DME issue or Fuel injector issue (Solved, it was the DME!)
10-09-2023, 10:26 AM | #23 |
112
Rep 347
ahh.. I'm not very familiar with DME software issues.. I'd imagine yes the Vin would stay with the DME along with the past history of the original DME. Im somewhat stumped as to what your bank 1 fuel cut is. What are your shadow codes on your vehicle? Did you pull plugs and clean them and check for fuel? The injector MOSFETS/transistors? If you're running msd80 it has been known to fry the DME and MOSFETS.
10-09-2023, 06:03 PM | #24 | |
76
Rep 231
No shadow codes in MHD Only the injector activation codes 2E30, 2E31, 2E32, 30AC, 30AD, 30AE |
10-09-2023, 06:19 PM | #25 |
112
Rep 347
If you've tried swapping injectors, plugs, coils, 02 sensors and the codes persist then you're more than likely looking at a connection/software issue. Activation code means its not reading.
10-09-2023, 06:22 PM | #26 |
112
Rep 347
Try swapping the non index 12 injectors to a different bank i.e 4 or 5 or 6 and see if the codes follow. Are the index 1 injectors on 2 and 3?
10-14-2023, 03:46 PM | #27 |
76
Rep 231
So i finally solved the issue, my DME was defective. I picked up a used MSD80 DME from a local junk yard and had it cloned from my original DME by a local BMW shop that does reprogramming. I didnt want to spend a ton of money on the DME in case it wasnt the issue. (found this person through Ebay, it was $100 to reprogram and the used DME was $100). Plugged it in and it fired right up.
I could have done an upgrade to an MSD81, as a matter of fact i had already picked up a used MSD81 but decided against the upgrade for now as I didnt want to run into any issues with the donor cars vin still in the programming affecting MHD and/or NYS inspection. I may still upgrade in the future. My issues started one day when i went to fire up the car ('07 335i) and i was greeted with the half engine light and running on 3 cylinders. When scanning for codes, i kept getting only these codes : (no other codes or shadow codes) 2E30 - DME: fuel injector, cylinder 1 activation 2E31 - DME: fuel injector, cylinder 2 activation 2E32 - DME: fuel injector, cylinder 3 activation 30AC - DME: fuel injector, cylinder 1 activation 30AD - DME: fuel injector, cylinder 2 activation 30AE - DME: fuel injector, cylinder 3 activation The DME was shutting down power to the bank 1 fuel injectors, i verified this with a test light. The injectors were receiving power/ground ONLY during cranking and once fired up, the DME was shutting down power to the bank 1 injectors....causing the engine to only run on the rear 3 cylinders. Here is everything i tried to figure this out: -checked for water intrusion into the DME, no water intrusion issues -tested the mosfets and they all tested ok. -tested continuity on all wires from the DME to the coils & Injectors, checked all the grounds, all tested ok. -Flashed DME back to stock from MHD Stage 2+, still same issues. -Monitored low & high fuel pressure, all checked out ok. -I have the Bimmerlife Audi R8 coils so i removed them and reinstalled stock coils and swapped in known good plugs in bank 1, still same issues. -swapped and coded 3 known good injectors in bank 1 and still same issues. -swapped bank 1 & bank 2 pre cat O2 sensors, still same issues. -Picked up a used MSD80 DME and had it cloned with my original DME's stock file, this solved the issues. Car is running great again! In hindsight i could have immediately replaced the DME with a cloned MSD80, but i wanted to troubleshoot the issue first before dropping money into it. After all, the codes above all do start with "DME" ! So i guess something in the DME was fried that controlled the bank 1 injectors, i guess it could be due to age, the DME is now almost 17 years old. The mosfets were not the issue, i tested them and another person (who replaces mosfets as a business) also tested them ok. I probably will still upgrade to the MSD81 since i already picked one up. Hope this helps someone in the future. Last edited by Rube; 10-14-2023 at 04:01 PM.. |
SlowE92112.00 TheMidnightNarwhal2683.00 |
10-14-2023, 04:24 PM | #28 | |
112
Rep 347
2007 E92 335i - MHD, Turbo Technics 19T's
2008 E60 535XI - JB4 2010 E92 335i - JB4, Borg Warner EFR 8374 |
10-14-2023, 05:02 PM | #29 |
76
Rep 231
10-14-2023, 05:22 PM | #30 |
650
Rep 2,020
it has been mentioned few times it doesnt have to be mosfets. So blindly replacing mosfets doesnt help. It can be the power supply unit in dme, in which case replace dme. Was the case in my 535i as well...
335i e92 TPC 19Ts
10-27-2023, 10:39 PM | #32 |
Rep 85
I’m in this boat right now.
Just tested 6 index 1, no leaks. New seals and decouplers, new spark plugs and eldor plugs put those in less thank 500 miles ago). Reset adaptations. Turn on the car and immediately injector 4 voltage went to zero. I then swapped the injector wires between 3 & 4, the problem moved to injector 3. Mosfets all check out with continuity and ohm tests. Oddly enough, when I tried again to start the car 4.5.6 all gave activation codes. I just picked up an MSD81 and will try and get it cloned tomorrow and hopefully that fixes this. Did you get voltage readings by just using a meter probe on the injector plugs and having the key set to ignition? I might try to check the wiring and/or pins at the DME, but initial testing looks fine. |
