stage 1
Hello, very interesting but you don't change the master cylinder?
      12-09-2018, 10:37 PM   #32
One28i
14
Drives: 1
thinking of doing the 4 pot front and 2 pot F30 328i caliper swap, but want the 17" style 44 rims to work. Have a local rebuild calipers shop looking at 330-340mm rotor front and 300mm-345mm rotor rears setup. I will be taking a rim to see if it will all clear. stay tune...
      12-14-2018, 10:46 PM   #33
Nad128
45
Drives: 2008 BMW 128i
FWIW, the fronts with 340mm fit my 17x8 et45 Fast FC04A wheels. It's a very tight fit but it works.
      12-23-2018, 12:41 AM   #34
One28i
14
Drives: 1
Question
that is awesome, you got pictures? did you do the rears by any chance as well? my current rims are 17"x8" ET47mm.
      12-23-2018, 10:44 AM   #35
Nad128
45
I didn't do the rears.
Here are a few pics
Test-fitting before painting the calipers:
Finished install:
      12-25-2018, 06:11 PM   #36
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
What needs to be done to install the rear F30 335i calipers? I need to put on new rotors and pads back there anyways. I'm guessing there will be an issue with the parking brake on the 128i?
      12-27-2018, 06:42 PM   #37
One28i
14
Drives: 1
[QUOTE=Nad128;24149093]I didn't do the rears.
thank you. I checked out the F22 section, and noticed some were putting on 17" on their M235i/240i that have the 340mmfront and 345mm rear setup.
https://www.2addicts.com/forums/show....php?t=1517341
      04-01-2019, 09:21 PM   #38
Jeb_
61
Drives: 2011 128i
I'm looking to do this swap in a couple weeks. Can someone confirm that the gray 4-pot Brembos bolt up to the 128i caliper carriers, or will the caliper carriers from an f30 be required?
      04-02-2019, 06:59 AM   #39
chris_flies
3029
The calipers have built-in carriers, you simply remove the 128i caliper entirely and it bolts right up. Make sure you install them with the bleed caps facing upwards.
Jeb_60.50
      04-02-2019, 08:23 AM   #40
Jeb_
61
Drives: 2011 128i
Good to hear. Thanks.
      04-05-2019, 06:54 AM   #41
128Styll
Colosseum Chariot Driving Instructor
Drives: Slow '12 128i
any idea if the 17in style 207 wheels have fitment issues with this setup?
      04-05-2019, 07:07 AM   #42
chris_flies
3029
Style 256's fit with a 5mm spacer up front. They're both OEM wheels, so I'd expect clearances to be similar.
      04-06-2019, 04:38 AM   #43
juld0zer
Australia
482
Drives: Prev 135i 7DCT, Now 130i 6sp
Disconnect the brake hose at the hard line and mount the hose on the caliper off the car to avoid twisting the hose upon reassembly.
eg. Use a vise to hold the caliper when torquing up the hose.
      05-16-2019, 08:26 AM   #44
$iriu$black
Drives: 2012 BMW 128
Could anyone positively confirm if these F30 calipers clear the 207M 17in wheels for 128i? I read the 5mm spacer requirement but wanted to know if anyone has tried and succeeded in fitting OEM wheels with the caliper upgrade.
