12-30-2021, 06:48 AM | #23 | |
Rep 817
Drives: bmw M3 F80
OK, thanks it is necessary as even that there have contact of the battery as indicated in the photo? |
12-30-2021, 07:38 AM | #24 | ||
99
Rep 155
12-30-2021, 07:55 AM | #25 |
Rep 817
Drives: bmw M3 F80
01-01-2022, 11:01 AM | #26 |
Rep 817
Drives: bmw M3 F80
Hello,
Is it normal that the relays heat up a lot? when i plug my plug into my box my bmw demare directly is this normal? the relay indicator lights always remain on even with the ignition off? Last edited by david51; 01-01-2022 at 11:18 AM.. |
01-01-2022, 11:04 AM | #27 |
99
Rep 155
01-01-2022, 11:24 AM | #28 | |
Rep 817
Drives: bmw M3 F80
I'm talking about the socket that feeds my box the relay indicator lights always remain on even with the ignition off? |
01-02-2022, 07:16 AM | #30 |
99
Rep 155
No that's not supposed to happen. All relay lights should light up only when the relay gets closed. What happens if you run the start sequence? Do they stay on or some light turns off?
01-02-2022, 09:16 AM | #31 |
Rep 817
Drives: bmw M3 F80
01-02-2022, 09:17 AM | #32 |
Rep 817
Drives: bmw M3 F80
01-02-2022, 09:23 AM | #33 |
99
Rep 155
Ok so all relays are receiving 5v, which is wrong. Is the wiring correct? If you look at the schematic, you can see that pin 1-6 of the relay board are directly connected to D2-D7 pins on the arduino. Is that the same in your wiring?
01-02-2022, 09:36 AM | #34 | |
Rep 817
Drives: bmw M3 F80
yes I did the same |
01-02-2022, 09:49 AM | #35 |
Rep 817
Drives: bmw M3 F80
the only difference with your connection
is that I took the power and the mass on the odometer. and the k-can2 on the idrive wheel |
01-02-2022, 09:52 AM | #36 |
99
Rep 155
01-02-2022, 09:57 AM | #37 |
Rep 817
Drives: bmw M3 F80
FlyHigh7574.50 |
01-02-2022, 05:36 PM | #38 |
Rep 817
Drives: bmw M3 F80
I always have the relays which remain on which heats the power supply and the relays.
is this due to an HS relay problem? is the power supply supplying the relays and the nano card at the same time? here are my connections |
01-03-2022, 01:37 AM | #39 |
99
Rep 155
01-03-2022, 09:02 AM | #40 |
Rep 817
Drives: bmw M3 F80
good news the relays are no longer lit
on the other hand output of the power supply I only have 3.38V it is not possible to adjust the voltage? or must I buy another model ? Last edited by david51; 01-03-2022 at 09:08 AM.. |
01-03-2022, 06:38 PM | #41 | |
99
Rep 155
DISCONNECT EVERYTHING FROM THE POWER SUPPLY WHEN YOU ADJUST IT!!! You risk to set the output too high and fry some components! (like the arduino) Remove it from the rest, set it to 5v and reconnect everything |
01-04-2022, 07:40 AM | #42 | |
Rep 817
Drives: bmw M3 F80
I tested the power board alone and the output is 5V as soon as I connect it to the relays and the arduino nano board the output goes down to 3.38V. is this normal? Last edited by david51; 01-04-2022 at 08:45 AM.. |
01-04-2022, 04:50 PM | #43 |
Rep 817
Drives: bmw M3 F80
I received my new power supply which is set to 5V at the output but unfortunately it still does not work
01-04-2022, 04:54 PM | #44 |
99
Rep 155
f30, remote, remote start |
