Power Box FTW!!!!!!!!!!!!!!!!
11-25-2009, 01:56 PM | #25 |
Joint Chiefs of Staff
4927
Rep 116,037
11-25-2009, 02:14 PM | #26 |
Rep 3,879
I can break traction from 1st, through second once it gets going lol
the PBX is the best upgrade out for the n52. But I have light wheels and tires and no muffler to hold down the back tires. |
11-25-2009, 07:56 PM | #28 |
Moderator
497
Rep 27,441
Regarding the mpg comments, I'm on map three and driving as I normally do (usually just in D mode), and my mpg has gone up too!
I'm happy with it performance wise as well!
11-25-2009, 08:44 PM | #29 |
Rep 815
Can anyone point me to some data on what sort of power improvement the Powerbox tune provides on a 330i (or Z4 3.0si)? The only real numbers I've seen are for the 328i.
11-26-2009, 02:21 PM | #31 |
Rep 701
Yeah, my skinnier, lighter snow tires/wheels improve gas milage a bit too, sometimes up to 10% on the highway. OEM tires/wheels are so heavy. Go figure.
_________________________________________________
11-26-2009, 03:35 PM | #32 |
Rep 901
11-26-2009, 07:34 PM | #35 |
Rep 901
11-27-2009, 12:16 AM | #36 |
Rep 3,900
just bought it off **********s :-) I can't wait. 330i manual with afe intake full exhaust with no cats/resonators with an ikon muffler.
11-27-2009, 06:40 AM | #37 | |
Rep 967
Drives: E92 335xi, 2010 Boxster S
It would be great if you could do a Dyno at Map 0 and Map 3, I'm very curious on what is the actual Horsepower gain if any on the 330 manual Thanks
11-27-2009, 04:47 PM | #38 |
Rep 33
11-27-2009, 08:14 PM | #39 |
Rep 1,564
11-27-2009, 10:15 PM | #40 |
Rep 3,900
I actually am going to do a dyno my friends at Fluid Motor Union in Chicago owe me a dyno. ill do both and compare.
11-27-2009, 11:23 PM | #41 | |
Rep 967
I will most likely order one anyway but , I'm looking forward to see if you really get gains and its not only seat of the pants
11-28-2009, 04:13 PM | #42 |
Type A - BMW Concours Judge
19
Rep 143
2008 323i - Now this is the way it should have been sold
After reading this thread, I decided to jump in and give it a try. So, I am sitting here with a big grin on my face as I have just finished and Waahooooo!!!
The installation was as documented, but here are some things I found. Take your time. It will take you about two hours, this is not a race and you don't want to mess up. Instructions are very clear, read them over a couple of times before you start. You will spend most of your time removing and replacng the cowl, etc. The actual connection of the wires was 10 minutes. Make sure you don't knock off the speed nuts that hold the cowl in place. There are two of them, one on each side. I had a spare. ECU cover is a pain to put back on. Hint... remove the two black clips and insert them after you have seated and locked the ECU cover down. Also, if you move the rubber cover on the left side, back a bit, the cover will slide into place easier. When you insert the new wires into the connectors, always in set them with the little tab up, so that if you ever want to remove this, you can disengage them by just pressing the tab down with a little screwdriver. All in all, the throttle response is noticeable right away, waiting for the power to come on as that is supposed to take a couple of days.
2010 328i xDrive, Jet Black, K&N filter, Euro headlight switch, Alarm/door lock beep kit, BMS, slotted rotors with ceramic pads, etc
11-28-2009, 05:57 PM | #43 | |
Rep 555
