05-18-2011, 08:16 PM | #23 |
European Editor
10640
Rep 22,992
engine
N54 = forged crankshaft N55 = cast crankshaft N54 = Mahle pistons N55 = Mopisan (Turkish) pistons suspension: N54 = progressive rear springs N55 = linear rear springs Note: I attached some BMW pdf's on the N55 and N54 engine's for your viewing pleasure. |
05-18-2011, 08:24 PM | #24 |
Rep 3,408
After doing some research, Mahle owns Mopisan
http://www.mahle.com/C12572E60048082...GTKHL749STULEN Mopisan was originally an aftermarket producer of pistons/components etc.. Who's to say they aren't made well or cannot handle the power. You don't know that for sure, and you don't know how much Mahle has had in the production of the pistons. After reading, it looks like Mahle has a lot to do with the production because their work load was getting large and needed to expand. You also cannot say that just because they are made in Turkey means anything because if Mahle pistons were produced in Turkey, you'd think they were from Germany. BMW can be a little foolish at times, but not that foolish. Last edited by Vectors2final; 05-18-2011 at 08:31 PM.. |
05-18-2011, 08:37 PM | #25 |
Rep 2,197
How about just post listing the differences between the two engines? Not personal opinions, but just a just a list of differences in parts/designs/manufactures. Ofcoarse, I'm opting myself out of compiling this list..
05-18-2011, 09:19 PM | #28 |
Rep 3,408
More to follow.... I am doing this because most of you won't read the PDF Dackel posted anyways, and this provides a lot of comparisons to both. Last edited by Vectors2final; 05-18-2011 at 09:29 PM.. |
05-18-2011, 09:20 PM | #29 |
The Fat Stig
Rep 274
(Thanks Dackel) Here's the differences I can find. IMO, the differences are "evolutionary" with exception of the Valvetronic system and much simpler oiling system. I have a feeling the N55 is going to be easier on oil than the N54.
N54: Some cams are cast, some are lightweight hollow N55: All cams are lightweight hollow N54: Vacuum pump gets oiled by unfiltered oil N55: Vacuum pump gets oiled by filtered oil N54: Connecting rods (small ends) do not have a hole N55: Connecting rods (small ends) have a hole (Which distributes load better) N54: Crank is forged, weighs approx 23.3Kg N55: Crank is case, weighs approx 20.3Kg N54: PCV system uses "cyclonic separators" N55: PCV system doesn't use them N54: No Valvetronic system (More complex oiling system) N55: Valvetronic system, with simplified oiling system N54: Intake valve size: 31.4mm, Lift is 9.7mm max N55: Intake valve size: 32.0mm, Lift is 9.9mm max (exhaust valve size/lift values are the same) N54: Less span on intake/exhaust duration N55: more span on intake/exhaust duration N54: VANOS units are heavier (possibly not Al), and slower adjusting N55: VANOS units are lighter (Made from Al), faster adjusting, simplified oiling N54: BMW Piezo high pressure (HPI) multi-hole fuel injectors N55: Bosch solenoid-valve fuel injectors (HDE) multi-hole are used N54 & N55: Use same HPFP, Pressure sensor & fuel rail N54: Dual mass (heavier) vibration dampener for crank N55: Single mass (lighter) vibration dampener for crank N54: Diverter valves are operated pneumatically N55: Diverter valve is operated electronically N54: Four catalytic converters are used N55: two catalytic converters are used (two "bricks" are inside the single canister) N55: PCM "DME" is mounted directly to intake manifold, and is cooled by intake air. N55 has newer ignition coils. N55 has newer oil pressure sensor that reads absolute pressure (N54 reads relative pressure) N55 has a newer more accurate O2 sensor N55 uses a Mass airflow sensor, N54 does not.
05-18-2011, 09:30 PM | #30 |
Rep 110
05-18-2011, 09:38 PM | #32 |
Rep 3,408
Dackel posted it above, but I decided to let everyone see because half will still talk, not even read. Plus, I can host all of these no problem..
05-18-2011, 09:41 PM | #33 | |
Extinct
Rep 81
Great info, but I don't see it making much difference. N55 loyalists will scream about lighter weight/rotating mass and that theirs is more advanced and N54 fans will yell about how theirs is stronger and simpler.... I guess people can't just be happy that they have a great engine, it has to be "Better than yours". |
05-18-2011, 10:41 PM | #40 |
Rep 1,044
yup. directly from the award site. bmw twin turbo! they also go on to mention the 1M. n55 != twin turbo http://www.ukipme.com/engineoftheyea...s_11/25_3.html
05-18-2011, 11:03 PM | #41 |
Rep 105
Lots of good info. Read quite a bit. I have an N54 and read somewhere peak boost is 8.8psi, is the N55 the same?
Before this read I only knew the N55 reached peak boost at 1200 rpm As opposed to 1400 and that it was a twin scroll which means there's 2 up pipes for quicker turbo spool if my STi day memory is correct. Also, does anyone know the sizes of the N54 and N55 turbos? For example my Forced Performance Green turbo had a 49 lb wheel on cold side and had an 8cm on the hot side. You'd think with the great BMW engineers the N55 would be better in almost every way, but there's always cost savings and sounds like one of them was the cast crank.
Burger Tuning JB+, AFE intakes with scoops, Clear bra and headlight film, City Vision Lighting for DRL & PL Halo's (6 LED), 20% tint, BMW alarm, RHO-Plate, Burger Tuning 12mm spacers in front with 255/35/18 in rear with 10mm spacers, Nitrogen in tires, Black OEM surround kidney grills with chrome slots!
Last edited by Mikeshot1; 05-18-2011 at 11:05 PM.. Reason: Added it was a FP Green turbo |
05-19-2011, 12:33 PM | #43 | |
Rep 611
As for the award site the link you posted is the engine in the 1M which yes is the N54, but it seems as though they have put the 1M N54 and the N55 together in that award because if you look at the other cars listed some of them are only the N55....like the X6 35i, the 335i 2011, x5 35i, x3 35i, 740i for example is the 300hp N55.
2011 AW 135i - DCT - M Package - BMW Performance Suspension Kit - Berk Street Midpipes - Evolution Racewerks FMIC - JB4 - BMS Intake - BMS Downpipes
