08-23-2013, 11:25 PM | #4423 |
Rep 1
Dear Shawn, I have an F30 316i Jun 2013 built. Would greatly appreciate if you could PM or email me at creati87@hotmail.com the link to the latest e-sys, data files and instructions.
Thank you in advance! |
08-23-2013, 11:28 PM | #4424 | |
General
10545
Rep 41,221
08-24-2013, 04:45 AM | #4425 | |
Rep 88
The only that doesnt work, copying from the stick to the internal Hard drive. Wanted to try reformatting the stick to NTFS and see it that makes a difference. |
08-24-2013, 05:48 AM | #4426 | |
General
10545
Rep 41,221
08-24-2013, 09:51 AM | #4427 |
9
Rep 149
I have installed my e-sys 3.22.5 yesterday. I have connected my 328i 2012 f30 to my laptop. I have opened E-sys and connected all successful.
Does anyone have a video on what to do next. I am not sure where to navigate to so I can turn off seat belt minder. A video or a phone call will help. Thanks Aaron Thanks |
08-24-2013, 09:59 AM | #4428 | |
General
10545
Rep 41,221
http://rapidshare.com/files/20447265...d%20Coding.pdf
08-24-2013, 10:57 AM | #4429 |
9
Rep 149
Shawn,
Thanks or the step by step. It helped and worked sort of. I am not able to get into ACSM modules. I can only connect to 1 of the 3 on my car. I am guessing the 3000 Ausstatftungsflags are in a module I cannot connect to. (trying to turn seat belt minder off) I get this message I cannot connect to FEM BODY similar message as above^^^^ I can connect to HU CIC and I was able to code the legal disclamer to be off. I am not sure what I am missing. Aaron Last edited by amf; 08-24-2013 at 11:02 AM.. |
08-24-2013, 11:07 AM | #4430 | |
General
10545
Rep 41,221
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 08-24-2013 at 11:16 AM.. |
08-24-2013, 12:48 PM | #4431 |
9
Rep 149
Thanks Shawn,
Thanks to F30post.com too. I am able to sucessfully code my 328i f30 2012. If anyone in Houston TX needs some help let me know. I will try to help out. Aaron |
08-24-2013, 12:49 PM | #4432 |
General
10545
Rep 41,221
Thanks! I'll now start referring everyone to you.
08-24-2013, 01:11 PM | #4434 |
9
Rep 149
I coded my mirrors to fold with my key fob today. To fold my mirrors I have to hold the lock button down for a couple of seconds. Is there any way to have them fold with a press of the lock button instead of holding button down?
Thanks |
08-24-2013, 01:15 PM | #4435 | |
General
10545
Rep 41,221
E-Sys - How to Change Werte Values http://rapidshare.com/files/10078793...e%20Values.pdf
08-24-2013, 02:45 PM | #4436 | |
Rep 1,892
FEM_BODY / 3053 / KOMFORT_SCHLIESSEN. As Shawn says, change the werte value. The default is 0F (15 in decimal) and the units are in 100ms, so the default is 1.5 seconds. I set mine (and others) to 03 or 300ms. That way is only folds when I hold the button down for an extra heartbeat. I've coded others to 00 for those that want the mirrors to fold every time they lock the car. |
08-25-2013, 08:32 AM | #4438 | |
Rep 31
Could pls send me the link ? Regards |
08-25-2013, 08:54 AM | #4439 | |
General
10545
Rep 41,221
Using newer PSdZData on a car programmed with older ISTA/P version buys you nothing. The car will still only be capable of the features programmed into it from the older ISTA/P version, unless you are going to flash the ECU's with the new 50.3 firmware.
08-25-2013, 09:29 AM | #4440 |
Rep 1
Hello Shawn,
May I have the links to the software also? Just ordered the cable. Also I have a question. Does mirror folding require extra hardware or is that just a software setting? My car does not have mirror folding. I am curious about what I can do with a standard screen(No NAV) and standard bluetooth. I cannot stream DVD over my screen now and I cannot connect iphone with a standard white iphone cable at the moment. I can send bmwvin output if it helps. |
08-25-2013, 09:35 AM | #4441 | |
General
10545
Rep 41,221
Mirror Folding requires hardware. The car must currently have Power Folding Mirrors from the Drive's Side Interior Door switch, and then you can make them also fold from Fob and Comfort Access. With 6NH Basic Bluetooth, and no 609 NAV, hence no Combox, you won't be able to code much at all. Even with a Combox, you can only stream Audio, not Video.
08-25-2013, 09:57 AM | #4442 |
46
Rep 383
Hi All- I was coding and for some reason when I'm using navigation, instead of showing directions in the HUD, it now shows below the speedometer. Anyone know how to fix this? 2012 F30. Thanks!
08-25-2013, 10:02 AM | #4444 |
General
10545
Rep 41,221
You have to post an email or wait until you can receive PM's.
