      06-04-2019, 09:28 PM   #23
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
Originally Posted by MrBimmer View Post
I never ever use my arm rest. It gets in the way of shifting so I have it up 100% of the time
Ibrahim I don't even think about it anymore. At first I noticed. Not anymore
      06-05-2019, 08:25 PM   #24
duder13
duder13's Avatar
768
Drives: Cashmere
Oh, then you've gotta do this delete. It's fantastic.
      06-06-2019, 01:53 PM   #25
nachob
It's reversible too just keep the armrest. Albeit the parts are a little pricey.
      12-11-2019, 02:09 PM   #26
touringteg
25
Drives: 2011 BMW 1M
I am so happy to find this thread! I will put the arm rest up for a while and see if I miss it. If not I will love to shave 4.5 lbs. Every bit helps. Cheers.
      12-11-2019, 03:00 PM   #27
nachob
It felt odd a couple of times without it but don't miss it now and car is lighter and probably faster too! ; )
      01-02-2020, 06:21 PM   #28
E30 Racer
E30 Racer's Avatar
Drives: '11 1M, '09 335i M Sport
Originally Posted by nachob View Post
There is already a DIY on doing this but I did notice one thing that was not mentioned and is key. After you take off the armrest, you have to put the new bracket and it partially goes in inside the console. It has some hooks that you have to slide in from the inside out and push the bracket up. I took enough bolts out that I was able to simply lift the console and spread it slightly to put the bracket in place. Then just put the fasteners back on and put the rear cover.
I just performed this retrofit. What Nachob has mentioned is true, but perhaps a bit understated. Rather than going all he-man when trying to insert the bracket into place by loosening/removing the bare minimum number of fasteners, I found it was necessary to remove the retaining screw on the right (passenger) side of the center console and the 10mm nut under the e-brake boot (in addition to the three 10mm nuts and two torx screws needed to remove the armrest). That allowed the back of the center console to be raised enough to comfortably install the bracket. Zero collateral damage using this approach.
Very pleased with the final result. Clean, OEM BMW parts, and 100% reversible if necessary.
BTW, here are some resources I found helpful:
https://www.1addicts.com/forums/showthread.php?t=213833
https://www.1addicts.com/forums/showthread.php?t=209774
Tornado1M1227.00
nachob2317.00
      01-02-2020, 07:07 PM   #29
nachob
Awesome!! Yes my writing failed me. I did take all of those off too but this time I only lifted enough to insert the bracket and slide it in. I love this retrofit because every time I drive and don't hear the armrest squeaking and rattling just adds more to the enjoyment. And as an old school performance guy that appreciates my stripper 1M it's one more weight saving thing I don't really need. Thanks for sharing e30Racer!
      01-10-2021, 01:23 AM   #30
GMpaintcode75
Drives: Porsche 944, Alfa Romeo Milano
Deleted Armrest Wanted
Is anyone who has done the delete interested in selling me their armrest?
      01-10-2021, 11:00 AM   #31
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I may have to do this. I love that the two center console cupholders and now 100% usable without fear that a sudden stop will slam the Armrest down on them!
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
nachob2317.00
      01-10-2021, 12:50 PM   #32
UberWagon
UberWagon's Avatar
Drives: 2011 BMW 1M
Just ordered the parts for doing this. Thanks for the inspiration nachob !
nachob2317.00
      01-23-2021, 05:22 PM   #33
UberWagon
UberWagon's Avatar
Drives: 2011 BMW 1M
Just a heads up that my bracket didn't come with the silver clips. You can reuse the ones from your arm rest bracket so if you are wondering why your cover is mounting loose, it is probably because you are missing the clips. Took me a minute to figure out what was wrong!
      07-30-2023, 03:45 PM   #34
schernov
80
Drives: 2018 340zhp, 2009 135i
I know this is an old thread - but if you are wondering why you need the mounting insert .... for cars with comfort access there is an antenna which slips into the bracket. Originally ot clipped onto armrest
Luxury89.50
      02-24-2024, 10:04 PM   #35
Luxury
Luxury's Avatar
Drives: A4 1.8TQM, 135is DCT
Thank you so much for this comment! I am making this modification also and had a Bimmergeeks code pop up A069 for an interior antenna fault. Your post relieved my confusion of the source of the fault!
2013 BMW 135is Coupe | Dinan Stage 3 | Dinan Monoball Joints | Dinan Toe Links | 1M Subframe Bushings | 1M Strut Bar | MPSS - BMW 313M's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | #341/586
