12-03-2022, 08:51 AM | #23 |
112
Rep 123
Sorry if this hijacks the thread but question for you hive. Does anyone run more than -3.5? Had mine aligned with full negative (Vorshlag) and shop measured -4.5 with zero toe. Won't be able to test until next weekend. Thoughts?
12-10-2022, 10:39 PM | #24 |
Retired Curmudgeon
3000
Rep 4,075
I don’t think the e9x chassis needs that much camber, but I’d need to look at tire temp data before I dismiss it.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
12-13-2022, 04:47 PM | #25 |
39
Rep 129
Just to add to this,
I’ve recently been running 3 degrees neg camber front and 2.25 degrees neg camber rear for around 3000kms + 3 track days and tire wear has been very good on 200TW tyres. Ideally I’d want to run a little more in the front maybe 3.5-4 degrees for perfect track wear but I felt this was the most aggressive compromise. In regards to toe out on the front, I tried this recently after 10+ track days running zero and didn’t like it tbh. It was much more eager to turn in but in turn also very nervous and unstable at speed on the front, probably good if you’re at a very tight track but most of the tracks near me have some pretty long straights and sweepers. I changed back to zero toe at front. The M3 chassis is so well balanced that even a small 1/16th of a toe change- you can feel if you’ve had experience with the car. The other thing to mention as well, you will lose an ever so slight bit of acceleration with front toe out, think of it like extra grip/drag on the front axle.
2011 E92 M3 - Mineral White - Pure Edition I
01-30-2023, 02:19 PM | #27 |
39
Rep 191
Switched back to stock alignment after running two track days on PS4S. I felt the front was sliding a lot and couldn't really figure out if it was my entry speed, technique or the tires that were giving up.
Going to start the year next weekend with a 200TW(RE71RS) tires being the only change. Looking forward to build up from there and work on the alignment as needed. |
01-30-2023, 02:59 PM | #28 | |
Rep 3,415
Not a Doctor, those are just my initials.
01-30-2023, 05:14 PM | #29 | |
Rep 1,597
01-30-2023, 10:14 PM | #30 | ||
39
Rep 191
Do you think I should keep the alignment specs the same and do a day with new tires? Last edited by ashutoshkotha; 01-30-2023 at 10:20 PM.. |
01-30-2023, 10:19 PM | #31 | |
39
Rep 191
At this point I felt completely lost and I thought I'd revert back to stock before making further changes. Any thoughts on what I could do? |
01-30-2023, 10:39 PM | #32 | |
Rep 1,750
you'll just need to be more mindful of your tires every session. as a beginner jumping to RE71RS from PS4S is a huge leap.... just saying. you'll end up relearning how to drive more than actually focusing on driving.
01-31-2023, 12:10 AM | #33 | |
Rep 3,415
And the slide is mid corner? I think you’re being impatient and getting back to throttle early and inducing understeer push. Which results in you likely pulling harder with the wheel and car doing less but dragging tires. Is this generally on the longer corners? Might examine the line, if you’re at throttle before apex, and most importantly where are you pointing at apex? Meaning is the car fully rotated for the exit? Do you capture any data? A simple speed trace would likely tell you a lot. If you’re going out with new tires this behavior of pushing/dragging will surely roast them in no time.
01-31-2023, 03:36 AM | #34 | |
Rep 1,750
ashutoshkotha38.50 |
01-31-2023, 11:18 AM | #35 | |
39
Rep 191
All this is at Chuckwalla CW. I was consistently at 2:08 and wasn't improving. This makes a lot of sense when I read it, I was probably trying to get on the throttle early and trying to drag it out without the rotation done. I think I'm doing these two things wrong: - Getting early on the throttle to correct the understeer and point to Apex - Carrying too much speed into the corner and not being able to manage that though the Apex. I will try and improve on this next weekend. Last edited by ashutoshkotha; 01-31-2023 at 11:29 AM.. Reason: adding info |
01-31-2023, 11:25 AM | #36 | |
39
Rep 191
Yes, It's definitely a huge leap. I felt PS4S were holding me back for some reason in terms of braking, grip levels etc. I might be totally wrong here. There are too many factors to even figure out what's going wrong including my driving technique. I wanted to dial in a few things as a standard setup and start this year from there. Hoping to learn more consistently that way. |
01-31-2023, 12:05 PM | #37 | |
Rep 1,750
especially on our heavy car in oem format. you're looking at like 37psi cold 42psi hot? also always MDM off..
01-31-2023, 12:10 PM | #38 |
39
Rep 191
Got it. I was always trying to be at 35/36psi hot.
01-31-2023, 01:26 PM | #39 |
Rep 3,415
Those are the ideal hot pressures - 1 psi per 100 lbs of weight is good starting point. Don’t fall into the running low pressures when just starting out, instead give yourself a cool down lap or two. If you go super low, it’s likely with the lack of negative camber you’ll roll the corners and cause more premature wear. Just take a cool down lap from time to time. It’s actually lovely practice to see if you can run a lap without the brakes. When you’re not coming as fast into a corner you’ll find you actually go through the corner at a higher min speed. Because you’re not panicking and over slowing for entry. And then you don’t have to get on the gas as early because you over slowed. And thus some of your understeer will be resolved . Try it you’ll be surprised.
Otherwise best to get an app, a more sensitive gps, and capture data / video. Work with online coach (Blaze is great) or better in car instruction. Careful with taking internet guidance on running traction control “mdm” etc on/off. That’s a personal decision and you alone should make it. Just note MDM can impact brake life as it’s constantly running to save you. Good luck
omgzirra_exe1548.00 ashutoshkotha38.50 |
01-31-2023, 04:31 PM | #40 | |
Rep 1,750
admranger2999.50 |
01-31-2023, 04:54 PM | #41 |
Rep 3,415
I’m saying to each their own I know you’re a strong bowler when the bumpers are deployed.
01-31-2023, 06:21 PM | #42 | |
Rep 1,750
i did start with MDM though nothing wrong with it.
02-01-2023, 11:47 AM | #43 | |
39
Rep 191
Going forward I'm always going to start recording laps and get some kind of instructions. it is super hard to explain without a reference lap. On the MDM. Yes, going to be careful there. I've been trying different things on/off. Also, reading a lot inputs on what effects the braking and what numbs down the cornering speeds etc. |
