07-09-2022, 10:56 AM | #23 |
Great Teacher
1141
Rep 1,322
Drives: 06 e91 325ix
Yep, but even that was too much for spousal approval after buying an amp and earthquakes last year.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
07-09-2022, 09:45 PM | #24 | |
Rep 666
can you recommend an equivalent or better substitute for the earthquake sound at lower or if more, slightly more price point?
how about groundzero sub? Quote:
07-10-2022, 04:24 AM | #26 |
Rep 666
for match up 7 bmw installation, do I need to disconnect the car battery first? or just plug and play? when i installed my EVO Head unit, i didn't disconnect my battery, just straight unplug the HU quadlock harness, and it was okay.
Do i need to do all of these steps (removing the rear plastic cover, 12V outlet, anchor, and trunk hinge cover) just to access the amp? if so, that's a pain in the ass if i need to tune the amp. any tips on how to run the USB cable for easy tuning access? Thanks. Last edited by dangerus_car; 07-10-2022 at 07:49 AM.. |
07-10-2022, 04:48 AM | #27 |
Great Teacher
1141
Rep 1,322
Nope. pNP.
07-10-2022, 08:50 AM | #28 | |||
56
Rep 121
https://www.amazon.com/Extension-AIN...dp/B09HB2P8RX/ |
johnung4554.00 |
07-10-2022, 09:22 AM | #29 | |
Rep 666
07-10-2022, 01:38 PM | #30 | |
56
Rep 121
When you want to tune the amp, just remove the plastic cover, you will see your USB cable right under it, pull the USB cable, attach your USB extension (optional), attach to your laptop, and tune the amp. |
johnung4554.00 |
07-10-2022, 03:16 PM | #31 | |
Rep 666
Ah okay. I thought you run the usb end all the way to the front along with the extension. I was thinking this way earlier but wasn’t sure. How about the uc3 remote? How did you run the wire all the way to front? Thanks. |
07-10-2022, 05:25 PM | #32 |
56
Rep 121
Yes, you need the wire for the URC.3 to go all the way to the front.
Watch the steps in this video from 8:25 to 10:45 to give you the steps on how to do it. The video is for installation of a backup camera and it's running wires on the passenger side instead of the driver side, but the idea and steps are exactly the same if you want to run the USB or URC.3 wire all the way to the driver. Just do the steps on the driver's side. |
07-10-2022, 08:28 PM | #33 |
Rep 666
i just installed the amp, and while reading the manual, the #1 port called 'auto remote' comes as ON from factory.
in the manual, it says the following The feature should be deactivated (Auto Remote = off) if the UP 7BMW replaces the amplifier of the BMW HiFi sound system (676) or if there are e.g. disturbing noises while switching on / off the amplifier. well, we buy the 7BMW to replaces the amp, then why does it come from factory turned ON? anyone running their wireless control yet? https://www.audiotec-fischer.de/en/b...s/wifi-control Last edited by dangerus_car; 07-11-2022 at 07:26 AM.. |
07-11-2022, 05:29 PM | #34 | |
56
Rep 121
But the manual posted on their site also has the same mistake you point out ... very odd. You should leave Auto Remote "ON" |
07-11-2022, 07:59 PM | #35 | |
Rep 666
direct link of their PDF it seems like from the title of the PDF, this manual is updated on 25 sept 2018, i wonder if yours is an earlier version or later version as it seems the web version adds the OFF if replacing sentences. Also the printed manual that comes with the amp is exactly the same as the website. As of now, i m leaving it OFF due to evidence I found and also I am going to refer to the manual they have on the website as it's clearly they added this line compare to the manual you have. But I am also reaching out to them to clarify on this issue. i m not sure now whether it's ON or OFF. what's the purpose of this auto remote? also i take a look at one of the youtube, when this guy unboxing the amp, it clearly comes in OFF mode. see attachment and see the youtube at 10:20 mark when he was unboxing it one more evidence, take a look at the manual page 20, the illustration has the auto remote in OFF position Thanks. Last edited by dangerus_car; 07-11-2022 at 08:34 PM.. |
07-11-2022, 10:10 PM | #36 |
56
Rep 121
it's fascinating that Audiotec Fischer has gone back-and-forth on this setting, based on their manuals, pictures, videos, how they ship the product.
For example, in the PDF manual on the site, the one you sent the link to, you can see the picture below on page 16: it's set to 'ON'. My printed manual is exactly like yours. The PDF they have on the site is exactly as you describe. You are correct that based on the printed manual and the PDF currently on the site, it should be 'OFF'. However, at some point I downloaded a clearly different version of the PDF, which I'm also attaching. And based on their description of the functionality, it should be 'ON' I'm stumped. Please let me know what you find out from Audiotec Fischer. |
07-11-2022, 10:28 PM | #37 |
56
Rep 121
I guess I should have asked you: are you using the "REM" (#8 on the picture above) in order to turn on the amp?
If you are using "REM" to turn on the amp, then your Auto Remote should be "off". If you are not using "REM", then Auto Remote should be "ON" |
07-12-2022, 01:37 AM | #38 | |
Rep 666
This is the direct link for the MatchUp 7 DSP Based on that manual, this is the text verbatim and it's exactly the same words as your manual. 1 Auto Remote The UP 7DSP will be turned on automatically if the highlevel inputs of the System Connector 1 are used or if a signal is applied to the remote input (REM) terminal. The Auto Remote switch allows to activate / deactivate the automatic turn-on feature of the highlevel inputs of the System Connector 1. The feature should be deactivated (Auto Remote = off) if there are e.g. disturbing noises while switching on / off the amplifier. Note: The automatic turn-on feature is activated ex works (Auto Remote = on). If the automatic turn-on function is deactivated it is mandatory to use the remote input (REM) to power up the amplifier! The high level signal will be ignored in this case. so i think it's safe to say that auto remote should be OFF for Match Up 7 BMW According to online youtube (as seen in my previous post) and tutorial, i just use the harness provided, and that's it. I don't have to use the power, etc. do you use the REM? I think REM is used if you are using the match up 7 as a separate amp to power something else? I just installed the amp with auto remote OFF and I load the factory tune setting for BMW limousine. Damn, I can already hear some improvement, more low end. These plug is used only when you are connecting an external amp in addition to Match Up 7 BMW. Did you use any of these two plugs? by the way, i only received three screws. and these, do you receive the same thing as mine? Last edited by dangerus_car; 07-12-2022 at 07:47 AM.. |
07-12-2022, 06:27 AM | #39 |
56
Rep 121
I did not use REM, just the OEM harness.
I'm pretty sure i received 4 screws, one for each corner, not just 3. Look at your mounting plate and see how many spots for the screws. |
07-12-2022, 07:51 AM | #40 | |
Rep 666
so are you going to turn off the Auto remote now that everything is clear? |
07-12-2022, 08:18 AM | #41 | |||
56
Rep 121
If you use the OEM harness, and you don't have a second amp, you shouldn't need to use either one of those. I didn't use any of those two plugs, I am using the OEM harness only. |
07-12-2022, 09:12 AM | #42 |
56
Rep 121
Summarizing for future readers of this thread.
The Match UP 7BMW needs a signal in order to turn on. There are 3 different ways it can receive this signal:
The Auto Remote switch controls which of these 3 options is used:
If you are replacing your HiFi amp (676) and using the OEM harness + the Match up 7BMW harness, the pin 25 will carry the turn on signal, so you can leave Auto Remote to OFF. Last edited by wildcat10; 07-12-2022 at 09:25 AM.. |
FastFrog143.50 |
07-12-2022, 11:31 AM | #43 | |
Rep 5,413
If for some reason, it is desirable for you to add a wire connection to trigger an amplifier on/off, there is a very easy way to do so in the F3x trunk. Just pull up the floor panel in the trunk to expose the fuse block mounted in the floor. Fuse #146 works perfectly with the ignition to turn an amplifier on/off. See attached photos. Almost any auto parts store will have a Mini-Sized Add-a-Circuit and Mini-Sized plug-in fuses. You only need a 1A or 2A Mini fuse. You also need maybe a 12 foot length of copper stranded wire (not solid copper wire). Technically it only needs a really thin 20-22gauge wire but I get 18 gauge because it's just easier to work with. Auto parts stores sell it but the least expensive place that I've found is a Lowe's hardware store. Also pick up some heat shrink splice connects as in the photo (from Walmart) Installation is simple. Please refer to photos. 1) Use the fuse puller located in the block to pull out the 5A fuse from Fuse Location #146. 2) Plug that 5A fuse into the standard location in the Mini Add-a-Circuit. 3) Plug the 1A or 2A Mini fuse that you bought into the slot in the Mini Add-a-Circuit that feeds it's built-in wire. 4) Take one of the heat shrink splice connects. Crimp the wire from the Mini Add-a-Circuit into one end, and strip and place the end of the 18 gauge wire into the other end of the splice connect. Use a crimping tool or a pair of pliers. 5) Use a lighter flame, heat gun or hair dryer to shrink the tubing ends around the wires. 6) Make sure that the ignition is OFF. Plug the Mini Add-a-Circuit into Fuse Location #146. 7) Run the 18g wire from the fuse block to your amplifier location. Run around the perimeter of the trunk rather than across the trunk floor to avoid any future stress/weight being placed on the wire. Secure with duct tape or tie-wraps. 8) Set the amplifier to NOT auto-detect. Instead set the amplifier to remotely detect ignition on/off through whichever wire port it uses for this function. 9) Cut, strip and connect the end of the 18 gauge wire to that port on the amplifier. 10) Turn on the car ignition to test whether it triggers the amplifier to turn ON. |
wildcat1055.50 |
07-12-2022, 01:11 PM | #44 |
Rep 666
I notice that to install earthquake, you need to splice wire from the BMW harness.
is there a way not to splice wire and instead use a pin at the end of the harness to extend the wires? for example if the harness is female, then use a male pin at the BMW harness to extend the wires. |
