11-28-2012, 11:07 AM | #23 |
31
Rep 218
What tires would look ideal on 19x9 OEM ZCP wheels ? I believe you guys have best knowledge on this one , so I'm asking.....
I need them to be as wide as possible and don't rub on Xdrive |
11-28-2012, 02:42 PM | #25 |
Rep 4,323
how much are those going to weight in the end? I hope not much more than those sexy M's sitting in my garage
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
11-28-2012, 03:54 PM | #26 |
Rep 1,975
Yea, I resurrected this thread from the dead. My 19x10 wheels will be more like +45 offset. I'm trusting that Forgestar knows what they are doing. When I ordered, **********s said that Forgestar makes them to order and does the offsets based on your car to make them sit flush. Should have the wheels in a week or two so we shall see....
11-28-2012, 04:06 PM | #27 | |
Rep 3,780
The new ones are 22lbs F and 24lbs R.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
11-28-2012, 06:43 PM | #29 |
Rep 1,975
11-29-2012, 12:00 PM | #30 | |
Rep 411
Mind posting the specs you went with? I'm running through some choices in the calculator and it's showing that 19x10 +38 should work. Paired with a 265/35 it is 14mm more aggressive and only 4mm taller relative to the stock 18" rims. |
11-29-2012, 01:22 PM | #31 |
Rep 65
I have 245/35/19 front and 265/35/19 rear bridgestone re11 . It looks perfect and no rubbing even with 5 people and lowered on HR sport springs..
11-29-2012, 01:27 PM | #32 |
Rep 1,975
Are you on 19x10 in the rear? If so, is there still a little room with your 265 tires? You think a 285 would fit?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
11-29-2012, 01:29 PM | #33 |
Rep 411
11-29-2012, 02:05 PM | #35 |
Rep 65
11-29-2012, 02:18 PM | #36 |
Rep 1,975
Thanks for the pics and info. Man, this is really changing my plans... What's the width of your front wheels? 8.5? Is there extra room there where a 255 would fit?
11-29-2012, 02:24 PM | #37 |
Rep 411
I'm starting to doubt the calculator...
9.5 vs. 10 - the same |
11-29-2012, 03:31 PM | #39 | |
Rep 65
11-29-2012, 04:00 PM | #40 |
Rep 1,975
Are yours 8.5 in the front?
11-29-2012, 05:20 PM | #42 |
Rep 1,975
Cool, I think my fronts should be ok with 255/35 but it might be tight! Now I'm wishing I wouldve went 8.5 front and 9.5 rear
11-29-2012, 05:21 PM | #43 |
Rep 497
i'm planning on the below tire specs for my current rims
20x8.5 : 235/30/20 20x10 : 275/30/20 just want the tire to protect my step lip =] |
BLACK HAWK DOWN105.00 |
11-29-2012, 05:51 PM | #44 |
Rep 1,975
What do you currently have on your 20s?
