      04-09-2014, 09:26 AM   #23
3002 tii
3002 tii's Avatar
2305
Drives: Z4 M, X5, GX460
Originally Posted by JSavela View Post
Not sure how I forgot to include these. Thanks for pointing it out. I've updated the original post. I'm sorry if anyone ordered up everything without the plastic caps.
Nothing had to be modified. It was a direct replacement.
It's an M8, probably 1.25 pitch. You can remove one of your 6 stock strut mount nuts to double check.
Thanks, I reread your original post... yea that's tough. I didn't realize at first you were referring to the hex nuts that go over the strut tower. I don't even know how to describe that type of nut, it's M8 hex nut but with a threaded 'stem' on the other end lol. I checked Fastenal and couldn't find anything so I doubt anyone else carries this.
For anyone else thinking about ordering this kit from ECS, I'll add 2 minor notes. One, the incremental cost to add 7 quarts of Official BMW 5w-30 motor oil was was $2 in s/h charges so it might be a good time to buy oil. Their charge only $6.82 per bottle.
Two, OP noted that you don't need to buy part p/n 31316769731 (x4) since you can reuse 4 of the 6 you are replacing by the strut tower. With that said, if you wanted black hardware to match your bar, Fastenal sells these quite cheap at $0.50/ea, although shipping ruins the deal. If anyone wants, I can buy a bulk order of these black M8 hex nuts and can ship them out to you via snail mail for the cost of hardware + postage + paypal fees. Just let me know, plan to put my order in by end of week. You would need 4 of these.
http://www.fastenal.com/web/products/details/11508216
Follow for latest mods
      04-09-2014, 10:35 AM   #24
JSavela
13
Drives: BMW 135i
Originally Posted by MightyMouseTech View Post
Hmm, going to be installing the Dinan fixed upper mounts, hope they will work with this.
This will work with the dinan fixed plates. All of the additional camber from the plates occurs on the underside of the strut tower. The top side, where the strut brace mounts, remains unchanged.
      04-09-2014, 10:49 AM   #25
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Perfect. Thanks!
      04-09-2014, 10:56 AM   #26
3002 tii
3002 tii's Avatar
2305
Perfect. Thanks!
The Dinan plates (or any camber plate for that matter) plus the strut tower brace will reinforce the strut towers which are known to cave/crack/mushroom on older BMW's so this is another reason to buy these parts.
Thanks again OP, I just put my order through with ECS. My ETA looks similar to yours, expected ship date is May 6th.
      04-09-2014, 02:36 PM   #27
vivanapoli806
Drives: 2012 535i Xdrive Msport
For you guys piecing this together just order through a vendor on here that works at bmw. U won't have to wait at all. I talked to Phil@reeves and gave me great quote
      04-09-2014, 10:55 PM   #28
Boosted_N54
Boosted_N54's Avatar
182
Drives: 135i N54
is there any difference in handling? is it bigger size?
      04-09-2014, 11:42 PM   #29
Sixle
Sixle's Avatar
17
Drives: CR 135i N54 6MT
negligible, but open up top strut towers for easy rebound/compression adjustment for car with adjustable damping. a brace going from tower to tower would be more effective for rigidity than this
      04-09-2014, 11:58 PM   #30
Venom
Venom's Avatar
Drives: M2 Competition
2008 BMW 135i  [8.50]
Thanks for posting! Would save me a lot of time to get these. Definitely going to nab this in the near future!
      04-11-2014, 07:32 AM   #31
TheBreeze
Drives: 2016 F80
Did you end up purchasing the black nuts? I'm in for 4 if you ordered them.
2016 F80 M3 (Mineral/Full SO)
2014 X5 M Sport (Mineral/Mocha)
      04-11-2014, 08:33 AM   #32
3002 tii
3002 tii's Avatar
2305
Not yet, still leaving this out there for now since I know the install can be done with the existing nuts. But I check back in a few days and tally up the final count =)
      06-03-2014, 06:49 PM   #33
3002 tii
3002 tii's Avatar
2305
After waiting 2 months for the parts to arrive I just got around to installing this, the only minor issue I had was when tightening the passenger side brace over then strut, the arm was hitting an electrical cable. Upon tightening one of the nuts I actually saw a blue spark so I immediately stopped. Adding 2 washers over the inner most strut hole closest gave me enough clearance but then I had difficulty tightening down the main plastic cowl because the nuts overt the brace were touching. Not sure if that was exacerbated by the washers or not but no big deal.
2 washers over strut tower gave enough clearance:
Bar installed before putting the plastic trim back on:
      06-03-2014, 08:10 PM   #34
jafo1701
40
Drives: 2011 135i, 2016 VW GTI
I just did mine today. Everything went smoothly except I broke a clip on the cabin filter housing. Non essential, I'll
Probably replace it down the road though.
      06-03-2014, 09:27 PM   #35
3002 tii
3002 tii's Avatar
2305
Interesting you didn't encounter the issue I had where the right side brace was pushing down on that cable
      06-03-2014, 10:07 PM   #36
jafo1701
40
I never really noticed it. I'll take a another look in the morning see if it's touching it. Shouldn't the cable be insulated anyways? I wouldn't think they would leave a cable that would be conductive to metal parts exposed in the engine bay.
      06-03-2014, 10:18 PM   #37
3002 tii
3002 tii's Avatar
2305
It is insulated but nonetheless when I began tightening the strut nuts, I heard some crackle and then a blue spark appear from that harness. Didn't want to chance it.
      06-04-2014, 09:19 PM   #38
jafo1701
40
I doubled check this morning everything cleared fine. No problems....maybe it was a static electricity discharge.
      06-04-2014, 10:16 PM   #39
3002 tii
3002 tii's Avatar
2305
Maybe but I know for sure without the washers it was definitely pressing down on the cable
      06-05-2014, 06:40 AM   #40
Southjersey128
Southjersey128's Avatar
Drives: 2008 128i
2008 BMW 128i  [10.00]
Thanks for posting. I have the stock setup with the BMW Performance strut bar, which I don't think really does anything as far as stability. Id swap that for something like this that actually does something for the car. I had to make a special tool to adjust the rebound adjustment on the top of my Koni's, it works but its a pain in the ass.
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
      06-10-2014, 11:10 AM   #41
wham
wham's Avatar
Japan
Drives: 2010 135i M-sport (N55 DCT)
Hi, I ordered these parts a week ago from Germany.
They have arrived today. (so quick!)
In my case, It seems that the top of bolt (connect "Mounting Ring" to "Strut Bar" ) interferes against "Microfilter Cover" a little.
In order to make cleaner install I had to cut the top bolt - this modification make the whole install more aesthetically looking.
In general - this is great low cost modification to my car.
Thank you for posting!
      06-10-2014, 12:28 PM   #42
JSavela
13
Drives: BMW 135i
Awesome! I'm glad this is working out well for everyone! Thanks for everyone else's input on their personal experience.
      06-10-2014, 02:28 PM   #43
3002 tii
3002 tii's Avatar
2305
I had the same problem of the bolt rubbing against trim but I forced the trim down lol. I just figured it rubbed because I added a spacer over my strut tower.
      06-10-2014, 02:51 PM   #44
MightyMouseTech
4338
Hmm, is the trim on the 1M different so it does not do this?
