02-06-2022, 07:44 PM | #23 |
371
Rep 317
Two weeks ago, I found a set of base F80 M3 mirrors for a fantastic price on Ebay and put them on right away. They came with Black Sapphire Metallic caps but I found a set of Alpine White ones on F80post.
02-06-2022, 10:23 PM | #24 |
Rep 407
dis good! need me some m4 mirrors
squaredphoto370.50 |
03-18-2022, 10:39 PM | #25 |
371
Rep 317
Been looking at front and rear strut bars for the F30 lately and decided to go with the KC Design front strut bar and the KC design rear lower bar ( kinda like the F33 rear lower triangulation bars ). Placed an order through them and literally a week later, they both arrived in Chicago from Taiwan. Shipping was a bit expensive...
Overall fit and finish seems great and I chose this set because they're "one piece" and not hinged. The holes here are oval and I'll show you why I don't like them later. I understand why they're this shape and I'll have to accommodate for them some other day. First issue. The ziptie / clip holding the harness is in the way. I recommend cutting the zip tie, flipping the clip and using a new zip tie. Second issue. The DME cover is in the way a lil bit. It gets pushed down more which I don't see as a problem yet. Third issue. The rear most bolt in scope doesn't even go into the hole until you start torquing down the other bolts. The part of the bar that mates to the strut tower will flex down into shape. This is mostly user error. The washers I'm using with the Vorshlag camber plates are small and dig themselves into the oval holes. I'm not sure how this impacts the functionality of the bar. I'll need wider washers. I torqued them to around 30 ft/lbs. With everything buttoned up, the bar looks great! Very low profile and stealthy. Notice the flipped harness clips on the strut towers. The DME cover didn't really get pushed much while comparing the before and after pics Now, does this bar really do anything? I only drove around for a few minutes to make sure nothing fell off. There appears to be a decrease in body roll and slightly better turn in and directness with steering input. I didn't notice a change in steering weight. With time, I'll chime in some more feedback. Next up: - Rear lower bar once I get the room to get under the car - Front lip once it gets ceramic coated |
03-19-2022, 11:12 AM | #26 |
371
Rep 317
Decided to wake up early and try installing the KC Design rear under bar. It's pretty lightweight and seems rather sturdy
This cylindrical piece mounts into the rear subframe More oval holes like we saw in the front strut bar. Here's the stock support brace. I decided to work on one side at a time as I didn't feel confident lifting by the rear diff. Removing the subframe bolts was the most anxious part on my end. More ovals. Notice that OEM ovals go side to side and the KC go up and down All buttoned up. I gave the subframe bolts a few hugga duggas and a few degrees with a breaker bar. The bolts on the brace themselves got one hugga dugga You can kinda see it from under the car. the clearance seems fine and it sits a lil higher than the bottom of the side skirt While on a test drive after install, body roll and NVH are unaffected. There might be slightly better turn in but that could also be the front strut bar playing a role. The most significant improvement is the reduction of the rear end squiggling around in a turn and under power. The car feels more planted. Also, shifts under load feel crisper. Before, I could feel the rear end shimmying front to back while upshifting under load. Overall, I'm satisfied with both pieces. Are they worth the price shipped? Not sure. Any basic strut bar off ECS should be good-ish. The rear brace could be replaced by the OEM brace for about half the price and would have probably comparable results. More info here: https://f30.bimmerpost.com/forums/sh...6&postcount=29 |
F30_320D_UK215.00 CJ4211566.50 |
03-19-2022, 02:15 PM | #27 |
300
Rep 140
Drives: Melbourne red and Estrol Blue
Sick build!
04-07-2022, 08:34 AM | #28 |
Rep 18
good car bro
04-09-2022, 06:44 PM | #29 |
371
Rep 317
Really wanted to clean up the front end when the headlights are on so I coded out the orange LEDs in the corners. The angel eyes are still on, my iPhone Live Photo mode decided to null those out
I used the following post combined with BimmerCode in Expert Mode https://f30.bimmerpost.com/forums/sh...11&postcount=5 These are the orange LEDs that are no longer on Last edited by squaredphoto; 04-09-2022 at 11:55 PM.. |
F30_320D_UK215.00 |
04-10-2022, 05:56 PM | #30 |
22
Rep 36
Looks awesome mate, I need to get the same mirrors
04-12-2022, 10:51 PM | #31 |
371
Rep 317
Bought a used and damaged 3D Design lip from Japan back in October and recently we had nice enough weather to put it on. Took some finessing but really happy with how it turned out.
Took some photos later in the evening And a regular pic of the front Last edited by squaredphoto; 08-29-2022 at 04:59 PM.. |
04-13-2022, 09:39 AM | #32 |
Rep 11
04-13-2022, 05:41 PM | #33 |
22
Rep 36
Wow 🤩 I need to learn how to make photos
04-14-2022, 07:42 PM | #35 |
371
Rep 317
M Parts Worldwide eBay store:
https://www.ebay.com/usr/mpartsww I've purchased f80 m3 mirrors, e90 m3 mirrors and other parts from them without issue |
04-15-2022, 01:16 AM | #36 |
Rep 6
Nice shots man amazing car!!!
04-16-2022, 10:29 PM | #37 |
Rep 12
Nice build! Liking the progress. Is this your daily driver?
04-17-2022, 02:48 PM | #38 |
371
Rep 317
Thank you! And yes it is
04-18-2022, 07:33 AM | #39 |
Rep 14
Amazing mods, looks elegant
04-18-2022, 04:38 PM | #41 |
Rep 97
Car looks great man!
04-29-2022, 08:39 AM | #42 |
42
Rep 37
These shots and step by step pictures are great. Thanks for theses impressions.
04-29-2022, 12:05 PM | #44 | |
371
Rep 317
There's another vent gauge by Awron but it's really expensive but does look cooler. The P3 option is probably the best bang for you buck option if you want a fixed gauge. Other options would be to use your phone/tablet + app and toggle on some views but that's not for me. |
