MY N53 (NOX, Injectors, rough run, sooty exhaust) Is running badly how do I diagnose
09-12-2019, 05:27 AM | #23 | ||
46
Rep 183
Let us know your take on the NOxEM once you have it installed, any power improvements/smoothness and mpg etc. A couple of people have it coded out, I've emailed a few tuners including Maptech but they still havnt got back to me hence still undecided! NOxEM does seem good on paper! |
09-12-2019, 02:33 PM | #24 |
34
Rep 187
I will surely say what I think about it after I get it installed.
Sadly I didn't think much at that time and just purchased NOXEM, not knowing there is map/code option too AND also a bit later I have seen some other NOX emulators online for about 150, which is like half price of NOXEM. But now it's too late and according to tracking I will have it here next week. I have high hopes for it given the price. I did see one forum member mentioned installing it and it solved few problems for him, so I'm optimistic.
Current: 2017 F30 330e PHEV
Past: 2007 BMW E93 N53 Convertible |
09-13-2019, 01:19 AM | #25 |
46
Rep 183
Personally I wouldn't go for anything other than NOxEM or Map-out! Even with the map-out I'm read stories of people mapping the sensor out to only face more problems as apparently there isn't a way to get it back!
On the bright side, NOxEM does mention that their version delays CAT regeneration so better economy, so if it is as smart as they claim it to be it might just be the right thing! I've emailed a couple of tuners to ask how exactly they map it out and whether they also do cat regen delay etc or even better just delete the secondary cats from the map to never waste fuel heating them! |
09-17-2019, 01:19 PM | #26 |
34
Rep 187
It arrived
Tr1ppy36.50 aaronblack45.50 |
09-17-2019, 05:25 PM | #27 |
Rep 681
Watching with interest ! I think I need one for my F10 N53 as the mpg went really really good for about 2 weeks and then dropped off a cliff.
Curious to know what the general quality is like, does it look OE? Wonder how they make them. |
09-18-2019, 04:47 AM | #29 |
34
Rep 187
It does look very good, quality seems to be excellent. And it seems like it really is Bosch probe, as advertised.
aaronblack45.50 Will_460cs213.50 |
09-18-2019, 12:47 PM | #30 |
Rep 464
09-18-2019, 12:57 PM | #31 |
34
Rep 187
Not sure if guys at the garage have those, but hoping a wrench + a hammer/rubber_mallet will do the job
09-22-2019, 03:50 PM | #32 |
Rep 681
Looks good. Be interested to hear how you get on.
I keep thinking mine has failed but I still had 34mpg on a run earlier. Down slightly from 37mpg typical and 39mpg max. The engine feels a bit down on power too, but that's subjective. Last time I looked there were plausibliity codes for NOx but I'll check again. |
09-22-2019, 04:23 PM | #33 | |
46
Rep 183
09-22-2019, 04:40 PM | #34 |
34
Rep 187
In my case I reset my MPG then went for a drive on a highway (to try desulphate) and came back with 12 L/100 which calculates to about 24 British MPG or 20 US MPG. That's with one of the NOX related codes: 30E9.
My mechanic is on vacation, need to wait 2 weeks...
09-22-2019, 09:46 PM | #35 |
46
Rep 183
From everything I've read NOxEM should get you anywhere from 35 to 40+ mpg which is perfect for a 6 cyl!
Initially I was getting 32 mpg when I first got the nox faults etc but now it's 26-28! I assume the secondary cats are not being regenerated anymore hence getting clogged not sure! |
09-23-2019, 05:41 AM | #36 |
Rep 681
Does anyone know if the desulphurisation / regen causes a rotten egg smell from the exhaust or is something wrong with mine? Only happened briefly after a spirited run. I have had NOx errors recently but nothing on the bimmerprofs "your NOx is dead" list of codes. Sulphur stinks of eggs so I presume the rotten egg smell was a regen rather than overfuel cat smell in which case my nox must be working to trigger a regen. 35mpg on a 25 mile motorway run this morning too, not bad for a 3.0 petrol F10.
09-23-2019, 06:22 AM | #37 |
34
Rep 187
Not sure on that smell, if it goes away then I would assume it's just the desulphation process. On the other hand: "As the cat fails, it stops changing hydrogen sulfide into its odorless counterpart and the result is a strong smell of rotten eggs from the exhaust." Or have a look here: https://www.e90post.com/forums/showthread.php?t=1369192
Out of curiosity - what codes do you have? My 24 MPG seems to be messed up badly comparing to others, I really hope 30E9 code is the reason and NOXEM will fix that. If not, I will be clueless...
09-23-2019, 08:58 AM | #38 | |
46
Rep 183
Again I've heard NOxEM delays cat regen etc over the standard OEM system and hence they claim upto 15% better economy than a standard fully working nox system! |
09-23-2019, 09:43 AM | #39 | |||
46
Rep 183
Did you have this problem? Do the 325/330 have the same NOx sensor size? |
09-23-2019, 12:13 PM | #40 | |
34
Rep 187
Did you check your NOX sensor using INPA? Some useful details shown there. According to Bimmerprofs, sometimes 30E9 does not actually mean cat is aging, but NOX sensor not functioning properly makes the car think that. In my case INPA shows NOX sensor Offset out of range meaning it is clogged (again, according to Bimmerprofs, if we can trust them). Value No3 in Nox screenshot here: https://bimmerprofs.com/problems-per...ck-nox-sensor/ It says somewhere that emergency mode, fuel consumption goes up A LOT. EDIT: Found it "If the error message memory of N43/N53 series engines contains error messages regarding NOx sensor and/or NOx catalytic converter (30EA; 30E9) or – the NOx sensors have hidden defects, due to which the engine doesn’t use Stratified charge, average fuel consumption (depending on driving mode) will be increased to 15 .. 25% (higher increase – in low load modes)."
09-23-2019, 12:16 PM | #41 | |
34
Rep 187
https://www.realoem.com/bmw/enUS/par...129&series=E92
09-23-2019, 12:54 PM | #42 | ||
46
Rep 183
I think cut and weld is the simpler easier solution to secondary cats! |
09-28-2019, 01:42 PM | #44 | |
16
Rep 34
I was one of the first in the UK to install the NOXEM and for anyone who has doubts you are in safe hands. Today I made a 50 mile return trip along the M3\M25\A3 to New Malden cruising between 60-70mph and achieved 42.8mpg indicated on the OBC, it was actually around 45 mpg until I hit the town center. Overall I'm very pleased to have restored stratified mode as was only achieving around 35mpg with a faulty NOX sensor for the same journey. I'm not affliliated with Bimmerprofs in anyway but I want to give them a honest review in that they give lifetime warranty of the NOXEM ECU as long as you own the car, the Bosch sensor is 12 months warranty and can be replaced should it fail in future which will save you money in the long run considering the extortionate price for an OEM NOX. |
