08-03-2010, 12:19 PM | #23 |
Rep 137
this thread gives me indigestion.
I hope things work outr well for you!
'11 Jerez M3 sedan, MDCT, ZCP
'99 Hellrot M3 vert, twin-screw SC, other goodies |
08-03-2010, 01:15 PM | #24 |
Rep 1,084
Drives: 2009 E-90 M3 space gray
Location: Deutschland KreisTrier auf Autobahn 64 & Tucson AZ
Not very common especially since your car has super low miles. BMW might want your engine sent to munich for evaluation. For they ca inspect it and find out why it failed if it was material failure or mechanical failure? And prevent future failures
08-03-2010, 01:57 PM | #26 |
Rep 798
Yeah saw your other thread... This doesn't really sound like a lemon law issue. That's generally for repeated failures of the same thing. If they do repair, push REAL hard for the extended warranty. They might just swap the engine though... probably easier for the dealership.
18 CQM M3
08-03-2010, 02:56 PM | #27 | |
20
Rep 157
Lemon Law has two qualifications in FL- either in the shop for 3 visits for the same issue or in the shop once for 15 consecutive calendar days (that's today). They have 10 days after they are given notice to remedy the problem after which time I can request arbitration (buyback or replacement). |
08-03-2010, 02:57 PM | #28 |
20
Rep 157
This is what I wish will happen.
08-03-2010, 03:08 PM | #29 |
Rep 3,173
Either way best of luck. Might want to research how much damage this part failure can cause and present it to them. Sometimes when the dealership sees you know what CAN happen because of the failure they work with you.
08-03-2010, 03:23 PM | #30 |
20
Rep 157
yep, that's what I've been trying to do this afternoon but not having much luck. I wonder how much of these engines are assembled by machine and how much by hand... especially with setting the valve seat, etc.
08-03-2010, 04:58 PM | #31 | |
Rep 798
18 CQM M3
08-04-2010, 11:53 AM | #32 |
Rep 3,836
Drives: Jerez E90 M3
Where do you bring your car for service??
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 | |
08-04-2010, 12:06 PM | #33 |
Rep 5,012
Good luck man. I was going to say to keep us posted, but every time something like this is settled, posters disappear (part of the deal with BMW, I guess), so never mind . Your silence will mean BMW gave you a new car .
08-04-2010, 12:34 PM | #34 |
Rep 5,012
Damn, so we '08 owners not only have to worry about possible defective main crank bearings, but bad valve springs as well? Geez! Add the expensive (after warranty) to replace ICV to the list, and it makes little sense to keep this car after warranty. What a shame; I really wanted to keep it. I bought one of the last '08s thinking most issues (ICV, etc) would be fixed by then. But most importantly, I assumed BMW learned its lesson after main bearing issues with the S54 engine, and didn't have to worry about that anymore. I assumed wrong . Oh well. I'll enjoy it for a couple more years, then switch to a P car on my 50th birthday. Good day.
08-04-2010, 08:38 PM | #35 | |
20
Rep 157
Coggin BMW of Fort Pierce. I'm not a fan of Braman in West Palm Beach.
08-05-2010, 03:44 PM | #37 |
20
Rep 157
Update:
Just got off the phone with the service manager: The piston head "lightly tapped" the valve. Valve was not bent. The parts they need to repair it are a new valve, valve spring, and retainer. No scoring of the cylinder wall. BMW will not entertain requests of a new engine or new vehicle. BMW does not see the need to replace the other valves. I said this was not acceptable. I am waiting for a return call from BMWNA. Am I out of line...what would you do?? Me: Last edited by SuitedPair; 08-05-2010 at 04:25 PM.. Reason: info edit |
08-05-2010, 05:32 PM | #39 | |
Rep 807
08-06-2010, 09:36 AM | #41 |
Moderator
7525
Rep 19,368
And for sure - ask them how they know the valve isn't bent. What are they doing, just eyeballing it? I would be very weary of the piston in that cylinder being ok. Even a slight deformation on the piston surface could in theory effect combustion. If they are replacing this valve that supposedly is not bent, then they should at least consider replacing the piston that supposedly is not scarred. Obviously that means cracking open the bottom end and lots of labor.
08-07-2010, 04:02 PM | #42 |
20
Rep 157
[ATTACH][/ATTACH]Just took pics. It was today (Saturday) so no manager or service advisor or tech. Don't know which valve spring went bad but I bet its the one with the lifter missing, closest cylinder to the firewall (far left in pic and those are the closeups).
I have a lot more pics...request more closeups and I'll post them. Thanks for any input. Last edited by SuitedPair; 09-27-2010 at 02:52 PM.. |
08-07-2010, 09:05 PM | #44 |
Rep 5,012
Piston and cylinder wall does look damaged on the pics, which is good news, I guess. How did the spring break? One little piece that went flying somewhere, or in the middle, and stayed in place? Any pics of that?
Is engine still in the car, or was it removed? It pains me to see a new car like that. Oh, and is it normal for pistons to be that dirty with just 1,300 miles ??? |
