BMW M3 Forum (E90 E92)
      10-04-2020, 02:35 AM   #23
TechE
TechE's Avatar
102
Drives: E90 M3, U11 X1
2008 BMW M3  [0.00]
[QUOTE=ABC99G;26733364]
Originally Posted by 6ixSpd View Post
Do you have a photo of the connectors they gave you?
Hi, as it turns out the connectors are correct, but in my car they are hidden
behind the side seat cushion under the seat belt.
To get to them I need to remove the seat cushion.
Do you know how to remove this?
Also, I noticed that the Bilstein plugs can be connected either way.
Is polarity an issue?
I have connected mine by cutting and joining wires but it still does not work.
Does the error code need to be cleared first?
Any help would be greatly appreciated.
Thanks,
Gerry
The rear seat ends use a clip to hold in place. It's simple as a firm yank from the top.
The plugs only connect one way. There is no cutting or splicing required.. Everything included is OEM fit.
You shouldn't have any error codes. My guess is your custom wire work triggered that.
No offense, but you probably should have researched this before going all rogue, or just paid somebody to do it. This is an expensive kit to be tinkering around on. Hope your hardware install went a bit more smoothly.
M4_GTS1152.50
nah dude238.50
      10-04-2020, 03:14 AM   #24
ABC99G
Australia
16
Drives: 2008 E92 M3 Coupe
Mine were the same as your photo for the front. The problem I had was in the rear. I thought the connector should plug into the wire that comes out of the top of the shock. I couldn't find the plugs where it was supposed to go because mine were in behind the fixed seat cushion in the corner.
I've since worked it out so I just need to get the error coded out.
I'm very happy with the result though.
      10-04-2020, 03:19 AM   #25
ABC99G
Australia
16
[QUOTE=E.Usaf;26759413]
I did pay my mechanic to do it, but you are correct, I should have researched it myself. However, I have since found a photo showing the connector going in the opposite direction to mine so this added to my confusion. Hopefully all will be OK once I get the error coded out. Hardware fit went without any problems.
      10-06-2020, 12:57 AM   #26
TrickTizzle
Drives: E92 M3 ZCP
Did these come with bump stops? If not, what are you using, if any?
Also, what rear shock mounts did you decide to go with?
I'll be getting mine installed in a few weeks. Collecting some complimentary suspension components right now.
Originally Posted by DanMpower View Post
Awesome review man!
Now I just need to find a set...
BayE30, sell me your B16 setup.
Turner shows them in stock for any one looking to grab a set.
'12 E92 M3 - Alpine White - ZCP - Dinan S2
IG:mpwr92
      10-06-2020, 01:43 AM   #27
DanMpower
DanMpower's Avatar
Drives: BMW M3s and a Red VW
Summit Racing and a few other places are showing in stock as well.
Just placed my order with AJUSA over the weekend, $2707 after coupon + tax, and free shipping!
6ixSpd6034.50
      10-06-2020, 07:45 AM   #28
Cyberdemon
Cyberdemon's Avatar
1542
Drives: 2020 X5 40i, 2018 M3 Comp
Not a bad price, but they're still backordered by 3 months or so right? I guess it goes "good fast cheap pick two"
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      10-06-2020, 08:23 AM   #29
tdott
Drives: M3
They have internal bump stops, it says so in the manual and tells you not to reuse the original.
Read the instruction manual, it's pretty detailed.
6ixSpd6034.50
      10-09-2020, 04:32 AM   #30
TrickTizzle
Drives: E92 M3 ZCP
Thanks. I've yet to open the box.
Which rear upper shock mounts are y'all running?
IG:mpwr92
      10-10-2020, 10:28 AM   #31
Yea Boi
Yea Boi's Avatar
Drives: Alpine white 08 M3
Hi, im in the middle of my install and just need a little clarification as to why there were 2 19mm nuts provided for the rear bilstein shocks. Can someone tell me if we use these 2 nuts instead of the 22mm oem?
      10-10-2020, 11:31 AM   #32
M4_GTS
Hong Kong
1153
Drives: M4 GTS
Read the instruction and follow the diagram. Tells you right there to use the 2 19mm instead of the 1 22mm.
Originally Posted by FMLYSDN View Post
You're a dick. Oops. Did I just say that?
      10-10-2020, 11:46 AM   #33
Yea Boi
Yea Boi's Avatar
Maybe I got a different diagram, unless the one nut, labeled ‘B’ for bilstein provided equals 2 19mm nut. Thank you though for clarifying, maybe I’m looking into it too much.
      10-10-2020, 11:50 AM   #34
M4_GTS
Hong Kong
1153
Drives: M4 GTS
Bilstein at it again with their packaging. You got the diagram for the non-edc B16 PSS10 kit. That diagram shows the top adjuster for dampening which we don't have.
Use 2 of the 19mm nuts. It's to prevent it from backing off. The oem nut is the wrong size for the Bilstein shock shaft.
Which pigtail did they include in your kit? The old style or the new style?
      10-10-2020, 12:06 PM   #35
Yea Boi
Yea Boi's Avatar
For the fronts, old style, but rears it’s plug and play. Thank you for clarifying, I figured looking at the diagram that it was for non-edc but I didn’t want to assume.
      10-10-2020, 04:06 PM   #36
M4_GTS
Hong Kong
1153
Drives: M4 GTS
Bilstein is just absolutely horrible with how they put kits together. Its always the mix and match parts. They throw in whatever they have left in the parts bin when they run out of parts. I wouldnt be very happy getting the old connectors for the front. Makes for a messy looking install.
      10-11-2020, 09:28 AM   #37
6ixSpd
Save the manuals!
6ixSpd's Avatar
6035
Drives: '16 M3, '23 718 Spyder
The instructions cover both B16 PSS10 and B16 Damptronic. You're looking at the wrong diagram. Each page has it labelled up top right whether its "B16" or "Damptronic."
https://productdesk.cart.bilsteinus....M4-Y611A00.pdf Page 27, not 26.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      10-11-2020, 06:42 PM   #38
Yea Boi
Yea Boi's Avatar
They didnt include the last page in my instructions but thanks for including the link.
6ixSpd6034.50
      10-11-2020, 07:00 PM   #39
6ixSpd
Save the manuals!
6ixSpd's Avatar
6035
Oh man... even the ones they sent me were all over the place and out of order. Thankfully I hunted down that PDF well in advance of my install and didn't use the printed ones.
      10-12-2020, 11:01 AM   #40
Yea Boi
Yea Boi's Avatar
Looking over your link with the instructions, was there a reason why you didnt re-use the spring pad? Did GC tell you not too?
      10-16-2020, 01:20 PM   #41
6ixSpd
Save the manuals!
6ixSpd's Avatar
6035
It does not fit with the GC plate design and is unnecessary.
      02-19-2021, 01:42 PM   #42
wootloops
wootloops's Avatar
359
Drives: 2013 E92 M3 Lime Rock Park
6ixSpd
I just installed B16 coilovers with Ground Control street camber plates like yours. I am also at 1.5 threads front and 9 rear. However, my car seems to sit way higher that yours both front and rear.
What tire size are you running? I have 265/35r18 on 18x10 +25 EC7s. Are you running something that fills in the fenders more?
The only thing I can think of is that I kept the rubber spring pad (it fit into the GC plates no problem) but that cant be more than 1/8" thick or so. Even still, that doesn't explain the rear also being way higher.
Pic for comparison - Just installed last night and aligned this morning.
      02-19-2021, 03:59 PM   #43
6ixSpd
Save the manuals!
6ixSpd's Avatar
6035
That doesn't seem right at all, the spring pad can definitely add a couple millimeters to your stack height though. Exactly which plates do you have? I believe there's a different type of lower profile bushing that you can use up top that reduces the stack height. I would speak to ground control and see what two different bushing options they have for OEM type upper mount setups. I can't recall if I kept my lower spring pads in the rear. I'll check once the car is out of storage.
My BBS LM setup runs the exact same rolling diameter as stock so my height suggestions should be the same for any car keeping to the stock rolling diameter.
Your 265/35/18 is a big factor. That tire and wheel setup is almost an inch shorter in overall diameter, thus you have an arch gap increase of 5.7mm front and 12.7mm rear. The spring pad plus this would definitely explain your ride height differences vs. mine.
      02-19-2021, 05:32 PM   #44
wootloops
wootloops's Avatar
359
Ok, that explains a bit.
I have these plates: https://groundcontrolstore.com/colle...t-camber-plate
Maybe the best move is to switch out the GC front plates for the shorter version, which will drop the front a bit. Then I can adjust the rear lower since it still has about 9 threads to go.
Realistically I'll probably leave it as-is for now, but at least I have a better idea as to why it looks so much different than yours.
m3post
