12-14-2008, 08:05 PM | #23 |
Rep 682
yeah I concur.. probably not tripped code in ecu... again, no cats = bad 02 readings.
Lesson to be learned here.. we shouldnt be attempting to put anything past the dealers, if you legitimately blow your engine or something you should own up to it, but inthis particular case, I dont think anything is REALLY wrong cept you dont have the o2 sims. Dont give them any ammo to even fight with. |
12-14-2008, 08:40 PM | #24 | |
Rep 1,245
12-14-2008, 08:43 PM | #25 | |
HALA MADRID!
941
Rep 2,879
I'm with you, I put in mods that I do myself, and feel comfortable taking them off in case I need to take the car to the dealer.
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
12-14-2008, 09:14 PM | #28 |
Change for a Nickle?
14
Rep 875
The O2 sim creates a difference in the reading between the upper and lower O2 sensors, which results the the computer believing that the cats are doing their job. The O2 sim is just a set of resistors.
"I tasted death many times on the river today. Do you want to know what it tasted like? Do you REALLY want to know? Well I'll tell you then: it tasted like BEEF JERKY." - unknown paddler 8/1/09
12-14-2008, 09:19 PM | #29 | |
Rep 879
did you leave the o2 sims in the ECU compartment when u took it in?...if so thats why...haha....you showed the proof of tampering with the ECU
Current: 2023 M2
PAST: 2022 Audi E-tron GT, 2021 Lexus LC 500, 2020 Maserati Ghibli S, 2015 M235i, 2014 Audi TTS, 2012 Lexus IS-F, 2009 BMW 135i, 2004 VW GTI |
12-14-2008, 09:22 PM | #30 |
28
Rep 932
SI B 12 20 08
Engine Electrical Systems June 2008 Technical Service SUBJECT N54 - Various Complaints Caused by Aftermarket "Tuning Kits" MODEL E90, E92, E93 with N54 engine E60, E61 with N54 engine E82, E88 with N54 engine E71 with N54 engine SITUATION I The customer may complain about an excessive muffler noise; "backfiring" into the intake manifold; high (increased) engine oil/fuel consumption; illumination of the "Service Engine Soon Light"; or an excessive battery draw. Fault code "2D18-Manipulation protection, air mass" may be stored in the DME, indicating an implausible airflow. To prevent possible engine mechanical damage due to increased turbocharging pressure, the DME will limit the maximum available torque to the nominal torque value of 400Nm. SITUATION II The customer may complain that the vehicle couldn't pass the state emissions inspection, where scanning of the OBD readiness codes is part of the inspection procedure. The GT1/DIS or aftermarket testing equipment indicates that the EVAP system is a "not supported" function of the vehicle's OBD control system. Also, various complaints regarding the cruise control being inactive; the battery draw message displayed in the Control Display; or incorrect muffler flap operation may be encountered. CAUSE I An aftermarket engine performance tuning kit, "turbo-tuner control module" (piggyback box), is (or was) installed in the vehicle. Depending on the manufacturer, these modules are plugged directly into the TMAP (Temperature / Manifold Ambient Pressure) sensor or into the DME harness in the E-box. The modified (erroneous) air intake pressure signal supplied to the DME causes an increased turbo boost. In some cases, these modifications also include alteration to the waste-gate vacuum plumbing, which may cause various vacuum supply problems. CAUSE II The vehicle's DME was reprogrammed with an aftermarket "N54 performance software calibration". As a result, various DME OBD II-relevant diagnostic functions are inoperative, or their functionalities are limited. Examples include diagnostic of the purge system; map-cooling thermostat; engine temperature sensor; oxygen sensors; and the functionality of the evaporation system and exhaust flaps. INFORMATION With the integration level of E89X-08-03-530 or higher (introduced with Progman V29.02.00), any alteration to the TMAP sensor signal ("piggyback box") is detected by setting the DME fault code 2D18 ("Manipulation protection, air mass signal plausibility"). In such a case, the maximum engine torque cannot exceed 400Nm. Aftermarket N54 DME software modifications usually do not change either programmed or basic DME part numbers, so it is not possible to identify this alteration via DIS/GT1 DME identification pages. In certain cases, the MSD80 DME software modifications can be detected by executing DIS/GT1 test module "S1214 NG6OBDII/Read codes" (reading of the OBD readiness codes). If the readiness code for the "Fuel Tank Ventilation" shows "XXX" (instead of "yes" or "no"), this is an indication that evaporation system function is not supported by the DME and the original BMW software was altered. (In this situation, when using the aftermarket scanning tool for checking readiness monitors, the Evaporation System status would be displayed as "Not Supported".) In such a case, the vehicle is not compliant with the federal (EPA) and state (CARB) emissions anti-tampering laws. WARRANTY INFORMATION Any repair or diagnostic cost incurred by a component and/or system failure as a result of an "N54 aftermarket engine tuning kit" installation is not covered by the terms of the BMW New Vehicle Limited Warranty. Moreover, modification of the vehicle or installation of any non-approved performance accessories or components attached to the vehicle, which alters the original engineering and/or operating specifications, or which results in damage to the other original components, voids the warranty coverage on the affected original Drivetrain and Emission Control components. In general terms, the BMW warranty on Drivetrain and Emission Control components is void due to a modification where the modification, alteration or installation of a non-approved aftermarket part was responsible for the failure. Please make sure to inform BMW customers considering the purchase of an aftermarket "N54 Engine Tuning" kit of the above legal, technical and warranty implications. |
12-14-2008, 09:32 PM | #31 |
Rep 786
Thanks Mad dragon. Thats probably a good piece of info for everyone to have!!!!
'09 135i 6MT : Space Grey/Black ette : Cold Weather Package : Sport Package : Glacier Silver Aluminum Trim : iPod and USB : Nav : HD radio : Premium hi-fi system
12-14-2008, 09:32 PM | #32 | |
Rep 879
so it seems the code actually shows up as a "service engine soon" light....because the stock car can limp mode.
Current: 2023 M2
12-14-2008, 09:54 PM | #33 |
Most interesting Roadster
70
Rep 2,224
Drives: '01 Z3.0 Roady;'10 C300 Sport
I guess the next question is, if you remove the SSTT before visiting the dealer, can you wipe the code with an OBD II tool?
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh |
12-14-2008, 09:54 PM | #34 |
Rep 5,970
12-14-2008, 10:05 PM | #35 |
Rep 2,042
I always was suspicious of the claims made about the SSTT not being able to be detected...it may not be able to be detected per se, but it appears it can actually set off a fault code.
12-14-2008, 11:17 PM | #38 |
Rep 5,970
12-14-2008, 11:22 PM | #39 | |
Rep 5,970
They didn't even know what the simulators were when they called me the first time, or that I didn't have cats on the car. The tech pulled the codes, called BMW, and they told him to start digging. That's when they found the O2 sims. It's possible that my car has set these codes because I've driven it at altitude (I've had it clost to 5500' ABSL) with the SSTT installed. Maybe that's enough to push it beyond the factory limits. Just a theory. :iono: |
12-14-2008, 11:22 PM | #40 |
Rep 2,013
12-14-2008, 11:28 PM | #41 | |
Rep 5,970
I know all about MMA, but do you really think I'm going to win a case where I've alted the emissions systems on the car to increase performance, and now have a misfire code set for cylinder two? BMW has a very easy out on this, and that is that the aftermarket products have altered the operating parameters beyond what they designed for. MM was intended to allow consumers to use aftermarket oil filters and such things, not to modify the car for additional performance. It's a no-win situation IMO. |
12-14-2008, 11:32 PM | #42 |
Rep 879
you have to take it to a shop with a GT1 reader for BMW codes to clear it...but it is possible....kinda late now tho....but i would have taken the DPs off the car and the sims out.
Current: 2023 M2
12-14-2008, 11:46 PM | #43 |
Rep 1,159
it's gonna be a tough one for you. Either SSTT or the O2 sim might screwed up your air/fuel ratio hence the misfire. O2 sensor failing is one reason for misfires.
There are bunch of other reasons for the misfire that's not caused by the SSTT and/or O2 sim, but I don't know how you could identify that w/o taking out the DP and O2sims and reseting the computer. |
12-14-2008, 11:53 PM | #44 | |
Rep 5,970
Oh I know what's causing the misfire. It's a faulty fuel pump. I've had that problem since before any of the mods were installed. The problem shows up on long trips when I'm around half a tank of fuel, and filling the tank up fixes it every time. I'm betting it's the low pressure fuel pump that's in the tank. There was another member who had that failure as well, I'm just not going to be able to have it replaced under warranty. |
