      02-17-2012, 10:47 AM   #23
Louis75th
Drives: 2009 130i 2008 135i
Do you think AHL headlight with led brows can be fitted on 2008 135i with AHL and xenon directly?
No coding?
      02-17-2012, 11:59 AM   #24
Jori
38
Drives: 1series
No coding?
Should be the case.
However, when i am able to attach the plugs, i will check that on my own car tomorrow
      02-17-2012, 12:10 PM   #25
CentralPA E82
Rookie
Drives: 2009 128i
Bump for Thomas. I bought a set from him last year, good riddance to the halogens.
      02-17-2012, 12:15 PM   #26
Jori
38
Drives: 1series
THX
      02-17-2012, 01:08 PM   #27
Jori
38
Drives: 1series
      02-19-2012, 08:45 AM   #28
AW128i
AW128i's Avatar
Drives: E82 N51
I can't remember, did you end up replacing your NFRM module, too, to get the lights to work?
"The Camaro's V6 makes so much horsepower because them horses are trying as hard as they can to run the fuck away from that ugly ass car." -Golden3ye
      02-24-2012, 03:32 AM   #29
Jori
38
Drives: 1series
I will rewire the led brow inside the lights, so they will behave just like the normal lci Xenos.
      02-25-2012, 09:21 AM   #30
Jori
38
Drives: 1series
Done and working
      02-25-2012, 09:24 AM   #31
Jori
38
Drives: 1series
No coding?
YES, just tried and it will work 100% by plug'n'play
      02-25-2012, 11:14 AM   #32
CentralPA E82
Rookie
Drives: 2009 128i
To AW: Kept the original FRM, wired a set of capacitors between the harness and the light housing (used 9006 connectors for a clean install). No issues
      02-25-2012, 12:04 PM   #33
Jori
38
Drives: 1series
Could you PLEASE explane it more detailled? Would make my life much easier
However, it is also possible to shut the error message down by using BMW EDIABUS software.
      02-25-2012, 03:48 PM   #34
CentralPA E82
Rookie
Drives: 2009 128i
I tried NCS Expert first, unfortunately the FRM would not accept the coding. A new FRM runs $300+ so I wired in a set of capacitors to stop the flickering.
      02-25-2012, 04:23 PM   #35
Jori
38
Drives: 1series
Ok, sounds good so far.
BUT how much Ohm for the capacitors and on witch wires.
PLZ ;-)
      02-25-2012, 05:03 PM   #36
CentralPA E82
Rookie
Drives: 2009 128i
Jori - the easiest way around the frm is to purchase a set of error cancellers and the 9006 connectors from ebay (there are other sources but ebay is the least expensive). I ran a new ground wire on each side from the grounding bolt on the front fenders to the canceller. The positive lead from the harness provides the switched current for the canceller. The other lead from the canceller goes directly to pin 2 (ground) and pin 3 (xenon) of the headlight connection. I used the 9006 connectors to provide a clean installation and allow me to swap out the canceller should it need replacement in the future.
      02-25-2012, 06:00 PM   #37
RedTRex
Digital Cerebrum
Drives: 05 330ci ZHP
2005 BMW 330ci  [0.00]
This is good, but can you do it "for dummies" ..... what kind of error cancellors and which 9006 connectors. Perhaps a few pics please.
also - What is the FRM if people want to swap it out?
Thanks much!
Rick
      02-26-2012, 03:47 PM   #38
Jori
38
Drives: 1series
@CentralPAE82
Thanks! Yould you post a link for a suitable error canceller?
Would help a lot.
@RedTRex
FRM = Foot Room Module
Sitting in the foot room left and controls the light functions
Costs $300
      02-27-2012, 02:08 AM   #39
ichiban
ichiban's Avatar
95
Drives: 08 135i
do these have similar angel eyes to the 3 or 5 series? I know the older angel eyes (08) were different than the 3s.
      02-27-2012, 02:25 AM   #40
Jori
38
Drives: 1series
You can see the angel eyes on the pictures.
      02-27-2012, 02:28 AM   #41
Jori
38
Drives: 1series
Something like this
http://www.**********s.com/Super-Har...MW-E82-E90.htm
      02-27-2012, 02:30 AM   #42
Jori
38
Drives: 1series
http://www.ebay.com/sch/sis.html?_nk...r+resistor+H11
      03-12-2012, 09:38 PM   #43
SickSixSpd
9
Drives: BSM 135i
R these still available?
      03-13-2012, 02:03 PM   #44
deadmoo
Drives: 2008 135i Vert
Are dynamic headlights still available?
