08-22-2021, 07:02 PM | #23 | |
Rep 4,184
I'd like to put in a vote for the os giken lsd, if for no other reason than how long long lasting and quiet they are. |
08-22-2021, 07:54 PM | #24 |
Rep 12,738
i don't feel a huge need for more power. i've tracked alongside cars with more power and they don't pull away as quickly as i had expected. i have trouble keeping up in the corners, so that is where i'm focusing efforts. ring and pinion ratio is also playing a role in this- i just don't feel the need at the moment.
obviously, there are a lot of changes coming to the car, and it is going to be a lot lighter. if i do decide to change ratio, its going to be later after i become accustomed to the car's new state. i was sort of torn between the drexler gt4 lite and the OS Giken. i read through florian's lsd shootout thread a few times in the past couple of weeks. i know dogbone is happy with his osg, and OG Shark likes his drexler. pricing is close. function is close. sort of a coin toss, so i went with the drexler because driftflo seemed to like it more.
Instagram; @roastbeefmike
slcook541863.00 |
08-22-2021, 08:34 PM | #25 |
Rep 12,738
one of the things i'm most excited about is the aeromotions wing. their website isn't great at explaining construction and design. i don't expect them to divulge trade secrets, but i've been having conversations via email and i'm getting more and more excited.
basically, they use 6061 aluminum extrusion and carbon fiber. no tubes, no fiberglass, no styrofoam. one of the unique features is a very thin trailing edge on a relatively "plain" looking airfoil, but wind tunnel testing has proven the design. legitimate, full scale, 180mph wind tunnel testing. i first questioned them on how the wings work. it basically has internal sensors and accelerometers to track G forces and read data from the CANBUS. its self contained, but allows settings and tunes. i have the ability to manually activate the drag reduction system, air braking, and set the angle of the wing to be static if required for specific rules. even in the drag reduction setting, it produces downforce. there is just no getting around that- there is an airfoil present on the car and air is flowing around it. if there is a malfunction, it defaults to a specific angle of attack. another thing i questioned them on was the lack of a gurney flap. most wings have them, and theirs do not. below is their copied and pasted response so i don't butcher the interpretation trying to put it into my own words; "Basically, they [gurney flaps] help reduce turbulence when the low pressure and high pressure meet at the trailing edge. They can also help at high AoA (Angle of Attack) when the air detaches (can't follow the surface contour). They're often needed most when the trailing edges are thick, inconsistent, etc. or when the airfoils have avery aggressive 2d shape that means the surface is a "cliff" on the underside. You can of course run them on our wings, but we do two things that make them less necessary; we have a nice and thin trailing edge (because we don't add glass and we have that beefy spar) and we use a sort of proprietary Concave Pressure Recovery system that means the 2D shape at high AoA can keep the air better detached. The Airfoil is designed to create max downforce at 14.2º in clean air so that underside is never perpendicular enough to the rear surface of the car (usually)." incredible stuff. one of the things i'm kinda waiting on depending on budget, is a kmp steering wheel like what slicer sells. bottom two buttons would be MDM and horn activation. top right would manually actuate the air brake to allow for the left hand to rotate and slap the downshift paddle on the left side, and the top left button would be for DRS since the right hand would be doing the upshifts. also kinda depends on how easy it is for me to get in and out of the car with my long clumsy legs.
08-22-2021, 09:46 PM | #26 |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
Sub'd.. Photos of goodies?
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium64693.50 |
08-22-2021, 09:50 PM | #27 |
Rep 12,738
I'm waiting on a ton of parts, but there will be thorough documentation. I don't have anything to really document yet.
DrFerry6734.50 ///M Power-Belgium64693.50 |
08-22-2021, 09:59 PM | #28 |
Derbo Tuning
3613
Rep 3,031
This is going to get good. Speedholes!
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
08-23-2021, 01:14 PM | #30 | |
Rep 1,750
im excited for what roastbeef has for us def one of my inspiration for my car. as well as DRLane and dogbone
08-23-2021, 11:01 PM | #31 |
Rep 674
Running full carbon doors without a full cage isn't smart.
Premium build list but seems like your safety EQ is taking a back seat. Just a shitty harness bar with fixed back seats, carbon doors, no interior, aero... A sub 3000lb E92 is going to be FAST. You should at least run a proper rear half cage. Surprised you're not going with Pinnacle. He uses T45. Strong and light -- 45 lbs. But again, I'd have a cage if I was running carbon doors.
08-23-2021, 11:40 PM | #32 | |
Rep 12,738
i'm not confident a 1/2 cage is going to do any more for me than a harness bar. the brey krause harness bar has been tested to NHTSA standards. can the same be said for the pinnacle 1/2 cage (i couldn't find any info on it)? could the same be said for any 1/2 cage? secondary to that, i've seen the braces within the doors and they aren't that great. i'm not sure what they are going to do for me in anything other than a mild side impact. the schirmer doors also have these "rails", but in carbon fiber. not sure what the strength delta is, but i have no data, and i highly doubt they are tested. there was some discussion about this in the chit chat thread. there were some pretty bad incidents where the doors were just about untouched. would the same safety precautions be mentioned if i bought a shelby cobra with thin fiberglass doors to track? maybe my risk tolerance is a little higher, but i don't see a huge safety lapse here. i'm not saying no to a cage, just not yet. obviously, a cage is safer than no cage. what i'm questioning is how much less safe carbon doors over oem.
SYT_Shadow11517.00 |
08-24-2021, 04:05 AM | #33 |
B.E.
445
Rep 761
Schroth belts here as well.
6 point for both seats, with the narrower Hans version for driver's seat
Current: 2022 TRX & 2010 GT3RS
Past: 2016 M3 Individual Grigio Telesto Pearl, Sakhir Orange/Black Full Leather w/ CF trim, 6MT, ZCP, CCB, etc... Previous: 2011 E92 M3 Melbourne Red on Black 6MT ZCP. --> now 2010 dedicated track car |
08-24-2021, 07:11 AM | #34 |
Rep 12,738
i'm eyeballing these.
https://www.sparcousa.com/product/6-pt-3-steel-pd
08-24-2021, 08:36 AM | #35 |
///M Powered for Life
11517
Rep 10,345
I would not change the final drive.
I curse the day I put a 3.62 in my E90. Acceleration traces show... zero discernible difference. If I could go back, I would keep it stock and run the OEM GTS software. Absolutely never again. The OEM ratios were great. This isn't a piece of shit GT4 with the longest gearing known to mankind, the DCT/6MT M3 is well geared stock. |
08-24-2021, 08:48 AM | #36 |
Rep 5,482
I think a 4.10 is about perfect for the 6MT, especially if you've got a lighter aggressive aero car that starts to make some gains in low-speed. There are a LOT of 50mph corners in the US where 2nd is too much and 3rd is boggy. That plus a ~25" tall rear tire *chef's kiss*.
Here's a picture of Road America with a 4.10 and a short tire: 4th-5th-4th-3rd-4th-5th-3rd-4th-3rd-4th-5th-3rd-4th-3rd repeat With 3.85 and the stock rear tire height: 4th-5th-4th?3rd?-4th-3rd-4th-5th-2ndWHEELSPIN3rd-4th-3rd-4th-4th-5th-3rd-4th-3rdbooooggggg just pit this sucks heh Funny enough, BMW Motorsport agrees with that assessment, heh 3rd gear is a lot shorter on the DCT , so just running a 295/30-18 would do most of the work, for basically free This is a rad build from a person who has the right mindset. A rad *first* build. Nobody starts out with the boring ol' cage on their first track build on a platform. But I've seen oh about a hundred peoples' second cars get the cage first. So, if this is your practice kid, then go for it, heh. Nobody likes to do that because it's unsexy and costs bucketloads of money, and a bad crash means you not only write off a production tub but also a bespoke crash structure that probably can't be re-used. It's a huge commitment for a low probability event, so I understand why people don't do it. But that's how it's done, if you have any inkling you might start to get nervous about safety later on, do it now, get to the choppa, get down. I would estimate at least...100lb of titanium hardware's worth, or 500 step-bits, lol. The E9x isn't strong in the footwells and fender/tire crush zones like modern cars and an offset hit on the front end will wreck your legs and feet. But again, relatively low PK on that. The nightmare #1 dig-in and end-over-end flip off at 100mph, and #2 a brake failure, are the major ones. I think a quality roll structure in the back half can address #1 to some extent (that's why you'll see OEM's do this on a street-homologated production car), but it doesn't do much for #2 except give you a good place to mount your harness to perform optimally in the event of a brake failure. Anyway, regardless of what you decide to do for crash structure, take a look at right-side nets, can be beneficial even on a "full-containmnet" seat and relatively low-impact, and even a half-cage gives you somewhere to stick it to. Sounds like you'll have the dash out at least once so you could do your forward mounting point then
08-24-2021, 11:40 AM | #37 | ||
Rep 1,750
inb4 this becomes the chit chat thread... lmao
DrFerry6734.50 |
08-24-2021, 04:13 PM | #38 |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
I have 3:45 in mine - with the DCT - and it's been an okay mod IMO (for the street). I didn't go with a 3:62 due to the chance of over-rev on downshifts if the DCT ECU wasn't re-flashed. I think the stock DCT Diff ratio is a 3:15 so it was quite a decent change to go to the 3:45 given the 7 speed DCT box ratios. Just sayin'..
08-25-2021, 03:20 PM | #40 |
Rep 580
Love this build and will be looking forward to seeing it come together!
I gotta say I am a bit envious of the people that can front the time and energy (and money of course) to put something like this together and actually use it at the TRACK where it is meant to be used (who cares about canyons?) on a regular basis. Perhaps one day when the kids are much older and hate having me puttering around... but today nor tomorrow is not that day. In the mean time, I'll live vicariously through you and dogbone. I would probably go the same exact route for a build - lightweight, focus on mechanical grip, squeezing every last ounce out of a NA engine.
2013 E92 M3 Mineral White Fox Red / Black
08-25-2021, 06:01 PM | #41 |
Rep 12,738
You guys ever see carbon fiber fuel service lid covers?
08-25-2021, 06:06 PM | #42 |
Rep 3,415
Beautiful! I assume nominal weight savings over aluminum?
Not a Doctor, those are just my initials.
08-25-2021, 06:15 PM | #44 |
Rep 3,415
Now I'm curious how much Mrs RB truly knows about this build.
