11-12-2012, 12:44 PM | #23 | |
Rep 5,951
The issue I've seen with GC plates is when people attempt to pull the F strut into the strut tower by torquing one screw. I've personally installed 4 sets of GC plates (fully torqued to 18 lbf-in) and I've had zero installation issues and zero noise issues. The only thing that creates noise, regardless of camber plate, is if the sway bar is not aligned properly on a lowered car and/or the OEM sway bar chassis mounting bushings are too tight (this is very common). |
11-15-2012, 09:55 PM | #25 | |
442
Rep 2,373
How many track day have you had with GC plates ? You can torque it to 18 lbf-in but GC calls to torque it to 18 ft/lbs, but the most important issue is that even if the stud is still in place, the actual plate gets bent and you can't see it unless you remove the CP from the car and compare to the new plate. Aleks. |
11-16-2012, 05:28 AM | #27 | |
Rep 5,951
I made a comment about the sway bar noise because I've never heard a single noise coming from any of the GC "street" plates I've used/installed. Yes, I know the difference between noises caused by camber plates and sway bars/end links. Number of track days may increase the probability of a bolt failure; however, the combined axial-bending-torque/shear loading applied to the bolts while installing the front strut is much worse than the loading the clamped-up and preloaded strut bolts will be subjected to once installed - the installed plate and bolts act like two "springs in parallel", and the load sharing between the bolts and plate is a function of their relative bolt-to-joint stiffness ratio. |
11-20-2012, 10:51 PM | #28 | |
442
Rep 2,373
just sharing our experience ... that's all |
11-21-2012, 06:17 AM | #29 | |
Rep 5,951
I would share my experiences with you but I don't want to start anything - we all have preferences on the parts/brands that we use and I'll leave it at that... Again, thanks and to get things back on topic - awesome build |
