02-26-2015, 06:24 PM | #23 |
///M
161
Rep 1,867
Thanks Harold i'll contact you soon!
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI |
02-26-2015, 07:16 PM | #24 |
Rep 623
Is the tension arm bushing the most common part of the front suspension to wear? My car has developed a looseness in its front end which slightly noticeable while going over speed bumps at an angle.
02-27-2015, 02:04 PM | #25 |
Supreme Allied Commander
3888
Rep 54,541
Drives: F80 M3
Yes, in most cases it's the tension arm bushings. The wishbone is a bearing, that is more like a clunk. Same with the upper strut mount.
05-30-2016, 01:49 AM | #30 | |
3888
Rep 54,541
Drives: F80 M3
If you drive on the street at all and the roads are bad, the street(black) is the way to go. |
05-31-2016, 11:16 AM | #31 |
1478
Rep 2,672
Ordered! Went with the street compound, looking forward to trying these out.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
