Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > V1 hardwiring through fusebox
      03-12-2012, 02:28 AM   #441
jello
jello's Avatar
184
Drives: LCI M2
2018 BMW M2  [8.33]
wow! just answered all my questions and concerns! thank you so much! such a big help! luv this forum!
      03-25-2012, 11:38 PM   #442
fmusignac
Drives: 2020 BMW Z4 M40i
I did it today. I got the mini ATM from autozone and the hardwire kit from eBay. Total about 15 bucks vs 100 that I payed for hardwiring my last car.
Im having a problem though. After a short drive I added electrical tape to the connection of the hardwiring kit and the fuse tap. Now it will not turn off when I shut off the car completely. The HomeLink will only work with the car on but the radar stays on. I guess I will give it a day or two and see but I would like to hear if anyone has seen anything like this.
I do have a 10 amp fuse for the radar and the 5 that was there previously. They were out of stock of the 1 amp fuses Ive seen recommended in different posts here.
THANKS!
      03-27-2012, 12:08 PM   #443
Mech_Man
I'm feeling much better now, Dave
Mech_Man's Avatar
Drives: 2008 335i e92 (MontegoBlue/Bk)
Originally Posted by fmusignac View Post
.... After a short drive I added electrical tape to the connection of the hardwiring kit and the fuse tap. Now it will not turn off when I shut off the car completely. The HomeLink will only work with the car on but the radar stays on. ....
I do have a 10 amp fuse for the radar and the 5 that was there previously. They were out of stock of the 1 amp fuses Ive seen recommended in different posts here. THANKS!
Congrats on the wiring.
RE the Radar Detector always on: sounds like you tapped into one of the fuse block circuits that doesn't ever shut off. Do you have the fuse block map/layout card to tell us what circuit you connected? (Don't just give us the circuit number, as BMW didn't use set numbers, they changed from year to year, from car to car - if you have the name of the circuit, or even the little icon, we can check it, and hopefully recommend a circuit number for a switched-power circuit like the cigarette lighter (see attached image for icon).
RE: The fuse amp size isn't all that important as these units use so little power. You really want a fuse, but mostly in case the power wire is accidentally shorted to ground so the fuse would blow to protect all the other stuff. And if the power wire is grounded, it will use more than your 10 amp, thereby melting the fuse.
-=] 2008 335i e92 Montego Blue & Black; Prem; Sport; AT-paddles
-=] Mods= VEI Digital Boost Gauge in RiXeffects custom Pod
-=] Tinted (front: 3M Crystalline 70); (rear: Johnson InsulatIR 40 ceramic); 3M ClearBra
      03-27-2012, 10:57 PM   #444
fmusignac
Thanks Mech...
I did the fuse tap to the HomeLink... Its weird because the HomeLink will instantly stop working but the radar is still on... It doesnt make any sense I know but I tripled checked everything!
I did notice it will shut off by the time I come back... But I havent been able to stay by the car long enough to see when it actually happens... Appreciate your comments...
      06-24-2012, 05:02 PM   #445
Quasimodem
Quasimodem's Avatar
Drives: 335d
2009 335d US  [0.00]
Thanks Mech...
My 09 e90 335d has two fuses for homelink. When I tried the first one with the tap with the tap, I could hear my alarm (I am installing a car alarm not a radar detector) click immediately, and the car was off, so I knew that was wrong. The second one I got no response from, so it should be the switched ignition wire (however the tap fit in very lightly so It could be a bad connection, I guess I will find out). Otherwise, if you have two fuses for your homelink like I do, use a DMM on the each until you find the one that has no power when the engine is off. I guess the homelink needs constant power and power when ignition is on, strange because it only works when ignition is on. But I cant think of any other reason for two fuses.
If your homelink is stopping working while the engine is on, maybe you have a bad tap -- it is sending the engine on signal down the RD line and not the homelink line.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
      09-27-2012, 08:28 AM   #446
virtualbong
virtualbong's Avatar
105
Drives: 2015 BMW X5 MSport
Originally Posted by bilbarstow View Post
OK - I said I'd post pics - here they are
First- mount the V1 where you want it on the windshield, I chose just left of the mirror. The telephone wire can then be easily tucked between the headliner and the windshield with just fingertips to push it in. Route it across the windshield to the right side until you get to the place where the headliner meets the separation with the A-pillar cover (point A in second pic).
Put your fingers behind the black rubber moulding at the door side of the A-pillar (at B) and push behind the seam from A - B. The headliner can be gently pulled out enough to open up the gap so that you can feed the telephone wire behind it. You can then push the headliner back in without showing any change or separation.
Route the telephone wire behind the black rubber moulding until you get down to the glove compartment (third pic). Fitting it between the gap is pretty simple.
Once you are in the glove compartment (pic 4), placing the Fuse Tap and the V1 Hardwire adapter is very straight forward. Crimp the Fuse Tap red wire to the red wire of the V1 Hardwire Adapter. I also used the fuse for PDC / Homelink (third from right side in the second row of fuses - see the fuse map card in the compartment for details). Remove the 5 amp fuse that is in that slot and place it in the A slot of the Fuse Tap. I used a 3 amp fuse for the V1 because that was the lowest one I had - even though the V1 only requires a 1 amp fuse. I have since replaced the 3 with a 1. For the black ground wire, crimp on an eyelet connector, and I drilled a hole in the metal brace and used a #8 bolt and nut to attach it, secured with some locktite.
I mounted the Hardwire adapter to the sidewall of the fuse compartment using the supplied velcro (pic 5). The phone wire plugs in to the Hardwire adapter in the main slot. If I choose to later, it will be very simple to add the Remote Display - just plug it in to the Accessory slot.
Very simple installation - Thanks very much to Josh49's original post for the initial info - I hope that this helps any of you considering doing this for yourself.
Should be getting my 9500ix today so hopefully I'll have some time to hardwire it to my car this weekend. Looks pretty straight forward...I may just remove the A-Pillar so that it's easier to tuck the wires in.
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST
| 1998 Acura Integra (Black/Black) - PAST
      09-27-2012, 11:38 AM   #447
Mech_Man
Mech_Man's Avatar
I've run wires up each side and removing the A-Pillar covers takes seconds and really simplifies running the direct-wire cables.
The most important concern is to be very gentle in prying off the screw cover-plates. The plastic is easy to scratch or break. Use a very small screwdriver and work them off very slowly. If you have something similar to a screwdriver, but plastic, that would be better.
With those off, remove the torx screws and the pillar cover is very easily removed, (and replacing is just as easy).
What I'd like to hear, is has anyone taped into the power wiring in the ceiling, say the cabin lights or sunroof motor circuits? If that cover was easily removable, it would save wiring all the way down to the fusebox.
      09-30-2012, 12:40 AM   #448
melvin
steady lurking
Drives: 335i
i tapped into the sunroof harness. depending on how big your hands are i say its pretty easy to pop down that whole unit. i just pull down on the headliner close to the windshield and pop those two clips and viola. no problems yet for me
      12-15-2012, 12:28 PM   #449
Fzara2000
Drives: E92 335is
I just bought the mini fuse - its a round connection but the v1 connection end is square..? How did you guys get both ends to meet?
'13 E92 335is
      01-05-2016, 11:07 AM   #450
mrbubba
33
Drives: E90 325 M Sport
Great write up, just in the process of installing my dashcam using this guide. I ran into a slight problem, in that I purchased a large fuse cable and not the mini blade one!
How did you remove the fuse? My hands barely fit in the area and there is nothing that I can get a grip on, don't really want to use something metal.
      01-05-2016, 11:28 AM   #451
Mech_Man
Mech_Man's Avatar
Take another look at the actual fusebox. Most have an space where a fuse-puller is stored.
Look at the pic at
http://www.e90post.com/forums/showpo...61&postcount=9
Look for the pic with the caption "Ground Screw Added" and go 5 o'clock from there, you'll see one that's red, mounted horizontally. It's about twice as long as the fuse is wide.
It might take some fingernails to get the puller off it's hold-down posts.
      01-05-2016, 04:36 PM   #452
mrbubba
33
Look at the pic at
Never noticed that! I'll have a look in the morning when the new circuit cable arrives
      01-06-2016, 06:01 AM   #453
mrbubba
33
I'm having a mare with this. I ordered this cable which arrived just now, but it doesn't clip into the fuse box, the connection just falls out.
http://www.amazon.co.uk/gp/product/B..._st_dp_summary
It seems the black section is in the way. Here is a picture of the one that I have
Can anyone link to a cable in the UK that will work? I'm on my 2nd and its getting expensive
Will this one work better? Although I've just noticed that its 5amp each slot, when the slot I'm using is a 20amp fuse, although that is for the cigarette lighter socket, where as the PDC (assuming thats parking sensor) is only 5amp, so it may work.....confused!
http://www.amazon.co.uk/HitCar-Vehic...1A9N0CMT0RSWMV
      01-07-2016, 11:55 AM   #454
mrbubba
33
All working now, realised my error and bought the correct part.
      01-29-2016, 02:48 AM   #455
mrbubba
33
Spoke to soon. It worked fine for a while and now it will no longer keep power to the camera.
The Mobius is set to power up and start recording automatically when the ignition comes on. Recently it doesn't power up, if I manually try and power the camera, it starts and the switches off, as if it isn't getting power
      04-14-2018, 04:12 AM   #456
Supermonkeyballs
Supermonkeyballs's Avatar
17
Drives: E90 - M57 - 330d Saloon
Guys I have tapped fuses on my E90 for my dash cam, thought not for a radar detector, however the power needed (12v constant and 12v switched) will be the same... so if you’re after any further information about E90 power supplies (via fuses) please see my link...
http://www.e90post.com/forums/showth...ash+cam+wiring
      09-11-2018, 04:25 PM   #457
thanu8
Drives: bmws e90 2006
Smile hardwire
hey, great post, I'm trying a similar thing, trying to hard wire my dash cam, to my bmws e90 2006 320d, but when i try tapping into the fuse box it doesn't see to give any power to the dash cam, i've tried using the piggybank tap in cable too, and it still doesn't seem to give power to the dash cam, i've tried this on different fuses, couldn't get any power, and i've also checked if my wiring was correct and it is because if i try connecting the power cable to the battery of the car it works fine (i did this just to check if the cables were all done correctly), but when i try hard wiring it to the fuse box it just doesn't seem to give any power to the wire for the dash cam, any help?
thanks
