02-17-2009, 06:26 PM | #23 |
17
Rep 63
wow, thanks for all the input. looking around youtube, i found this, it's another good video showing the footwork for heel-toe downshifing...
[SIGPIC][/SIGPIC]
02-17-2009, 07:00 PM | #24 | ||
My ride: bimmergirl84
22
Rep 302
[quote=mugennosora;4506626]1. pro-car usually has ABS, it won't lock up.
2. going that fast i don't think they would gear brake for any reason, it's asking to drift...heel toe doesn't gear brake, you rev to match the gear. 3. again back to 2. engine brake, gear brake how ever you call it. 4. if not 1,2,3 then can't be 4. 1) No they don't, what car are you talking about? GrandAm cars? No. ALMS cars? No. Any Formula car? No. And besides that, even if a car has ABS, it doesn't react until AFTER the tire has locked. 2) No idea what you're talking about, I said you DON'T want to use the engine/clutch to slow the car down. Quote:
02-17-2009, 07:18 PM | #25 |
Master Wang
37
Rep 444
I don't think brake slow down then rev with out heel toeing is going to lock it up, nor has ever seen it or hear it before...sorry my mom's friend is pro GT-R restoration/driver in japan, he was the one that taught me how to do heel toe, and i also learn that there is many way that i can do the same with out heel toeing...and if you had ABS and you still lock up, you need to throw away your car. seriously I've been driving my 1 with out heel toeing, simply just brake, then clutch and rev shift, it does the same, and it'll not lock up the rear.
proof me wrong show me someone lock up the rear and blow up their valve and burn their clutch from not heel toeing and still drive fast. (without miss shifting, or jam their gear from down from 4-2 or 3-1) cornering angle (fix under or over steering) i would like to see a F1 heel toe, because F1 or those super cars don't use foot clutch. so why would you heel toe?????? and i missed read the 3rd one, it's my fault..i was trying to said, if you heel toe that wouldn't happen.... you are comparing different kind of brake concepts and use.. we're are talking about driving that actually involves the use of heel toe.. i don't see why driving in circles would need heel toe... Last edited by mugennosora; 02-17-2009 at 07:47 PM.. |
02-17-2009, 07:47 PM | #26 |
17
Rep 63
While were at it, I see the phrase "rev shift" being thrown around alot. What exactly is that? BTW, thanks to everyone for replying to this thread, this is such a useful forum to be a part of for someone who is just getting into motorsports, like me. Thx!
[SIGPIC][/SIGPIC]
02-17-2009, 09:16 PM | #28 |
Rep 242
I would really not try to go against J_Tyler when it comes to driving technique. He's almost certainly a better race driver than any of us here.
Check out the video in his signature. If you do not downshift mid-corner (while you are decelerating) you have to do it coming out of the corner (accelerating). The sudden application of power to the wheels will almost certainly break traction. When you do it midcorner you are increasing revs but (by the time you let the clutch out) you are at zero throttle and therefore actually producing very little power. This is in addition to the reasons already given in the other posts =P For us big-footed americans (no offense intended, it's simply anatomy) don't think of it as heel-toe, think of it as ball-toe. You use the toe part of your shoe to break (which can be funky to get used to) and the ball of your foot to blip the throttle. It's great for you if you have small enough feet that you can actually use your heel, but most americans (that I know, anyway) simply have feet too big to do this, and if they try it just messes everything up. To the problem with being unable to get the stick into gear: It's easy when quickshifting to fail to depress the clutch all the way and hold it until the stick is through all the gates and synchros. I practice my heel-toe (ball) downshifting every nice day on my break at work and I can't tell you how many times I've left the clutch up a bit and either ground the gear (which sounds like you've completely bombed your tranny... scarry as hell) or simply been unable to get the stick in. - You have to make sure that the revs are high enough. If the flywheel speed is not equal to the input shaft speed you put tremendous pressure on the clutch and can literally blow it to pieces (I've seen it). - And you have to make sure the clutch is ALL the way down or you can create additional wear on your gates and synchros and can actually damage the shift linkages by applying excessive force as you try to force the stick into gear. Also, if the cluthc isnt all the way down and you dont get the stick all the way into gear when you let up on the clutch you will be thanked by some nasty sounds and some nice wear on your tranny. |
02-17-2009, 10:45 PM | #29 |
Rep 99
It's obvious that some folks here have a great deal of knowledge, while others are "post whores".
To the OP, you might get a copy of "Going Faster! The Skip Barber Racing School". It's about $15 used on Amazon. It's not a Bible, but at least they are credible. Some info here does not meet that criteria. DJ
2009, tuned 135i, gone, but not forgotten.
Fear of dying exceeded thrill of speed. (and coordination.) |
02-18-2009, 07:32 AM | #30 |
Rep 475
The rears would not lock, but a significant amount of wheel speed would be lost due to engine brake. The wheels would be spinning, just not at fast as the car is traveling so possible slide could occur.
///M 135i
02-18-2009, 08:17 AM | #31 | |
Master Wang
37
Rep 444
02-18-2009, 08:19 AM | #32 |
Master Wang
37
Rep 444
thank you, if the rears locks up J-Tyler might as well takeout his ABS controller and save some weight in his car, because in his case, ABS does jack for him.
02-18-2009, 09:05 AM | #33 | |
Rep 456
I have said book. It does have a section on heel-toe downshifting, the technique to do it and why you should do it. A good read indeed. |
02-18-2009, 09:16 AM | #34 |
or Rosencrantz
Rep 455
Drives: 2008 Montego Blue 128i
And a better authority then a 26 year old driving on public Roads. Everyone thinks they are an awsome driver on the street. It's funny how those usualy are the people in the back 1/2 of the pack when they are put on a track.
02-18-2009, 09:33 AM | #35 |
Master Wang
37
Rep 444
yeah and a 29 year old is totally enough to tell a 26 year old Ph.D in Computer Science and physics who he is. No thank you. I don't race my car even if i had the knowledge. once in a while i do pull a quick corner, but i don't race my car.
02-18-2009, 10:27 AM | #36 |
Rep 280
If NASCAR is good for anything, the Sears Point (I refuse to call it Infineon) race is great for showing the difference that heel & toe can make, especially going into Turn 11. This is a great clip of Boris Said going around Sears Point. The three camera shot shows the feet, the windscreen view and the car on the track so you can understand how it all comes together.
I didn't look for a clip that shows what happens when you don't heel & toe, but I'm pretty sure a search of "Infineon" and "Jimmy Spencer" or "Sterling Marlin" will find one. As axoid said way back on page one, though, it's not a technique you'll use much in autocross.
2008 135i Performance suspension, exhaust, grilles, front bumper, skirts, shift kit, spoiler. M3 front control arms, rear subframe bushings. Cobb'd. |
02-18-2009, 12:30 PM | #37 | |
or Rosencrantz
Rep 455
So then if you don't race your car, why are you coming here presenting yourself to be an authority? Because some Frend of your moms used to race? Come on "Doctor" |
02-18-2009, 12:31 PM | #38 | |||||
22
Rep 302
Prove you wrong? I can't prove anything, it's an internet forum. I'm just speaking from experience and knowledge. I have no idea why you brought up F1 cars, they have pneumatics for the clutch & gearshifting and the ECU automatically blips the throttle on downshifts. They heel-toe electronically Quote:
- So keep that in mind when reading that book. Otherwise it's all pretty solid info. Quote:
02-18-2009, 01:10 PM | #39 | |
Rep 280
Anyhow, good advice - ignore the double-clutch instructions, and the theory at the beginning of the chapter is a good explanation about why you want to match revs under braking.
02-18-2009, 02:13 PM | #40 |
Rep 1,338
i see plenty of replies addressing the "smoothness" advantage of heel-toe (not disrupting the car with erratic fluctuations in the rear axle speed... this is the advantage of rev-matching), but the major purpose of heel-toe in a racetrack scenario is to save time before entering a corner by multitasking.
working in REVERSE chronological order from turn-in back to the initial braking point, if you don't heel-toe, you have to downshift before you turn in, but after you brake. during the time you spend performing the downshift, you are neither accelerating nor braking. you must therefore leave yourself some "coasting room" between finishing your braking and your turn-in point. this is wasteful. by using heel-toe, you perform the downshift while you're braking. this means that you are able to turn in as you have completed your braking, which means that you can brake later, and therefore stay on the gas longer. this paves the way for trail braking, since you're just coming off the brakes as you're turning in, but that's a different discussion. simply put, approaching any given turn, if you cover 15 feet performing your downshift between braking and turning in, you could brake 15 feet later and accomplish the same braking and downshift by the time you get to the turn-in point if using heel-toe. |
02-18-2009, 03:25 PM | #41 |
Rep 1,159
I'm a noob and still learning how to heel-toe. I found it very difficult to keep a constant pressure on the brake while bliping the throttle. the Stock gas pedal is a tad too far for me to do "ball-toe" and it's even more difficult to do heal-toe, coz the pivot point of the gas pedal is at the bottom, so you've to really raise the heel higher up to effectively blip the throttle. This is even harder when you are not braking Hard (i.e. on service streets), coz w/o fully depressing the brake, the distance to blip the throttle is even further.
Then, I decided to get some performance pedals that has an extension at the top of the gas pedal. This makes it so much easier to keep a constant pressure on the brake while hitting the gas. But then, I've to be more careful when braking and not hit the gas at the same time. |
02-18-2009, 03:50 PM | #42 |
Rep 1,338
i've been fine with all the OEM pedals in all the BMW's i've had (e36 325, e46 328, e46 m3, now 135i), but needed aftermarket pedals in the audi s4. for the bimmers, i leave my heel on the floor half overlapping the gas pedal. i use the ball of my foot just under my big toe for the brake pedal, which leaves the right side of my right foot covering the left side of the gas pedal. i dont move my heel at all, just "roll the ball" of my foot to the right to get the gas.
02-18-2009, 04:09 PM | #43 |
Rep 829
Cholewski -- To make you feel any better... after reading this post last night I went out for a ride. I sucked ass with the heel-toe. As stated above, the gap between the pedals are too wide for me.
'08 135i.
02-18-2009, 04:32 PM | #44 |
Rep 1,338
i was originally told to start with the ball of my foot on the brake pedal with my heel straight below, then to pick up my heel and pivot my heel to the right to get the lower part of the gas pedal with my heel. this is mechanically bass-ackwards when the gas pedal hinges at the bottom.
try starting with your heel planted more in front of the gas pedal, tilting leftward to get the brake pedal with the left side of the ball of your foot. now roll the ball of your foot to the right. this way part of your foot is already overlapping the gas at all times, and is avalable for a blip. this way, the entire right side of your right foot is over the gas at all times to blip. |
